Elite Engineering
Camaro V6 LLT Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 10-19-2011, 06:33 PM   #1
DREV LSX
DREV LSX's Avatar
Drives: Its the Millenium Falcon
V6 VMAX CNC TB Removal/Installation
Hey ladies and gentlemen, we are very glad to see that the Camaro5 members have had great success with the VMAX CNC Ported Throttle Bodies that myself and other vendors have been selling for years to all the other GM vehicles. On the V8's they have been delivering great results in overall driveability and performance. And now on the V6's it has been nothing short of the same results in performance and driveability. We get a lot of calls from our V6 clients that have purchased their VMAX CNC TBs and wanted to tackle this mod on their own but were not sure in their mechanical aptitude. We have put together a step by step procedure with pics for those that need a reference. Its very easy and most will probably be able to complete it in about 30 minutes or less. We hope you enjoy it and it helps out.
1. Start of by disconnecting the battery. This will eliminate the possibility of setting off a code. (Service Engine Soon light, Service Stabilitrak, etc....) Then remove the oil filler cap and lift off the intake manifold plastic engine cover. Once you remove the engine cover, put back the oil filler cap to prevent anything from dropping into the engine that shouldn't.
2. This is what you should see. Next remove your intake tube from the throttle body.You will need a small 1/4" drive ratchet and a small extension with an 8mm socket to loosen the hose clamp at the TB inlet and at the air cleaner or airbox if you have the stock intake. This particular Camaro has an aftermarket CAI and removes the same way.
3. This is what should be staring back at you. The stock TB. You will need to disconnect the harness that is connected to the TAC (Throttle Actuated Control) harness. GM's fancy term for the electronic throttle body harness on the throttle body. See step 4. some will have a white or grey retainer on the connector. This one did not have one. If it has one use a small screwdriver or a tip of a pen or scribe to push it and slide it out.
4. Squeeze the middle of the connector and slide it out of the harness.
5. Now you will need a 10mm socket attached to your ratchet or extension. You are going to remove 4 total 10mm bolts that hold the Throttle body and the metal gasket. One of those bolts, the lower left one on the TB holds the bracket on the TB harness. Between the TB and the intake manifold mounting flange is where the metal gasket is. You will see it in step 6.
6. Once removed, place it on your workbench or table. Be careful not to drop it or you can damage the connector out back or crack the plastic motor case. If you do, remember YOU WILL LOOSE YOUR CORE DEPOSIT. We cannot accept a damaged TB connector. We cannot use it in the core exchange to a fellow Camaro5 member if it is damaged. This is the policy of our supplier and all the other vendors that sell the VMAX CNC Ported TBs. You can see the metal gasket that goes between the TB and the Intake manifold mounting flange. You can also see the TAC/Throttle body control harness. It comes with the TB when you remove it. Below is what your connector at the TB should look like and when we receive it, it should look like this.
Make sure it looks like this guys. No cracked or broken or missing connector guides. We just want to make sure that all other clients get a working part. Remember that you would not want to receive a broken or inoperational part for your car.
7. Now turn the stock TB over and you are ready to remove the TB harness from this TB and to be reconnected onto your new VMAX CNC Ported Throttle Body. Use a small pocket screwdriver or the tip of a pen to push down on the retainment clip and use your other hand's fingers to slide out the clip like you see below.
8. Once you slide the clip out, squeeze the center of the connector and remove the harness from the TB. It is now ready to be installed on the VMAX CNC Ported Throttle Body.
I personally like to add a little dielectric grease to my electrical connectors. It is not a necessity, but chance favors the prepared mind!!! It protects electrical connections from moisture and corrosion between the connections and promotes better conductivity between the circuits. You are ready to connect your harness to your VMAX CNC Ported TB.
9. Here it is!!! If it doesn't say VMAX CNC and Serialized, its not the real deal!!! Now you connect your harness to the VMAX CNC Ported TB and reinstall the retainment clip. Just slide it back in and it should click in place and look like the picture.
10. Here is the VMAX CNC Ported Throttle Body with the harness and the metal gasket ready for installation. Install 2 of the 10mm bolts and put them through the two upper holes on the TB and screw them in to the gasket to help hold it when you install the TB on the intake manifold like you see in the picture below.
It should look like this ready to install on the intake manifold without worrying about the gasket falling off during installation.
11. Once you have lined up the 2 top 10mm bolts on the TB that are also holding your metal gasket, run them in by hand. On the lower left hand of the TB is the harness you first disconnected from the harness on the TB. It has a bracket that needs to be held in place by the 10mm bolt that goes in to TB.
