Caryle Racing
Old 10-20-2011, 10:28 AM   #1
Mach
Mach's Avatar
Drives: White M6 1LT RS
DIY: LED Strip Sidemarkers
I got 2 amber and 2 red 40 LED flexible array strips from Radiantz.com
Splitting the sidemarkers apart was challenging. I started prying at the tab on the front of the lens. Then ran a sharp utility knife along the edge. A 10 min 200 degree oven did help soften the plastic and made it less prone to the lens cracking.
Double sided tape on the LED Strip.
LED strip in position.
Glued back up and installed.
I still need to paint the lens white. I will leave a 1/8 inch slot unpainted for the LED strip to shine through.
Repeat this 3 more times... I paid $131 for all four LED strips. Alot less then the 2 companies that make these.
NEXT UP I WILL INSTALL A 50 LED STRIP IN THE MIRRORS.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 10-20-2011, 10:32 AM   #2
Daily Driver
Daily Driver's Avatar
Drives: Silver Bullet
Nice work !
Daily Driver is offline   Reply With Quote
Old 10-20-2011, 10:51 AM   #3
jmart53
jmart53's Avatar
Drives: 2012 Cruze LTZ RS
I think you might have convinced me of a DIY for this winter Way cheaper than aftermarket and you get that pride of doing it yourself! Post pics when you get them painted too!
jmart53 is offline   Reply With Quote
Old 10-20-2011, 10:53 AM   #4
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
Originally Posted by Mach View Post
Repeat this 3 more times... I paid $131 for all four LED strips. Alot less then AAC or Showstoppers
Cool write-up but our sidemarkers are only $199 for all 4 and as seen HERE and you do not need to spend hours cutting up your sidemarkers and you keep your old sidemarkers after you install which cost $40/ each from Chevrolet so when its all said and done this DIY mod costs you more than buying sidemarkers from AAC... but to each his own I guess
AACstyle is offline   Reply With Quote
Old 10-20-2011, 10:56 AM   #5
Mach
Mach's Avatar
It took me 15 mins per sidemarker. I don't really have a need to keep my old markers. So overall this DIY is still 70 dollars less. But hey to each his own.
Plus its much more rewarding knowing you did something by yourself.
Next mod: Done!
Old 10-20-2011, 11:02 AM   #6
AACstyle
AACstyle's Avatar
It took me 15 mins per sidemarker. I don't really have a need to keep my old markers. So it's still 70 dollars less. But hey to each his own.
Its all good, not knocking,
Next time you decide to do one of these DIY projects get your LEDs from us, we have MUCH brighter LEDs at better prices than the other guys you mentioned
Old 10-20-2011, 11:05 AM   #7
tobalt
tobalt's Avatar
Drives: IBM L99 2SS/RS
I have Showstopper's LED Sidemarkers, but this looks great too! Awesome DIY! You should definitely post this over in the DIY section!
tobalt is offline   Reply With Quote
Old 10-20-2011, 11:05 AM   #8
Mach
Mach's Avatar
I actually want to dim these a little because they are so bright!!
PLUS, your strips are wayyyy more expensive and I get the length I need from Radiantz
Radiantz LED's are really high quality. They are MADE IN THE USA!
In fact your Dual Intensity Circuit LED controller is from Radiantz. They make it and they charge 4.99 and you charge 14.99. SHAME ON YOU FOR RIPPING PEOPLE OFF!!!!
Next mod: Done!
Old 10-20-2011, 01:49 PM   #9
Inferno LSX
Supercharged LSX
Inferno LSX's Avatar
Drives: 2011 2SS/RS Black/Carbon Fiber
Awesome DIY! What Length are the LED strips?
Inferno LSX is offline   Reply With Quote
Old 10-20-2011, 01:51 PM   #10
Inferno LSX
Supercharged LSX
And how did u seal the wires through the socket hole on the back?
Old 10-20-2011, 02:28 PM   #11
Mach
Mach's Avatar
40 led strips. These are the 1mm spacing strips. I got the same length for all 4. But the back ones can fit 45 led strips, as the back sidemarkers are slightly longer.
Didn't have to. I ripped off the metal tabs off the stock blub and wedged the led wires with the blub into the socket. I will get a blank 192 socket eventually and do it the right way.
Next mod: Done!
Old 10-20-2011, 03:05 PM   #12
Inferno LSX
Supercharged LSX
Awesome. Thanks I might try this just for the fun of it on someones car.
Old 11-06-2011, 08:49 PM   #13
Mach
Mach's Avatar
I got more pics on the DIY thread here...
http://www.camaro5.com/forums/showthread.php?t=177650
Next mod: Done!
Old 11-07-2011, 09:28 AM   #14
Inferno LSX
Supercharged LSX
Are these the LEDs on Radiants site that come in a plastic tube?
DIY LED Night Rider Scanner V2.0 install pics ROBBDOGG1986 Camaro DIY & HOW-TO instructions & discussions 135 03-06-2015 12:30 AM
LED Sidemarkers that look like OEM chozn4service Cosmetics and Lighting Modification Discussions 16 03-08-2011 04:41 PM
T10 LED Bulbs (Used for Interior, Sidemarkers, License Plate, Etc.) Just $6.99/Pair! AACstyle Interior Parts & Accessories 10 12-07-2010 02:11 PM
LED sidemarkers bulbs LosXC451 Cosmetics and Lighting Modification Discussions 13 08-26-2010 11:00 PM
FS: Camaro LED Sidemarkers chutoyy Exterior Parts & Accessories 7 07-01-2010 06:48 AM
