Grabiak Performance Center
V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters
Old 10-14-2011, 02:55 PM   #1
Oxtar41
Oxtar41's Avatar
Drives: 700 rwhp 2010 SS
2nd gear grind issue and updated GM parts (pics)
Im tired of the 2nd gear issue with my M6 so since I work as a technician at a chevy dealer I decided to pull the trans out of my car, rip it down and see what I can find myself. First off its kind of a pain in the ass to rip that thing down lol. It was my first 6 speed manual that I have pulled apart so I was going by the books making sure I do everything the right way.
Theres like 12 special GM tools you need to use, anyways once inside I found what I think is the issue, which is the blockring rings for 2nd gear. In the pictures you can see the wear on the brass ring, when pressed down on second gear its self the ring still spins, it shouldnt. There is about 10,000 miles on this trans and its the second trans in the car due to 2nd gear grind. I was about to order the new updated carbon rings that everyone has been putting in them from aftermarket companies.
I called a few after market companies and found out they wanted like 500-600 JUST for the new rings. I decided to hold off as its going to be covered by warranty anyways. So I get the parts today for second gear and low and behold they are the CARBON UPDATED rings right from chevy . I talked with the service manager and he gave me the go-ahead to order 1,3,4 rings as they are updated so needless to say that just saved me 500-600 bucks!
I thought id pass this info along with pictures to anyone with second gear issues to print off and that way you can SHOW the service manager at your local dealer that there is infact an updated ring that is supposed to solve some of the 2nd gear issues. Maybe that will persuade them to open the tranny up and replace the rings for you guys! Hope it helps!
Old
Updated
Oxtar41 is offline   Reply With Quote
Old 10-14-2011, 03:59 PM   #2
ponbigi
ponbigi's Avatar
Drives: 2011 CAMARO LS
Wow if there is anyway that you can find something.offical about the rings going to carbon that would be most helpful
ponbigi is offline   Reply With Quote
Old 10-14-2011, 04:57 PM   #3
camarorick
Drives: .
Can you confirm that GM is replacing 1,3,4 rings with carbon ??
I've had my tranny rebuilt already with the 2 gear carbon ring, and now that works like a charm..... 3rd gear still has a little something that's not so right
camarorick is offline   Reply With Quote
Old 10-14-2011, 06:12 PM   #4
Russell James
Russell James's Avatar
Drives: '12 SS/RS LS3 IBM
Any word if the '12s already come with these parts?
Old 10-14-2011, 06:43 PM   #5
Oxtar41
Oxtar41's Avatar
From what the parts guys told me they are updated. I ordered 1,3,4 today so I should know monday morning if they are carbon. Ill keep you guys updated.
Old 10-14-2011, 06:50 PM   #6
camarorick
Drives: .
Thanks !
Old 10-14-2011, 07:02 PM   #7
Mach
Mach's Avatar
Drives: White M6 1LT RS
Can you tell us if the AY6 has updated carbon rings?
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 10-14-2011, 07:07 PM   #8
jesserayjames
jesserayjames's Avatar
Drives: Drives a 2012 IOM 2SS/RS 6M
That's good news, just ordered a 2012 2SS/RS 6M.............
CAMARO 2SS/RS 6M
jesserayjames is offline   Reply With Quote
Old 10-14-2011, 07:10 PM   #9
BlackPlague
BlackPlague's Avatar
Drives: 2010 Camaro 1LT (Prod. #115)
so is this the first step to GM fixing our issue? or are they still going to deny it?
2011 Chevy Camaro 2LT/RS Vert A6 in CGM
-mods pending ;D
2010 Chevy Camaro 1LT 6M, Prod #115, Black W/ Cyber Grey stripes [TRADED]
BlackPlague is offline   Reply With Quote
Old 10-14-2011, 07:15 PM   #10
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: cgm 2LT RS 2010 16847
I want to find out also. Can I get mine fixed if I go to the dealer ?
Airaid,jba,mrtv2,tryfecta,gm bodykit,havock spoiler,razzy splitter,pfad 1.25 drop,blacked out headlights,markers,tail lights,blacked out all bowties,painted engine cover and underhood lighting,Custome underhood bowtie,t rex grill,tinted windows,black side gills,disk brake covers,barton shortthrow,abl (all the way across),footwell lighting,blacked out dash trim and console,zl1 nose soon
chevy 3 is offline   Reply With Quote
Old 10-14-2011, 08:12 PM   #11
2ss-booya
2ss-booya's Avatar
Drives: 2013 ZL1 CRT 6M
Send a message via Skype™ to 2ss-booya
I can't say for sure (because I havent taken the tranny apart)...but I had a 10' ss m6 and I now have a 12' ss m6 and the tranny definitely feels different (For the better)...i have not for once had an issue with 2nd gear like i did with the 10'
2ss-booya is offline   Reply With Quote
Old 10-15-2011, 04:08 PM   #12
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
Great info. Thanks!
I'm getting the 1-2 grind on my '11...
