Caryle Racing
Old 05-10-2011, 04:13 PM   #1
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
The mighty LSA supercharged V8
Overview
Model: Chevrolet Camaro ZL1
Body style / driveline:
four-passenger, front-engine, rear-drive coupe
Construction:
unitized body frame, one- and two-sided galvanized steel
EPA vehicle class:
coupe
Manufacturing location:
Oshawa, Ontario, Canada
Key competitors:
Ford Mustang Shelby GT500
Engines
LSA 6.2L Supercharged V-8
Displacement (cu in / cc):
376 / 6162
Bore & stroke (in / mm):
4.06 / 103.25 x 3.62 / 92 mm
Block material:
cast aluminum
Cylinder head material:
cast aluminum
Valvetrain:
overhead valve, two valves per cylinder
Fuel delivery:
1.9L supercharger with intercooler; sequential fuel injection
Compression ratio:
9.1:1
Horsepower
(hp / kW @ rpm):
580 / 410 @ 6100 (estimated)
Torque
(lb-ft / Nm @ rpm):
556 / 745 @ 3800 (estimated)
Recommended fuel:
premium required
Maximum engine speed (rpm):
6200
Transmission
Tremec TR6060 six-speed manual
Gear ratios (:1):
First:
2.66
Second:
1.78
Third:
1.30
Fourth:
1.00
Fifth:
0.80
Sixth:
0.63
Reverse:
2.90
Final drive ratio:
3.73
Chassis / Suspension
Front: double-ball-joint, multi-link strut; direct-acting stabilizer bar; progressive-rate coil springs; with Magnetic Ride Control
Rear:
4.5-link independent; progressive-rate coil springs over shocks; stabilizer bar; with Magnetic Ride Control
Steering type:
electric power steering with variable-ratio, variable-effort rack-and-pinion
Steering ratio:
16.1:1
Steering wheel turns, lock-to-lock:
2.5
Turning circle, curb-to-curb
(ft / m):
37.7/11.5
Brakes
Type: four-wheel disc w/ ABS; ventilated two-piece front and one-piece rear rotors; six-piston fixed Brembo aluminum front and four-piston rear calipers
Rotor diameter, front (in / mm):
14.6 / 370
Rotor diameter, rear (in / mm):
14.4 / 365
Rotor thickness, front (in / mm):
1.26 / 32
Rotor thickness, rear (in / mm):
1.1 / 28
Wheels / Tires
Wheel size and type: 20 x 10-inch aluminum (front)
20 x 11-inch aluminum (rear)
Tires:
P285/35ZR20 summer (front)
P305/35ZR20 summer (rear)
Dimensions
Exterior
Wheelbase (in / mm): 112.3 / 2852
Overall length (in / mm):
190.4 / 4836
Overall width (in / mm):
75.5 / 1918
Overall height (in / mm):
54.2 / 1376
Track, front (in / mm):
63.7 / 1618
Track, rear (in / mm):
63.7 / 1618
Curb weight (lb / kg):
TBD
Weight balance (% front / rear):
TBD
Coefficient of drag:
TBD
Interior
Seating capacity (front / rear): 2 / 2
Headroom (in / mm):
front: 37.4 / 950
rear: 35.3 / 897
Legroom (in / mm):
front: 42.4 / 1077
rear: 29.9 / 757
Shoulder room (in / mm):
front: 56.9 / 1444
rear: 42.5 / 1080
Capacities
Cargo volume (cu ft / L): 11.3 / 320
Fuel tank (gal / L):
19 / 71.9
Engine oil (qt / L):
8.9 / 8.5
Milk 1027 is offline
Old 05-11-2011, 01:27 PM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Thanks Milk'. I gotta' get in here and make some additions. Theses, among the others, will be a great addition , I believe.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
radz28 is offline
Old 05-17-2011, 11:25 AM   #3
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
It looks like the ZL1 will have taller 3.73 gears.
Old 05-17-2011, 02:14 PM   #4
JEFF2010SSMANUAL
JEFF2010SSMANUAL
JEFF2010SSMANUAL's Avatar
Drives: IOM 2SS/RS LS3
Thats what it needs. When the Camaro SS was compared to the new 5.0 Mustang it should have 3.73:1 gears. The GT does. 0-60 would probably be the same then. With a 3.45:1 rear in the Camaro SS take-off is slower.
JEFF2010SSMANUAL is offline
Shno's House of Z Number 3 Camaro Z/28 Forum - Z/28 Specific Topics 17553 02-12-2018 03:59 PM
Magnaflow Axle-Back | 2010+ Camaro V8 | 2.5" Loud w/ 5" Tips | 2.5" System w/ 4" Tips AutoAgenda V8 Bolt-Ons & Tunes 20 03-01-2012 11:43 AM
MagnaFlow Cat-Backs | 2010+ Camaro V8 | 2.5" w/ 4" or 5" Tips | Full 3" System w/ 4" AutoAgenda V8 Bolt-Ons & Tunes 15 02-29-2012 11:35 AM
V6'ers do u regret not getting the V8? GreenMonster 5th Gen Camaro SS LS LT General Discussions 85 05-11-2010 11:17 PM
All this LS9, LSA, and DI Speculation. Good53X Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 12-12-2007 03:42 PM