12. After starting all 4 10mm bolts, tighten them down with your ratchet. Do not "Gorilla them down", they only require 89in.lbs of torque or 7ft.lbs of torque. If you dont have a torque wrench just snug them down. Don't trust your "calibrated" elbow. You can overtorque and break something.
12. Now connect the harness to the TB harness. As you can see I added some dielectric grease to the connector.
13. Now reinstall your intake elbow and tighten hose clamps.
14. Remove now your oil filler cap and reinstall your engine cover and reinstall your oil filler cap. Reconnect your battery and you are now done. Time to fire it up and go for a ride and feel the difference from your stock TB to the VMAX CNC Ported Throttle Body!!!
We hope that this will help a lot of you DIYers out there. Have fun and thank you for all your support of VMAX and myself and the other vendors that carry the VMAX CNC TBs and Ported Intakes!!! Very special thanks to Blacktip for his time and his super clean Camaro that made this write up possible. Thanks man!!!
DREV LSX is offline   Reply With Quote
Old 10-19-2011, 07:28 PM   #2
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
Great thread! Very well done!
What about disconnecting the battery before installation? I've heard some people having issues with CELs doing this install.
ChadG is offline   Reply With Quote
Old 10-19-2011, 09:34 PM   #3
Elykson
Custom One Off
Elykson's Avatar
Drives: 2010 Chicago Blackhawks Edition #1
Thanks for the DIY write up. Hopefully I'll get mine Friday. It's going on right away!
Vararam Intake/SLP Loud Mouth II/BBK LT HFC/Magnaflow x-pipe/Pfadt Springs/Black Ice-olator/FE3 suspension/VMAX TB/RX catch can/Trifecta Tune
http://www.camaro5.com/forums/showthread.php?t=129416
Elykson is offline   Reply With Quote
Old 10-19-2011, 10:01 PM   #4
cyberLS
cyberLS's Avatar
Drives: 2010 Cyber Grey LS
getting mine tomorrow.
cyberLS is online now   Reply With Quote
Old 10-19-2011, 10:28 PM   #5
DREV LSX
DREV LSX's Avatar
Thank you Chad. I didn't want to be too detailed, but I wanted to make sure all levels of skills would benefit from it.
I dont disconnect the battery, although its a good idea to do so. In the shop we have the Tech 2, HP Tuners, and Snap On Modis so clearing codes is not an issue. But for the average owner that does not have access to these tools, disconnecting the battery is a good idea.
Old 10-19-2011, 10:30 PM   #6
DREV LSX
DREV LSX's Avatar
You are very welcome! I sent out about 9 TBs so chances are one of those is headed to you.
Old 10-19-2011, 10:32 PM   #7
DREV LSX
DREV LSX's Avatar
Thats awesome! Please let us know what you think of it!!!
Old 10-20-2011, 12:02 AM   #8
kenkartasasmita
COTW [4/23/12]
kenkartasasmita's Avatar
Drives: Camaro Of The Week.
where did u buy the TB?
kenkartasasmita is offline   Reply With Quote
Old 10-20-2011, 12:25 AM   #9
Blacc Mamba
SoCal HT5
Blacc Mamba's Avatar
Drives: 2010 Camaro
Great, thanks for write up, mine should be here for the weekend
Mods: Brembo Brakes/ Pedders Street 1/ Cold Air Inductions CAI/ Vmax CNC TB/ ZL1 Fascia
Blacc Mamba is offline   Reply With Quote
Old 10-20-2011, 01:36 AM   #10
DREV LSX
DREV LSX's Avatar
We sell them. Contact us.
Old 10-20-2011, 01:40 AM   #11
DREV LSX
DREV LSX's Avatar
You are very welcome Mamba! you should have it for the weekend.
Old 10-20-2011, 01:56 AM   #12
11 Camaro IBM
Drives: Camaro IBM
Great! Getting mine tnrw after I take the car into chevy for warranty work if anythings wrong might as well get it out of the way before I mod more
11 Camaro IBM is offline   Reply With Quote
Old 10-20-2011, 06:15 AM   #13
Blacktip
Blacktip's Avatar
Drives: 2011 1LT Silver RS package
Nice write-up Johnny ...This mod is awesome. The car feels better and better.
The guys at D Revolution provide excellent service, and support. along with great products.
.....Well alright,alright..didn't know it was this kind of party
Blacktip is offline   Reply With Quote
Old 10-20-2011, 08:00 AM   #14
DREV LSX
DREV LSX's Avatar
Thanks a lot bud, I couldn't of done it without you. Car feels like a whole different monster!!! cool.
