Cold Air Inductions
Old 10-15-2011, 10:16 PM   #1
rydahog
rydahog's Avatar
Drives: camaro ss
catch can info.
so i had about 2-5 k on my v6 with out a catch can, some time later, i installed a catch can,,but i never looked into the Cold air tube going into throttle body. This oil change i took out approx 1/2-3/4 inch of old oil, Still not taking the cold air tube apart. This evening i installed a ported TB, and then i noticed it...some OLD oil in curved part of the tube that was apparently dried up from BEFORE i put in catch can. How do i deduce this?, is that there was NO new wet oil in Tube nor inside TB..so in my un-scientific research,i think the catch can is doing its job....... i will keep and eye on this and report back sometime.. after popcorn..
rydahog is offline   Reply With Quote
Old 10-15-2011, 10:43 PM   #2
OOLIE
OOLIE's Avatar
Drives: 2011 LS
I am sorry I was a little confused as to where the oil was exactly. If it is in the clean side (intake tube) the breather should help eliminate that.
OOLIE is offline   Reply With Quote
Old 10-16-2011, 12:41 AM   #3
jeff4946
jeff4946's Avatar
Drives: 2010 RS 2LT
I'm thinking there are more than a couple people who have set these up wrong. I have heard of a few replacing the driver side line instead of eliminating that line, and installing it correctly on the passenger side line.
K&N Cai, BSR Ported intake, MBRP catback, BBK long tubes, VMax throttle body, 3.73 SS gears, Zex nitrous 125hp shot, window switch, purge,remote bottle opener, bottle heater, Trifecta tune, Hurst short throw, RX catch can, Intake isolator, Ported Intake manifold
jeff4946 is offline   Reply With Quote
Old 10-16-2011, 02:04 PM   #4
rydahog
rydahog's Avatar
Drives: camaro ss
This is on pass side, and was installed by tracy sc2150..so i have to think its correct.
Old 10-16-2011, 02:07 PM   #5
rydahog
rydahog's Avatar
Drives: camaro ss
intake tube
it was where the 90 degree elbow from my injen cai just before it goes into TB..but like i said,,this was before i put in catch can, now it appears that this is rectified.))
Old 10-16-2011, 03:41 PM   #6
SC2150
PCV oil separating catch can systems SC2150 V8 Bolt-Ons & Tunes 49 03-10-2016 07:56 PM
Mike Norris Motorsports Billet PCV Oil Catch Can Availability Mike Norris Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 12-04-2011 08:41 AM
Vararam and a Catch Can Ir0nM4n Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 5 07-20-2011 10:19 PM
My RX Catch Can OOLIE Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 16 06-02-2011 01:13 PM
Updated list of Car Shows bamaproshop USA - Southeast 1 02-09-2011 11:03 AM
