Solo Performance
Old 10-18-2011, 06:18 PM   #1
alab32
alab32's Avatar
Drives: 2010 Camaro 2SS/RS
315's and a drop?
Well, I have TSW Nurburgring rims with a 275/315 setup. That being said, is it possible to go with a 1.5 in drop without rubbing on bumps and aggressive turns? When I look at the car I feel like it would rub, but I would like to see who may have the answer from personal experience. If it is as close as I think it is, should I wait to get a suspension until it is time to change the rubber then go to a 305? Thanks for the help.
Ill take my GUNS, FREEDOMS and MONEY... you can keep the "change"
alab32 is offline   Reply With Quote
Old 10-18-2011, 06:26 PM   #2
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
I have theTSW Nurburgrings also. I think that would be close. I have looked and considered the same thing, but was thinking of doing a 305. I love my TSW's, but because of this I wish I would have went with a wheel with a better offset. I just feel like these wheels limit you so much unless you are sticking with the stock tire size. By the way... do you have any pics you could post of your wheels with the 315's? Do you have a 10 inch wheel in the rear?
newagemuscle is offline   Reply With Quote
Old 10-18-2011, 06:32 PM   #3
alab32
alab32's Avatar
I do have a 10 in wheel in the rear and I have some pics but I am out of the country without my computer at the moment. I will post them right here when I get home. I have been thinking about selling my rims for the reasons you mentioned as well as others. We shall see how it works out.
Old 10-18-2011, 06:50 PM   #4
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
I am very interested in this also! I would like to go with the 10" Nurburgrings but I want to be able to use a 315 rear tire like the Nitto Invo's! There's one vendor here who sells that setup but everyone else says it's a no no! The recommended rim for 315's is 11" with 10.5 being minimum!
Not a Camaro but it works for now!
Old 10-18-2011, 06:52 PM   #5
Mr.Maro23
Mr.Maro23's Avatar
Drives: 2010 2lt chevy camaro
those are some bad ass wheels let me tell ya and damn sure expensive!!!
Mr.Maro23 is offline   Reply With Quote
Old 10-18-2011, 07:01 PM   #6
alab32
alab32's Avatar
Originally Posted by ssmike View Post
I am very interested in this also! I would like to go with the 10" Nurburgrings but I want to be able to use a 315 rear tire like the Nitto Invo's! There's one vendor here who sells that setup but everyone else says it's a no no! The recommended rim for 315's is 11 with 10.5 being minimum!
The tires fit rather well on the rim even though it is recommended to have at least a 10.5. I was told the Nitto run a bit smaller so it isnt as bad, however I have the Conti DWS tires on mine. I have ZERO issues with mine, however the drop is a bit nerve racking to think about.
The wheels are actually decently inexpensive compared to a lot of others. But I am glad you like them!
Old 10-18-2011, 08:02 PM   #7
ssmike
Missing Big Red
ssmike's Avatar
Let me know if you decide to sell them! Are they matte black?
Old 10-18-2011, 08:35 PM   #8
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
i have 10.8 in rear on nitto 315 and they fit great with pfadt drop kit..
Whipped416 is offline   Reply With Quote
Old 10-18-2011, 08:42 PM   #9
summitss/rsls3
summitss/rsls3's Avatar
Drives: summit white/IOM ss/rs ls3
i have the same wheels with nitto nt05r's and pfadt springs and i have no issues.
_____________________________________
2010 Summit White w/IOM stripes SS/RS LS3, Pfadt spings, Richmond 4.11 gears, GTO clutch reservoir mod.,MGW shifter with retro handle, TSW Nurgurgring wheels, Nitto NT05R 315/35R20 on rear, Kooks 1 7/8 LT's no cats, Stainless works retro chambered catback, Cold Air Inductions CAI, Texas Speed UD pulley, LG G6x3 cam, PRC dual valvesprings w/titanium seats and retainers, Texas Speed 7.4" hardened push rods, Lethal Ported Fast LSXr 102, Ported stock TB, RX catchcan. Tuned by Dan at Dynosport in Lincoln, NE 483RWHP/442RWTQ SAE corrected.
summitss/rsls3 is offline   Reply With Quote
Old 10-18-2011, 10:01 PM   #10
alab32
alab32's Avatar
Will do. They are considered Matte Gunmetal. However, they look black which is one of the other reasons I am thinking about selling them. I was hoping for a bit more gunmetal to match my stripes.
Sounds good! Thanks!
Even better since you have the same rims! Awesome! Thank you much.
Old 10-18-2011, 10:04 PM   #11
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
My buddy has a 1" drop and his running 315's on the back and if I remember correctly on hard bumps he said that the Tires do rub on the wheel wel. but his tires stick out a bit on the side. maybe that could be the reason that his tires rub on the wheel wel.
Old 10-18-2011, 10:18 PM   #12
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
I have a 1" drop, running 20 x 11 wheels, with 315's Pirelli PZero Rosso's and they will rub if you hit a big bump, especially if the car is loaded down at all. I'm not sure I would go any lower with than 1" with 315's.
So Cal Camaro is offline   Reply With Quote
Old 10-18-2011, 10:21 PM   #13
GEEo
OKCamaros
GEEo's Avatar
I think theres a member here (SUX2BU) running 315's on the back with a 1.4" drop. and his pretty knowledgeable with Wheels and Tire fitments.
He'll be here soon. he could answer you questions.
Old 10-18-2011, 10:29 PM   #14
So Cal Camaro
So Cal Race Team
Drives: 2013 Camaro
Tires make a difference too, 315 Nitto's are smaller than the 315 Pirelli's I have, so shouldn't have an issue with Invo's and a wheel with the correct offset.
Nitto NT05R 315/35/20 on stock wheels 95RedCamaroz28 Wheels and Tires Talk Sponsored by The Tire Rack 86 07-06-2012 08:13 PM
Nitto Invo 315's on 10" wheel ssmike Wheels and Tires Talk Sponsored by The Tire Rack 24 10-21-2011 01:16 PM
Deleted InvaderMoose Wheels and Tires Talk Sponsored by The Tire Rack 5 06-13-2011 12:19 PM
stock wheels stretched to 11'' with 315's barnesql Wheels and Tires Talk Sponsored by The Tire Rack 4 05-04-2011 09:16 PM
Anyone have pics of 315's mounted on 10 inch rims? newagemuscle Wheels and Tires Talk Sponsored by The Tire Rack 2 12-18-2010 03:15 PM