Old 10-20-2011, 05:33 PM   #15
DREV LSX
DREV LSX's Avatar
They picked it up from us. PM us to order one.
Old 10-20-2011, 07:03 PM   #16
11 Camaro IBM
Drives: Camaro IBM
Installed the Throttle body from Johnny feels like a whole new car! Love it great product easy install and great service. Thanks DREV LSX
Old 10-21-2011, 06:05 PM   #17
Blacc Mamba
SoCal HT5
Drives: 2010 Camaro
Got mine on in about 15 min, great addition. I sent the core to the address in package, should be there by monday. Props to you guys
Old 10-22-2011, 09:14 AM   #18
DREV LSX
DREV LSX's Avatar
Thanks bud! We are glad that you guys are very happy with the VMAX CNC Ported TBs!!!
Old 10-25-2011, 08:23 AM   #19
DREV LSX
DREV LSX's Avatar
You are very welcome bud!!! Glad you are happy with it and that you had a good experience installing it.
Old 10-26-2011, 05:54 PM   #20
jmiele
jmiele's Avatar
Drives: RIP
If one does this without removing the battery and the CEL shows up along with Service Stabilitrak how does one go about clearing this?
jmiele is offline   Reply With Quote
Old 10-27-2011, 03:15 PM   #21
Saint Alban
Saint Alban's Avatar
Drives: '10 Black V6 2LT RS
Send a message via AIM to Saint Alban
Did you install this and get a CEL? I have been considering doing this mod, but I'm worried about getting a CEL all the time like when I had a K&N cold air intake for it giving "too much air" to my engine. Now I have a Vararam. Thinking I may be going too far with the TB.
Saint Alban is offline   Reply With Quote
Old 10-27-2011, 07:16 PM   #22
Blacc Mamba
SoCal HT5
Drives: 2010 Camaro
Did you guys ever receive my core
Old 10-28-2011, 08:40 AM   #23
jmiele
jmiele's Avatar
Drives: RIP
Yeah I got a CEL and the Service Stabilitrak. Disconnected battery over night and it's gone.
Old 10-28-2011, 11:40 AM   #24
mypuppysirius
mypuppysirius's Avatar
Drives: 2011 Cyber Grey V6
This is an awesome write up. Now come the stupid question from a new guy who just got his first "fun" car and wants to get into all this....
haha, k. Can you describe what the VMAX CNC TB will do for our cars? Gains? purpose? What's different from the stock one?
It is the TB so i'm assuming that it will help with peddle response, but more details about how this will benefit us would be awesome.
Thanks again for the write up and your time.
mypuppysirius is offline   Reply With Quote
Old 10-29-2011, 09:17 AM   #25
DREV LSX
DREV LSX's Avatar
My father once told me that the only stupid question there is, is the one not asked. lol.......
So you want to know what makes the VMAX CNC Ported Throttle Body what it will do for your car? Gains? Purpose?
First, it improves your throttle response and eliminates that "dead spot" in the throttle during accelaration. Also improving the overall driveability of the car.
Second, you pick up on the average between 6-8 RWHP and between 8-12 RWTQ. After the CNC porting airflow is increased, and the engine can use it to increase TQ and HP.
Third, The purpose of this Mod. To GO FAST!!!! The stock TB is cut on the CNC machine and smoothed to improve accelaration of the incoming air and to keep its velocity to give you that crisp clean tip in throttle response.
I hope this answered all your questions. No go out and get one for your Camaro!!! You are very welcome for the write up. We hope that it helps all the DIYers on this forum.
cnc ported tb
V6 CNC spiral port Throttle Bodies!! SC2150 V6 Bolt-Ons & Tunes 185 04-19-2013 05:19 PM
VMax CNC Throttle Bodies For V6 LLT Available @ Norris Motorsports Mike Norris Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 96 01-05-2011 12:23 AM
Norris Motorsports VMax CNC TB Testing Results - Free Shipping for C5 Forum Members Mike Norris V8 Bolt-Ons & Tunes 27 11-01-2010 06:37 PM
VMax CNC Throttle Bodies For V6 LLT Available @ Norris Motorsports - Free Shipping Mike Norris V6 Bolt-Ons & Tunes 4 09-27-2010 07:08 PM
Norris Motorsports Now A Sponsor - Check Out Our PCV Oil Catch Cans and VMax CNC TB's Mike Norris V8 Bolt-Ons & Tunes 4 09-08-2010 06:03 AM
