SDPC
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 4th Generation Camaros > 4th Gen Marketplace
Old 10-19-2011, 03:52 PM   #1
MTI Racing Kevin
MTI Racing Kevin's Avatar
Drives: 2010 Camaro
MTI Racing F-Body Supercharger Install
Check out this awesome 2001 convertible F-Body Camaro. This Camaro comes to us from Canada for an MTI Racing F-Body supercharger[/URL], camshaft[/URL], Stainless Works Header system and some routine maintenance.
The supercharger kit is based on the Magnuson MP112 [/URL]supercharger with 8 lbs of boost mounted on a specially made intake manifold to fit the LS-Based F-Body Camaro. The supercharger system utilizes a 90mm throttle body and spacers to lower the K member for hood clearance, an SS hood or Ram Air Hood must also be used. We also installed an MTI Racing custom grind camshaft [/URL]with matching valve springs to make some more power. To top everything off we installed a set of Stainless Works headers [/URL]to make sure the F-Body Beast can breath properly. This F-Body now has 473hp and 445ftlbs of torque at the rear tire. With that kind of power you will definitely have some drop top fun.
MTI Racing Kevin is offline   Reply With Quote
Old 05-14-2013, 08:13 PM   #2
Chevrolade
Drives: 2010 2SS/RS
Where can I get that adapter for the throttlebody
Chevrolade is offline   Reply With Quote
Old 05-15-2013, 12:18 AM   #3
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
They won't sell it without the entire kit. I tried.
2010 IOM Camaro 2SS/RS manual trans (Sold)
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 05-15-2013, 04:20 PM   #4
insidethreat07
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
I wish they did this with a V6 lol
2001 Camaro V6
2016 Camaro 2SS
insidethreat07 is offline   Reply With Quote
Old 05-15-2013, 09:03 PM   #5
73camarolt
73camarolt's Avatar
Drives: 2002 Camaro SS
Did they have to trim part of the cowl??
2002 Camaro SS- BTR Stage 3, 799 Heads, Bolt on's Tuned by John at Broadview Automotive.. 420hp and 400tq
73camarolt is offline   Reply With Quote
Old 05-15-2013, 09:31 PM   #6
yotaman96
yotaman96's Avatar
Yes, and lower the k-member. I didn't trim much on mine. I hammered a lot of it in where others cut it out.
Old 05-22-2013, 01:05 PM   #7
Chevrolade
Drives: 2010 2SS/RS
I'm fixing to install one on my 02 z28
Where did y'all mount the heat exchanger inter cooler?
Old 05-22-2013, 02:56 PM   #8
yotaman96
yotaman96's Avatar
It goes in front of the AC condenser.
MTI Racing Black Supercharger 'til Black Friday Deal MTI Racing Forced Induction 2 11-25-2010 11:19 PM
Unbeatble Prices on ACT / Fidanza / Hurst / Mishimoto / MTI / SLP / Spec / More maperformance Transmission / Driveline 18 10-26-2010 03:16 PM
589RWHP Daily Driver by MTI Racing MTI Racing Kevin 5th Gen Camaro SS LS LT General Discussions 10 04-14-2010 10:08 AM
MTI Racing FREE V6 Shifter Install MTI Racing Kevin V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 02-09-2010 02:53 PM
New Edition to MTI Racing "Six Shooter Shifter" MTI Racing V8 Bolt-Ons & Tunes 0 09-17-2009 02:31 PM
