SDTW Custom Wheels & Tires
Old 10-12-2011, 11:15 AM   #1
cyrusthevirus
Drives: 2009 chevy cobalt ss, 1989 Iroc-z
Whats your take on modding for that extra power
What do you guys think it would take to push this beast to 700 hp or just under? I believe it can get very close to that limit with long tube headers, full 3" exhaust cat back, intake, Retune and pulley possible.
cyrusthevirus is offline   Reply With Quote
Old 10-12-2011, 12:43 PM   #2
IROCanSS
Drives: 89 IROC 350
Let's just take an SS... with all my listed mods, I gained around 55 rwhp
Baseline was like 355... now I'm at 410... that's a 15% increase... It "should" be the same here... maybe a hair more so with all that it's mire likely you'll be about 580-600 at the wheels with the pulley... Just cancel out the 15% drive train loss. If you want to talk CRANK hp, youd likely be 670-700 range... so yes if you're talk crank, you'd be right there. You could play with tune a lot and different pulleys. Also a cam and you'd be pushing 800 crank hp easy...
I would do it if I had the bank roll... at the warranty anyhow!
Old 10-12-2011, 01:29 PM   #3
cyrusthevirus
thanks for the input
Old 10-12-2011, 01:46 PM   #4
91Z28350
Drives: 2012 GT500 SVTPP 2010 Traverse LTZ
Check out Lingenfelter, Katech or Hennessey. They all have packages over 700 crank hp. The motor is still the lsa, so they are basing their packages on the CTS-V, but I believe it will be similar, if not greater, hp gains.
91Z28350 is offline   Reply With Quote
Old 10-12-2011, 05:21 PM   #5
payne.jeremy82
payne.jeremy82's Avatar
Drives: 2002 Lifted Trailblazer
Lingenfelter has a package based on CTS-V LSA 700+hp that produces 623rwhp
700 +BHP *
Package Includes:
-Engine removal & removal of supercharger assembly, cylinder heads, camshaft
-Lingenfelter CNC porting & polishing of LSA cylinder heads for optimal flow
-2.165" diameter hollow stem intake valves
-1.59" diameter high temperature inconnel exhaust valves
-Lingenfelter multi-angle valve job, cc chambers, surfacing & spring height adjustment
-Competition Cams valve springs, titanium retainers, 10 degree locks
-Lingenfelter GT9 camshaft by Competition Cams 215/247.629/.656121CL
-GM Head gaskets & head bolts
-2.55inch diameter steel supercharger drive pulley
-powder coated black
-8rib-8rib serpentine belt
-Lingenfelter LS9 solid supercharger isolator coupling
-Port and polish supercharger snout
-Lingenfelter air intake duct
-K & N Air Filter
-Lingenfelter 10%overdrive harmonic balancer
-63lbs/hour fuel injectors
-Fuel injector connector change
-160degree thermostat
-Professional installation, camshaft degreeing & testing
-Engine testing & expert ECM tuning
-Chassis dyno testing before & after installation
-Excellent drivability, highway mileage not adversely affected
-Lingenfelter certificate of authenticity
-Lingenfelter 2 year/ 24,000 mile warranty
Package price –$11,245.00
this is what my ZL1 be getting along with
Forged shortblock (add) 4485.00
• Water jacket plugs, oil galley & cam bearings
• Manley forged aluminum pistons
• Total Seal Premium file fit rings
• Manley 6.125" I beam connecting rods
• Speed Pro heavy duty rod bearings
• Speed Pro heavy duty main bearings
*shortblock options subject to change in regards to actual ZL1 specifications.
Hotchkis Racepack, with billet sway bar bracket kit (installed)2964.90
BMR trailing arms and toe rods (installed)869.90
payne.jeremy82 is offline   Reply With Quote
Old 10-12-2011, 05:32 PM   #6
91Z28350
OOHH!!! I was wondering how much the forged Shortblock was. I will most likely be going through ADM (since they are 15 minutes down the road), and adding one more item to a very similar setup (obviously if I do it all at once, I won't be getting the supercharger upgrades), a 2.9L Whipple!!
Old 10-12-2011, 05:41 PM   #7
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 944 RWHP/787 RWTQ
Have you talked warranty with ADM? Just curious what he is offering on something like this.
BiggFoot is offline   Reply With Quote
Old 10-12-2011, 05:47 PM   #8
payne.jeremy82
There is one more thing i am on the fence about but i may go ahead with for the loss of weight and proven performance now I am not saying GM doesn't have it figured out but Lingenfelter runs this in there black drag car and I think it runs 9's but I am still undecided
Old 10-12-2011, 06:48 PM   #9
blaSSt
blaSSt's Avatar
Drives: 98 SS, 15 COPO, 09 ZR1
This: http://www.camaro5.com/forums/showthread.php?t=133040
On the internet - Anything is possible, especially when you don't know what you are talking about.
blaSSt is offline   Reply With Quote
Old 10-13-2011, 01:50 PM   #10
Hotchkis
Drives: 1st through 5th gen Camaros
700 +BHP *
Package Includes:
-K & N Air Filter
That's a nice big list to be on! Thanks for posting it!
Hotchkis is offline   Reply With Quote
Old 10-13-2011, 02:21 PM   #11
91Z28350
Wonder how much weight savings there is compared to the big, cast iron pumpkin we have seen on the ZL1?
Old 10-13-2011, 02:26 PM   #12
Black GT
Banned
Drives: 2006 Mustang GT
Originally Posted by blaSSt View Post
This is most likely what most people that want a little more power will end up doing.
looks like a good setup.
Black GT is offline   Reply With Quote
Old 10-13-2011, 02:32 PM   #13
cyrusthevirus
that what i was saying before pulley, cold air, tune and exhaust i believe alot of people will be happy with the outcome!!
Old 10-13-2011, 03:48 PM   #14
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I've seen pulley kits on CTS-V with H/C push up to an alleged 19 psi on the stock 1900. This car also had an I/C upgrade, along with a lid spacer with all bolt-ons. If I remember correctly, this car was close to 650 at the tires. If you want 700 FWHP, with a 15% drivetrain loss (which I think will be closer to 18% for ZL1 because of the beefy driveline), you're going to be looking at a little more than 600 to the tires. If ZL1's rating doesn't change from 580, it should be around 500 to the tires, stock, so getting another 100 RWHP shouldn't be too bad. A consideration should be where you're coming from.
For me, I have to be as stealthy as possible because of emissions. For me, that means CARB-shorties (maybe...), no CAI (may not be completely necessary anyways, though I'm waiting to see if there's something like a Blackwing tube or something like that), and leaving a lot of the OEM exhaust (I'm planning on leaving pretty much all of the exhaust stock except the mufflers which I'll mod' like the 'Vette guys have been doing with their dual-mode mufflers). That means, I really only have pulleys, tuning, and maybe shorties. Given, a super-sharp eye will see the pulleys, but I think I might make it by with some creativity.
I believe LTs, bigger lower pulley, CAI, tune, and maybe a cam should net you close to 600 RWHP pretty easily. More boost is more heat, so maybe look into either an I/C upgrade, Superchiller, meth', or a combination of those for the 1900. Depending on what I find, I might consider a 2300, too... If you don't have to worry about emissions, it will be a lot easier.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Acronyms at C5 hokie2012 5th Gen Camaro SS LS LT General Discussions 34 08-10-2011 04:56 PM
Weight reduction vs power loss? (Removing mufflers) Jason@ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 07-31-2011 09:21 AM
Amp Recommendations? CamaroDreams07 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 55 05-28-2010 11:37 AM