Kilo-9 is offline   Reply With Quote
Old 10-15-2011, 09:33 PM   #13
toasterfires
Drives: BMW 328i
I would be extremely interested in knowing if there might be an update for these in the 2010 V6 AY6 transmission as well. I am on the verge of selling my camaro just to avoid the hassle of dealing with the tranny issues in the future. If there are updated parts that might fix the grinding/binding that would be awesome news.
toasterfires is offline   Reply With Quote
Old 10-15-2011, 09:41 PM   #14
mike25
mike25's Avatar
Drives: 2012 Camaro 2SS/RS
im going to say yes. 2500 miles and not one grind yet.
2LT/RS M6 CGM VIN#53104 SOLD
2012 Black 2SS/RS w/ Hurst-
Mods:
Corsa catback, SSE, Vararam
mike25 is offline   Reply With Quote
Old 10-15-2011, 10:21 PM   #15
pnyklr
Drives: A Gift From My Wife
I am with Mike on this one. I have 3000k miles on my 2012 and the only grind I ever got going from 1st to 2nd was due to operator error. Plus, my service manager has verified that the tranny has been updated for 2012 and the second gear grind should not be an issue.
I just make sure the tranny is up to temp before any 6000 rpm shifts. Works like magic.
Enjoying the ride Mike? Told you it was worth the wait.
-Funk
2012 Convert 2SS/RS SW/IO LS3 - Build #1081
07/21/2011 - (3800) Order produced and vehicle is being prepared for shipping.
08/09/2011 - (4200) Shipped (vehicle is shipped to the dealer or interim point of delivery).
08/16/2011 - (5000) Vehicle has been delivered to dealer.
08/19/2011 - In my possession.
pnyklr is offline   Reply With Quote
Old 10-16-2011, 06:41 AM   #16
IROCanSS
Drives: 89 IROC 350
2010 LS3, I have owned it since August 2009 and have about 28,000 miles. As of late mine sounds like a meat grinder going into second. It seems to have slowly got worse over the past two years, this past summer being pretty bad. I will be contact the dealer soon to get this looked at and the heated seats fixed, and the HVAC update and the PDIM update... I am a little behind
Old 10-16-2011, 02:44 PM   #17
mike25
mike25's Avatar
-Funk
Oh yea. I love it- look forward to driving it each day. Cant wait to do a set of headers though- corsa is very nice, but quieter than other systems ive owned. How about you? Still enjoying it?
Mods:
Old 10-17-2011, 12:26 AM   #18
pnyklr
It rocks and the top has been up probably 400 miles out of the 3000 miles since I got it.
Still have that 3rd gear nibble but I am hoping it will get better when I change the fluid here in the next couple of weeks. Just glad I don't have the 1-2 grind.
-Funk
Old 10-17-2011, 02:07 PM   #19
Russell James
How does the Factory Hurst feel in the '12s?
I'm about to order a '12 and am trying to decide if I want the Hurst option or not. I drove an '11 with a Hurst, and to me it felt notchy. But I'm use to the base shifter in my '10 which is pretty smooth.
Anyone go from a '10 to a '12 with a Hurst? Glad you got the Hurst, or does the shorter throw makes it notchy and buzz 2nd/3rd? I didn't like the '11 I drove at all, but maybe if the '12s have improved blockers/synchros the Hurst might feel better?
Old 10-17-2011, 03:25 PM   #20
qniknam
Member
qniknam's Avatar
Drives: 2012 Camaro ZL1 | 2012 Charger SRT8
What is the TSB number for this?! My car is in the shop and before they turn around and tell me there is nothing wrong. I'd like for them to see it and acknowledge it.
qniknam is offline   Reply With Quote
Old 10-17-2011, 03:59 PM   #21
pnyklr
To my knowledge there has never been a TSB issued.
I can't comment on how the Hurst compares to stock but I like the notchy feel of the factory Hurst. I get a more notchy feeling 2-3.
-Funk
Old 10-17-2011, 04:20 PM   #22
Oxtar41
Oxtar41's Avatar
There is no TSB. I wrote the above so you guys could print the forum page out and bring that to your service advisor. Thats why I supplied the pictures so you can see the difference in the syncros. If needed shoot me a PM and I can give you the updated GM part numbers for the 2nd gear carbon synchro so you can give to your advisors aswell.
Old 10-17-2011, 04:53 PM   #23
OUTATIME
OUTATIME's Avatar
Drives: 2010 IOM 2SS/RS
So you mentioned that the 2nd gear synchro and blocker is updated, but what about gears 1,3 and 4 . . . and 5 and 6 for that matter? I'm having an issue with 5th not engaging as well, unless I double clutch.
OUTATIME is offline   Reply With Quote
Old 10-17-2011, 05:25 PM   #24
Oxtar41
Oxtar41's Avatar
1,3,4,5,6 are not updated. I just found that out today. But what I did was paid the extra 210 bucks and got the carbon rings for 2nd gear x3 since the rings for 1,2,3,4, are all the same size. My cost on the rings is 70 bucks, list is like 120 or so, GM paid for 2nd gear to be fixed and I paid for the other 3. Its alot less then buying aftermarket and its the same thing.
Old 10-17-2011, 08:15 PM   #25
mike25
mike25's Avatar
-Funk
Awesome glad your enjoying it!
Mods:
V6 AY6 M6 2nd Gear Problem - Report Your Issue Here CAMAR0 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1606 10-25-2012 03:18 PM
Those with LT's, RESET your check engine light! TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 107 08-18-2010 01:51 AM
