10-19-2011, 10:31 PM | #1 |
Drives: 2011 Camaro Join Date: Apr 2011
cai inc installed...loss of mpg
So I installed my Cai inc intake and I've lost about 1 mpg. I was right at 15.5 and after I reset it with the intake install I'm at 14.2. Any suggestions on why this would happen. Also no i havent been stomping on it to hear that great rumble if anything I drive it nicer bc i wanted to see if there was an mpg difference. Also it says to pull the tube away from the throttle body slightly. How close is to close I pulled it off a little bit but not to far. Is tbe any harm in it being to close
10-20-2011, 06:48 AM | #2 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
I've seen where vendors claim more mpg but I would like for someone to explain that to me. More air requires more fuel to make more power, which is what a cai is all about. Not sure how burning more fuel is going to increase mileage. If this were the case wouldn't these be OEM to start with? I've never checked my mileage but I would expect it to be worse. If you're only losing 1mpg i think that would be normal. Never heard about moving the tube around.
10-20-2011, 06:55 AM | #3 |
You will lose MPG when the temperature decreases. That would be my guess over the CAI.
As for the tube, I think they just don't want the throttle body and tube touching. It gives it room to flex. Give it about 1/8 to 1/4 inch clearance if you can.
2010 Camaro 2SS/RS, 6M, ADM Race scoop, CAI intake, VMAX TB, Kooks LTs, Solo Mach X, MGW Shifter, Dynotech driveshaft, 1LE 3.91 gears with JRE updates, BMR bushings/Toe/Trailing Arms, Pedders ZL1 sways and XA Coilovers, Heritage Grill, Yenko side stripes, SS emblems, Havoc Rear Spoiler.
10-20-2011, 09:04 AM | #4 |
v It bites.
Drives: 2011 IBM 2SS/RS Join Date: May 2008
Did you get a tune? My tuner had to adjust air/fuel ratios... I gained 2-3 mpg city with the CAI even with headers once those ratios were adjusted.
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit. |
10-20-2011, 09:18 AM | #5 |
Beasting off the Riesling
Drives: 2011 Black 2SS/RS Join Date: Jul 2011
It would likely be more efficient, as its pull in more air, which ='s less gas to make the combustion necessary to power the vehicle.
Also did you reset you MPG calc as soon as you installed it? It might take some time for the computer to "learn" the new CAI. A fresh reset will also give off readings, as the number will flux between high and low depending on driving conditions... ex highway local etc... |
10-20-2011, 10:14 AM | #6 |
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X Join Date: Aug 2011
Comparing MPG with anything is nearly impossible to get a proper reading. Air temperatures, humidity, fuel quality, traffic, excitement with your new found power, etc. They all will effect your average MPG, these things can change in 10 minutes, so its super hard to determine effectively on the street. It does take some time for the computer to adjust to the CAI, if I was you, I'd now drive it like normal (full throttle at times) for a while to get the computer used to it in all circumstances, then I would retry the fuel economy; but remember it probably won't be a good comparison, especially as eclipsen stated, winter is coming... :(
Having a CAI doesn't mean it gets more air, the throttle body blocks any unwanted air. If it got more air, it would go lean (bad) and it would add more fuel, and your RPM would go up. A CAI grabs colder air and allows it to enter the engine in a smoother and quicker way, which means the engine doesn't have to work as hard, pulling air into it, hence more power available and better fuel economy. Correct about the intake tube, it cannot contact the throttle body for noise and vibration, which is why it needs to be pulled out slightly. An 1/8 inch gap would probably be all thats needed. As long as the clamp gets a good full hold on the pipe, you're fine. |
10-20-2011, 10:26 AM | #7 |
love. my. car.
I had that same suspicion when it started getting cold last winter. I replaced the CAI with the stock one for a few weeks and did not notice any increase in mileage. It's a combination of 2 things, cold temps make the engine run less efficiently for longer, and winter blend fuel causes a slight mileage drop as well.
10-20-2011, 10:29 AM | #8 | |
Ted.
www.jannettyracing.com
10-23-2011, 09:17 PM | #9 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
Camaro tuner in Tampa
10-23-2011, 09:43 PM | #10 |
Drives: Chevy Join Date: Oct 2011
You should get you car tuned, and if you do may i suggest a 160 stat as well. You should truly get your car tunes after any mod if you wanna get the best bang for your buck.
10-24-2011, 09:03 AM | #11 |
Drives: 2010 silver SS Join Date: Apr 2011
mine dropped with my exhaust.... then dropped again with headers... then again with cai.... then yet again with a tune.... then I realized I was driving like I was 16 again and it started to rise back to the 20/24 mpg range as I stayed off the skinny pedal.
2012 Corvette Grandsport... TSP headers, Borla S-Type, BTR Stage 3 N/A cam, Halltech Super Bee MF108
10-24-2011, 10:00 AM | #12 |
Drives: 2010 SS/RS Supercharged 427 Build Join Date: Nov 2010
Thats typically the case!!
10-25-2011, 11:41 AM | #13 |
Chief Many Camaros
Drives: A paid off Camaro!!! Join Date: Mar 2009
Did you happen to do a fuse pull when you installed the CAI, I did when I installed my Roto-Fab at C5F2 and driving back I noticed about a 2-3 mpg increase. A buddy also purchased a CAI intake at C5F3 and we did the fuse pull at the hotel, he also noticed similar results. I just like to pull fuses I do it to reset the computer any time I change anything on the car, as I feel it resets the baseline parameters. Just my 2 cents worth.
504hp/478tq Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac |
10-26-2011, 09:37 AM | #14 |
Also reset your mpg monitoring euip and start it over with the CAI. Otherwise it is calculating an average of every mile you have ever driven. Typically our customers see a 2 or 3 mpg increase.
Thread Tools | |
Similar Threads | ||||
CAI from CA Inductions installed | Heelhook22 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 07-20-2011 02:25 PM |
***Magnaflow part# 16483 and LMR CAI installed today*** | DHSS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 02-22-2011 09:11 PM |
Injen CAI Installed! Have a question though.... | Jaime068 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 17 | 02-13-2011 12:11 PM |
Installed my new cai Intake from CAI | americo | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 115 | 04-29-2010 09:52 PM |
LS3 CAI MPG loss | herkman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 32 | 07-16-2009 09:24 PM |
