Old 11-18-2011, 06:03 PM   #43
SSTG
SSTG's Avatar
Drives: 2014 Z51 Corvette
Originally Posted by nak3dsnake View Post
Part number for the new insulator is 20859337.
Thank you! I called my Dealer and they did not have a new number for it,which meant they would be installing the original again. He asked me if I could get the new number for him,lol.
SSTG is online now   Reply With Quote
Old 11-18-2011, 07:41 PM   #44
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
The part number did NOT change, the part changed.
Old 11-19-2011, 09:42 PM   #45
SSTG
SSTG's Avatar
Oh, good to know. Thank you!
Old 11-20-2011, 12:13 AM   #46
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
For those still having the popping nose from the front, look at the spring and see if you can see where the powder coating is sraped off. On mine, it showed signs of hitting on the first big coil from the bottom, facing out. With the tire off, it should be staring right at you. The spring itself looked like it moved just a tad clockwise and was just barely hitting on the lower perch. We took the spring off, inspected, and reassembled, making sure everything was lined up. This was on the drivers side. On the passenger side, we looked at it with the wheel off and noticed that it looked like it hadn't moved but the first big coil from the bottom also has signs of scraping on the lower perch. After thinking about it we came to the conclusion that the powerdercoating made the diameter just big enough to hit the perch and make the nose when compressed over bumps. We took a pair of channel locks and slightly bent out the lower perch on both sides, just where it showed signs of hitting. Took it out for a drive and no more popping when going over bumps. That was last week and went over the speed bumps down the road and no sound at all, other than the shock compression swoosh sound. I can't say this is the answer for everyone, but it's what apparently fixed mine.
For the record, mine is a Nov/Dec 09 build with the black upper isolator.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 11-20-2011, 05:36 PM   #47
L99CAMA2011
L99CAMA2011's Avatar
My car for over 23000 miles has never made a noise. Got to be the way some are fitted. Maybe try reinstalling them and grease them with bushing lube perhaps.
Old 11-22-2011, 11:39 PM   #48
JusticePete
Any chance you took some pics?
Old 11-22-2011, 11:53 PM   #49
Sevn86
Sevn86's Avatar
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 11-22-2011, 11:59 PM   #50
RedRocketSS
BSHU
RedRocketSS's Avatar
Drives: 2011 Red Jewel SS
This is interesting. Nobody has been able to tell me why my car makes these popping/clunking noises since I installed the lowering springs.
Maybe I'll order the new isolators if their fairly cheap and see if it helps.
CAI and Ported TB,Loud Pedal Motorsports Tune, Pfadt Lowering Springs, and more.
RedRocketSS is offline   Reply With Quote
Old 11-23-2011, 12:10 AM   #51
JusticePete
Less than $20 for two Chevrolet list price last I checked.
Old 11-23-2011, 12:24 AM   #52
axis
Search Ninja
axis's Avatar
Sorry, no pics. Didn't even think about this thread while we did it. It wasn't anything dramatic though. Just a light scraping of the powdercoat in one area. The "mod" wasn't anything dramatic either. Just a huge pair of channel locks and a very slight bend on the outer lip of the lower perch.
Halltech CF 102 fed
Old 11-23-2011, 11:22 AM   #53
JusticePete
How many miles on your SS?
Do you know the build date?
Old 11-23-2011, 01:47 PM   #54
axis
Search Ninja
axis's Avatar
Just rolled 19k over and it's a Nov/dec 09 build. Not sure of the actual date. It does have the black upper insulator though.
Halltech CF 102 fed
Old 11-23-2011, 02:18 PM   #55
JusticePete
Good info so far. Can you please measure your ride heights at all four wheels? Your Camaro should be as empty as it was new with a 1/4 tank of fuel. It should be resting on the flattest surface you can find. Make sure the suspension is relaxed i.e. the front wheels should not be turned straight with the car not moving We measure rim to guard. Place the end of the tape on the lower rim lip. Measure up through the wheel center to the painted edge of the fender. Measuring in MM is good.
Old 01-28-2012, 09:15 PM   #56
ss/rssleeper
Drives: 2010 Camaro SS2
I had the same issue and all I can tell you is that when I installed Pfadt Adjustable Coilovers, the noise is gone. I got the same response from every dealership I took it to that the "bump" in the right front suspension is "normal" and every 2010 and 2011 Camaro. I don't think any abnormal noise is "normal" and Chevrolet should do a recall. If Chevrolet is saying other wise as in the thread above, then the dealerships are telling "us loyal customers" a different and discouraging message.
ss/rssleeper is offline   Reply With Quote
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
Gap in front suspension nut after springs installed lelzie Suspension / Brakes / Chassis 9 07-11-2011 01:21 PM
Popping sound from front right side BaylorCamaro Suspension / Brakes / Chassis 8 01-12-2011 10:45 PM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 01:56 PM
2010 Camaro SS V8 in Syracuse NY-FREE TRAVEL TO PICKUP Mitsubishi in Syracuse Camaro Price | Ordering | Tracking | Dealers Discussions 0 12-10-2009 04:23 PM
