Solo Performance
Old 10-16-2011, 02:12 PM   #15
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Awesome thread man!
Well done!
Old 10-16-2011, 05:17 PM   #16
techinny
techinny's Avatar
Drives: '12 Silverado 1500, '05 GMC 2500HD
Subscribed!
Had: 2010 SS/RS M6 Hurst STS, Noweeds
techinny is offline   Reply With Quote
Old 10-16-2011, 06:45 PM   #17
el ess A
formerly "el ess X"
el ess A's Avatar
Drives: 2010 & 2013 Camaros
It's just as I thought. You DO need that air bag switch and metal piece.
Simple to get the metal piece off. Drill out the rivets and you're done. You can go get some genuine GM rivets, p/n 92234427 at list price of $5.42 each. Or you could do what I did and go get my rivet gun out of the tool box with a box of short 5mm (3/16") rivets. Yeah, they're aluminum, but they don't cost $10.84 for 2 of them either. Worked just as well IMO. Don't use medium or long ones as you might contact the operating screw in the track.
The switch/bracket itself just unscrews with the one phillips like I said, and screws right into the new seat base. Reminder: goes on the INBOARD track. It should be easy enough.
Anyway, I cut the old blue wire for the switch at the splice in the old harness. Removed the pin from the old main floor plug. Then I spliced the short blue wire into the seat belt blue wire. And then routed the "new" blue wire from the switch to the new main floor plug. Put everything back together and tested. NO MORE AIRBAG WARNING LIGHT!!!
Works like a champ and I am D-O-N-E!! (well, except if I get a notion to replace the inboard mini-hinge cover with the correct one)
So in summary, this isn't exactly plug and play, but almost. You DO NEED the air bag switch. So don't throw away your old harness/seat right away. You'll need some stuff off of it. If GM doesn't have the proper harness, then you need to splice the 2SS heated harness like I did mine. Obviously, if I can help anyone with any further explanations, I'll try my best to help. Again, this is for a 2SS with heated leather. I'm not electrically inclined and I was able to do this, so if you know anything about wiring, it should be no problem.
Top pic shows the plug comparison. The wiring is virtually identical except for that tan wire color was changed and the new harness doesn't have the switch pin.
Second pic shows where to mount the switch and the two rivet holes on the new track.
Last pic is where I completed the air bag switch install. Now the wife is happy.
2010/2013 Camaro
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 10-16-2011, 09:51 PM   #18
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
My wife will be thanking you when I get a spare $600.00.
This should be a sticky...
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 10-16-2011, 09:56 PM   #19
Wantconvertible
Wantconvertible's Avatar
Drives: 2011 SS/RS VERT
I'll be over Saturday so you can do mind
Wantconvertible is offline   Reply With Quote
Old 10-16-2011, 10:10 PM   #20
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Nice work,
Old 10-18-2011, 09:13 PM   #21
Jrichards73
Jrichards73's Avatar
Drives: 2011 2SS/RS Victory Red
No need to rewire on 2011 2ss/rs, that piece you speak of is not on old seat so must have been phased out. I did have to swap the airbag plug though as my old one had a different locating pin in it and new one didn't go into airbag. Otherwise butter and its installed.
Jrichards73 is offline   Reply With Quote
Old 10-18-2011, 09:30 PM   #22
Baldman
EMERALD COAST CAMAROS
Baldman's Avatar
Drives: 2015 Spice Red Metallic 2LTZ Impala
Nice work. As long as the wife is happy that's what's important.
Baldman is offline   Reply With Quote
Old 12-19-2011, 08:09 AM   #23
dajones
Drives: 2011 2LT RS Summit White
Great Project
I completed installing my power passenger seat this weekend. Your write-up made this task straight forward. If any of you are planning to install in your 2011 2LT I have the wiring harness, cover, switch and knob that I will sell as I ordered two of these items. PM and I'll give you a great price.
dajones is offline   Reply With Quote
Old 12-19-2011, 03:05 PM   #24
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS and Twin Turbo'd SRT8
Is there a parts list and is anyone going to offer a kit to do this or least where best price can be had
Old 04-01-2012, 12:18 AM   #25
Rangore
Rangore's Avatar
Drives: 2012 Camaro 2SS 45th Anniversary Ed
Great write up!!
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
Rangore is offline   Reply With Quote
Old 04-01-2012, 01:28 PM   #26
UCI CamaroFan
Zot!
UCI CamaroFan's Avatar
Drives: Toyota 4Runner
I will be doing this when I get some free time. My girlfriend can't see over the dash :(
Thanks for the writeup!
UCI CamaroFan is offline   Reply With Quote
Old 04-02-2012, 05:25 AM   #27
BlackIce1066
Black Ice
BlackIce1066's Avatar
Drives: 2SS/RS Black w/ silver ice stripes
OK a couple of questions please.
1. Are the switchs for the seat controls mounted on the outside or inside of the seat?
or
2. Do you modify the existing outside cover to accept the new switches?
BlackIce1066 is offline   Reply With Quote
Old 04-03-2012, 07:45 PM   #28
el ess A
formerly &quot;el ess X&quot;
el ess A's Avatar
or
The outer cover on the passenger side (you'll need to buy the correct cover- see parts list in the links in original post. P/N 22780755)
IIRC, the existing non-power outer cover doesn't have any clips and such for the new additional seat switch.
2010/2013 Camaro
Creaking Drivers Seat GLBL WMR Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 57 09-19-2013 09:56 PM
Latest Camaro Products - March 2010 Sean@Phastek V8 Bolt-Ons & Tunes 26 08-04-2010 05:42 PM
Squeak from drivers seat or console? klondike Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 22 07-29-2010 04:02 PM
Why aren't there any Aqua Blues yet? txcamarogirl 5th Gen Camaro SS LS LT General Discussions 40 08-20-2009 11:05 AM
No confirmation number? jamesc1123 Camaro Price | Ordering | Tracking | Dealers Discussions 12 02-21-2009 09:49 PM
