R1 Concepts
Old 10-18-2011, 04:24 PM   #1
Synergy SATX
Mike and Debbie
Synergy SATX's Avatar
Drives: 2014 Corvette Stingray 3LT Z51
Concerned about tire rub during autocross UPDATED
Take a look at his pic of my wife (and son pondering his date for his full driver's license) as they are pushing our new Pedders suspension. I am concerned about tire rub on the hard corners. Think this is too low of stance for autocross? First pic is hard turn and second is hard slow leading into a turn.
Synergy SATX is offline   Reply With Quote
Old 10-18-2011, 10:21 PM   #2
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
Depends on how much drop you're interested in. I have lowered mine one inch with Eibach springs, and have done quite a few AutoX runs with no issues. If you run sway bars too, it helps level off some of the lean.
So Cal Camaro is offline   Reply With Quote
Old 10-19-2011, 12:10 AM   #3
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Well, looks like you've already put it through its paces on the course. If you don't see any rub marks on the tires, then you should be OK in the future.
But like So Cal says, the stiffer your suspension, the more drop your Camaro can handle.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 10-19-2011, 01:26 PM   #4
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
If you haven't alraedy I would put a set of sway bars on the car from the look of the pics.If you have Adjustable bars on it I would set them stiffer.
Bruce@raymondsperformance is offline   Reply With Quote
Old 10-19-2011, 02:37 PM   #5
Synergy SATX
Mike and Debbie
Pedders solution B. Rear set hard, front normal (older sway bar with only three options). I was told better autocross setting is soft front hard in the back. So I have Xa coilovers and maybe just raise the stance some? Looks like I had some rub after the event.
Old 10-19-2011, 06:20 PM   #6
sting808
Drives: 2010 SS RS
I have the same. SwaybarB, FR=Soft, RR stiff. XA set to 12/10. Running CCW 20x10,20x11.5 using Invo 275/40 & 315/35. Car dropped around 1". Still looks good while address most driveway/curbs. Car has minimal body roll compared to stock.
Front
-1.0* camber (now -1.2*)
6.8* caster
.something toe(can't remember, but near stock)
Rear
0* camber
0* toe
No fender tire rub, but had to fill to 45 psi to address soft sidewalls. Car still understeers. Will be trying softer front and stiffer rear dampening to see if that helps understeer. Last solo course was slalom city.
sting808 is offline   Reply With Quote
Old 10-19-2011, 08:18 PM   #7
What you have sounds good,I would raise the height up slightly to help with the rub then use the shock adjustments to fine tune it.The bar settings sound good for auto crossing.
Old 10-19-2011, 09:41 PM   #8
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
With the OEM tires I don't think you'll have any rubbing issues. When you look in the inner wheel well do you have rubber marks? In terms of your settings that is 100% correct. You want to run it soft in the front and stiffer in the rear. The settings will be dependent on the surface as well as the course but that is the beauty of having a fully adjustable suspension. The picture below is my car loaded on the track and even with the OEM tires tucked I'm not rubbing. If the tire is rolling over it might appear like you have a rub.
Front
6.8* caster
Rear
0* camber
0* toe
I would suggest 8-12 front and 15-20 rear on the damping settings depending on the course and surface; tire compound also plays into these settings as well. I generally run 28-34 PSI depending on the surface with the OEM tires. It looks like you have aftermarket wheels and tires, what are you running?
I would also run the following alignment settings:
Front
-1.2* to -1.5* camber
-1/16" - 1/8" toe-in
7.5* to 8.5* caster
Rear
-.8* to -1.0* camber
0 to -1/16" toe-in
These setting will help your tire roll over issue and you'll have better overall corner grip. You have to be careful with rear camber as too much will affect the ability to put power down. Please feel free to call, email or PM me anytime with questions.
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 10-20-2011, 12:03 PM   #9
Synergy SATX
Mike and Debbie
I am a novice at the suspension AND autocross thing so I appreciate all the feedback and patience. I was set 20/24 for the autocross. Stock tires/wheels (wheels are black chromed so they look a little different). I use the car as a daily driver as well so will any of these camber/ caster/ toe adjustments affect the daily driver driving?
Old 11-13-2011, 09:34 PM   #10
Synergy SATX
Mike and Debbie
Update. All is well. Very very well. Proof here. Thank you all for the help and advice.
Old 11-13-2011, 10:11 PM   #11
Li0nel1234
What should I name my car
Li0nel1234's Avatar
Drives: 2010 Camaro 2SS RS IOM
Send a message via AIM to Li0nel1234
Awesome vids... I just found out Youtube has an IN BROWSER video editor... I edited my vid here...
I'm going to have to do a shot from behind the wheel... after I get a few runs in... haha my first run was terrible.
Anyways, it was fun to see you all out there. See you sunday at HH.
Performance: ARH 2"/"3 headers + ARH 3" HF catback system, SS brake lines, hawk HP+ pads, motul RBF 600 fluid, K&N CAI (w/custom insulation), plug wires, air scoop, Hurst STS, Pedders Track II suspension, 18x10 wheels, 295/45/18 Nitto NT05s
Looks: powder coated iom calipers, LED foglights w/ always on harness, custom painted bowties, window tint, smoke tinted tail lights etc, oem gfx w/ custom outlets, painted taillight bezels, all weather trunk mat
Li0nel1234 is offline   Reply With Quote
Old 11-13-2011, 10:41 PM   #12
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
Is it actually Rubbing? Or are you just worried that it might?
Info@PeddersUSA.com is offline   Reply With Quote
Old 11-13-2011, 10:57 PM   #13
ddunerider
So-Cal Race team!!
ddunerider's Avatar
Drives: Tahoe LTZ,2010 2SS/M6 Camaro
Send a message via AIM to ddunerider
I have Hotchkis stuff and running 275 tire up front and have no rubbing ..as well as the 315 in the back nothing rubs..
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!!
ddunerider is offline   Reply With Quote
Old 11-14-2011, 09:50 AM   #14
JDP Motorsports
Sweet!!!
Kind regards,
Jordan Priestley
888.308.6007
NEW OEM GM tire pressure monitors availabe at GMPARTSHOUSE.COM patrickt Wheels / Tires 76 08-08-2012 09:35 PM
Tire pressure computer issue UT-Engineer Wheels and Tires Talk Sponsored by The Tire Rack 7 02-13-2012 06:18 PM
Reccomendation on Road coarse/Autocross Tires michael's maro Wheels and Tires Talk Sponsored by The Tire Rack 21 09-06-2010 05:52 PM
Exhaust bolt in tire = bad day GPD151 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 07-29-2010 11:56 PM
WHAT A NIGHTMARE!!! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 110 09-27-2009 11:25 AM
