Old 10-14-2011, 01:59 PM   #1
pacecarguy
pacecarguy's Avatar
Drives: 2010 Indy 500 Pace Car
WTB: 2011 Camaro SS stock rear diffuser
Looking to buy a take off stock rear diffuser in like new condition to replace my damaged one. Please pm or email with details.
I am located in Macedonia Ohio 44056 to calculate shipping costs.
Thanks.
pacecarguy is offline   Reply With Quote
Old 10-14-2011, 02:54 PM   #2
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
i have mine but it was painted yellow....i'm only about 15 miles from you....if you wanted it painted to match mine is smoothed out already so it might not be much
bmbbl be is offline   Reply With Quote
Old 10-14-2011, 02:59 PM   #3
spenta1
Drives: 2010 Camaro 1SS 2001 Trans Am WS6
i don't know if this is what your looking for but I hope it helps...
http://www.ebay.com/itm/2010-Camaro-...sories&vxp=mtr
spenta1 is offline   Reply With Quote
Old 10-14-2011, 03:14 PM   #4
pacecarguy
pacecarguy's Avatar
Thanks but I Need an Oem unpainted one to put on a pace car so it needs to be original.
Old 10-14-2011, 03:15 PM   #5
pacecarguy
pacecarguy's Avatar
Yes, thanks that is what I need and saw that earlier, the buy it now price is great, but. I think the $72 shipping cost is excessive.
Old 10-14-2011, 03:16 PM   #6
UT-Engineer
Just Cruisin'
UT-Engineer's Avatar
Drives: 2010 Synergy Camaro
Sorry, sold mine not too long ago. FYI the V6 diffuser is the same as the SS. i sold my to a guy with an SS and it fit perfectly. I made him a good deal $60 Plus shipping, so good luck and hope the info helps.
2010 Synergy Green Camaro
25% Tint - CGM Painted GM GFX - 20" Niche M102 Wheels
UT-Engineer is offline   Reply With Quote
Old 10-14-2011, 03:20 PM   #7
pacecarguy
pacecarguy's Avatar
Thanks, just curious do you remember what the shipping cost was approximately? Does it need to go truck or anything oversized due to its size?
Old 10-14-2011, 03:30 PM   #8
UT-Engineer
Just Cruisin'
I shipped it from South Texas to Alabama for about $25 using UPS ground. The diffuser itself is not heavy at all just long. It was def. under 5lbs. You'll pay a little more in cost if you ask them to box it up but you also dont want it to get damaged since they'll probably just throw it in the back of the truck. Some padding or paper will help as well in the shipping process. So under $30 should be right for shipping. A new diffuser runs around $120 or so last i heard (dont quote me). So anything close to that is too much.
Old 10-14-2011, 03:32 PM   #9
2010camarolt
2010camarolt's Avatar
Drives: Victory Red 1LT
the v8 diffuser has a bigger opening for the exhaust tips. dont want you to get burned on a v6 if your putting the car back to orginal
2010camarolt is offline   Reply With Quote
Old 10-14-2011, 03:35 PM   #10
UT-Engineer
Just Cruisin'
I know the exhast pipes are larger on the SS but didnt know if the diffuser exhaust openings were larger as well. The guy i sold my V6 diffuser to installed in on his SS and he said it fit fine. I highly doubt there will be serious issues with this. The plastic is not going to melt.
Old 10-14-2011, 03:51 PM   #11
pacecarguy
pacecarguy's Avatar
Thanks for the shipping estimate and SS vs v6 discussion. I do have Corsa exhaust so the tips are larger than stock.
Another question. Someone told me that when these are removed, they have to bend them to get them off if they don't remove with the bumper fascia off and it leaves a blemish mark in the part that is noticeable. did you encounter this and how bad is it damaged?
Old 10-14-2011, 03:57 PM   #12
UT-Engineer
Just Cruisin'
To be honest im not sure about the blemish marks. I had the dealer remove mine when i installed the GM GFX on mine. I couldnt tell you if they removed the bumper or just the diffuser. I would assume they took off the diffuser without having to remove the whole bumper. There may have been some work to be done to get the diffuser off, or in your case to install it in properly, but I didnt notice any blemishes or scratches on my stock diffuser.
Old 10-14-2011, 11:59 PM   #13
SSTG
SSTG's Avatar
Drives: 2014 Z51 Corvette
http://www.camaro5.com/forums/showthread.php?t=175633
I have mine for sale, lmk if your interested?
SSTG is offline   Reply With Quote
Old 10-15-2011, 03:04 AM   #14
cyberLS
cyberLS's Avatar
Drives: 2010 Cyber Grey LS
the openings are bigger and the "fins" in the middle are bigger. and it is known for the exhaust to melt the plastic. go here http://www.camaro5.com/forums/showth...elted+diffuser
cyberLS is offline   Reply With Quote
September 2011 Exterior specails list at GMPARTSHOUSE.COM patrickt Exterior Parts & Accessories 8 09-28-2011 09:32 PM
Modern Camaro Performance - Lowest Prices Anywhere! PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 11-03-2010 10:50 AM
Im sure this has been asked before.. But forgive my innocence :) gmag21 Suspension / Brakes / Chassis 23 02-21-2010 10:29 PM
Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 338 04-15-2009 05:33 PM
