Solo Performance
Old 10-14-2011, 12:53 AM   #1
vexss2010
vexss2010's Avatar
Drives: 2016 Summit White 2SS
Is a front alignment a must after lowered and new wheels?
Just lowered car and put on 22" wheels..is it highly recommended to get a front alignment done?
vexss2010 is offline   Reply With Quote
Old 10-14-2011, 01:10 AM   #2
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
You need an alignment after lowering, not after wheels.
SUX2BU is offline   Reply With Quote
Old 10-14-2011, 06:38 AM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Old 10-14-2011, 07:52 AM   #4
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
Yes,a four wheel alignment is needed and don't forget to time the bushings.The sooner the better.
Bruce@raymondsperformance is offline   Reply With Quote
Old 10-14-2011, 02:37 PM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
We agree with everyone here, you definitely need to get an alignment done. No need to wear through those tires faster than they Have to.
Old 10-18-2011, 12:20 PM   #6
Hotchkis
Drives: 1st through 5th gen Camaros
vexss2010 - Any time you remove a strut and re-install it, you need to have your car aligned...espeically if you're installing springs that change the ride height.
Hotchkis is offline   Reply With Quote
Old 10-18-2011, 12:41 PM   #7
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
Highly recommended and a must! What springs did you go with?
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 10-21-2011, 06:39 PM   #8
lionssfan
drive it like U stold it
lionssfan's Avatar
Drives: 2010 2ss camaro
Hi Burce bought my suspension parts from you question thanks
what do you mean time the bushings? drive it for awhile? before alignment so it settles? if so how far do you need to drive it? thanks
lionssfan is offline   Reply With Quote
Old 10-23-2011, 10:43 PM   #9
L99CAMA2011
L99CAMA2011's Avatar
Pfadt solid bush no need to time anything .
Old 10-23-2011, 10:48 PM   #10
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
If you don't reset the bushings to the new ride height you can damage the bushings, as well as cause ride/handling issues from the bushings being twisted at ride height. Your ride heights will also be wrong due to the added rebound the bushings are giving.
Pedders Camaro/G8 Bushing Timing Tech Sheet
Info@PeddersUSA.com is offline   Reply With Quote
