Old 10-16-2011, 08:15 PM   #1
1995z28
1995z28's Avatar
Drives: Red 95 Z28
Brake Problems
My Rear brakes for some odd reason make a weird sound not so much like the pads are low more like a squeaking sound of the sort. Also the Parking brake will not let me pull it up. its very stiff and resistant to moving. any help would be much appreciated.
1995z28 is offline   Reply With Quote
Old 10-16-2011, 08:22 PM   #2
dmginc
dmginc's Avatar
Drives: 14 Camaro 1LS AGM
if you know nothing about working on brakes, bring it some place. otherwise, pull rear wheels and have a look. emergency/parking break is cable operated and there can be several reasons for it to not operate. broken cable, something fell down into the brake linkage and is stopping it from moving.
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 10-24-2011, 12:21 AM   #3
1995z28
1995z28's Avatar
Drives: Red 95 Z28
sorry for the late response, im getting it looked into professionally because i cant seem to figure it out but thank you for the help
Old 10-26-2011, 01:47 PM   #4
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
Squeaking can just happen, Ive done at least 30 brake jobs, some squeak, some dont. Dragging is a different story. I was told to take a new or newly turnded rotor and hit it with a sander or grind it lightly cause the grooves play like an old vinyl record. Never tried it lol, Parking brake could be frozen if it wasnt used often. Wd40 all of the parts underneath, let it soak and see if that helps.
Old 11-25-2011, 01:35 AM   #5
cnwalden24@gmail.com
cnwalden24@gmail.com's Avatar
Drives: Black 99 Camaro V6 5 Speed
I just put brand new brakes on my car and they squeak. its just put of it. they sell this lube for it but it dosent work.
cnwalden24@gmail.com is offline   Reply With Quote
Old 11-25-2011, 01:37 PM   #6
ndtguy
^ Me. Things I write ~>
ndtguy's Avatar
Drives: 2010 Camaro SS
Send a message via AIM to ndtguy
If you have semi-metallic pads, every set I've had always squeaks. I've switched to Ceramics and had no issues with squeaking.
As long as the brakes are working correctly and its not a constant squeak from the squealer touching the disk, then I wouldn't sweat it. If the squealer is touching the disk, its time for new pads.
ndtguy
New DD: 2010 Camaro SS L99/A6 - bone stock.
Gone but not forgotten...
- 2001 Camaro SS m6 - SLP lid, free ram-air mod, poly sway bar bushings/end links, BMR springs and bilsteins.
- 1998 Trans Am m6, forged 347, T70;alky-water injection; intercooled, 208/230 .549/.579 121LSA, Moser 12 bolt, 561rwhp/611rwtq.
ndtguy is offline   Reply With Quote
Old 11-25-2011, 04:09 PM   #7
bill2129
Drives: 2085 Trans AM COBRA
I got all new brakes and rotors for 179 on ebay. Been on for a little while now I cant say anything bad about them. drilled and slotted rotors to. Pretty sure this is the ones I got. Buy them if you wanna save money then paying over 300...
http://www.ebay.com/itm/FRONT-REAR-K...item43ab50e54c
bill2129 is offline   Reply With Quote
Old 11-25-2011, 04:10 PM   #8
bill2129
and yeah bad rotors will make a squeak to if its not the brakes
4th gen, brake, z28
2011 2SS/RS Problems: Engine Squealing, Brake Squealing, 1,2 Gear Grind. Please Help. qniknam V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 10-30-2011 11:36 AM
Hawk Performance Brake Pads part HB247Z.575 $85.00 Rogan USA - Florida 2 10-07-2011 01:10 PM
Stainless Works Longtube w/High Flow cats plus Hawk Ceramic Brake Pads Xplosive Performance V8 Bolt-Ons & Tunes 35 09-17-2011 12:03 PM
Hawk, DBA & Goodridge Brake Upgrade Packages from JSC Speed JSC Speed Suspension / Chassis / Brakes 4 08-05-2010 03:29 PM
Brake upgrade 96CAMaro Wheels and Tires Talk Sponsored by The Tire Rack 28 06-03-2009 02:44 PM
