BeckyD@RodgersChevrolet
Old 11-09-2011, 11:24 AM   #43
Mach
Mach's Avatar
Drives: White M6 1LT RS
Originally Posted by verboten View Post
Will I need resistors? I have a LT and plan to use dual filament for turn signals.
I am not familiar with dual filament LEDs strips. The flexible led light array that radiantz sells has resistors on the strip.
Are you talking about making your side marker running lights into turn signals also?
If you want turn signals you are better off buying a 4.99 Dual intensity circuit...
Radiantz sells a dual intensity circuit that lets you run running lights and turn signals on one led strip.
http://www.radiantz.com/index1.html?230.html&1
AAC sells the exact same thing for 4 times the price.. RIPOFF!
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 11-09-2011, 12:23 PM   #44
Saint Alban
Saint Alban's Avatar
Drives: '14 Black 2SS RS
You'd need one circuit per light I believe....or one per side (left and right) if you want both front and rear to be signals, but using one per side means you'd need to splice the front and rear together to connect to the dual intensity circuit. One per light would be easier but obviously a bit more money.
Saint Alban is offline   Reply With Quote
Old 11-10-2011, 12:50 AM   #45
MikeGstayUp
MikeGstayUp's Avatar
Drives: 2013 SS in the future
great mod, looks like you ordered them instead of making them!
MikeGstayUp is offline   Reply With Quote
Old 11-10-2011, 10:42 PM   #46
Krapdavid
Drives: Camaro soon
Man how'd you get that effect? Did you paint the markers? I like how that LEDs are the only things you see. How'd you make that effect?
Krapdavid is offline   Reply With Quote
Old 11-11-2011, 04:51 AM   #47
Saint Alban
Read from the first page. This entire thread is about how he did it and how to "do it yourself" (DIY).
Old 11-11-2011, 09:21 PM   #48
Sleez
Sleez's Avatar
Drives: 2010, 2LT, RS, 6M, ABM (#1893) SOLD
since you used the orig lenses, couldn't you have just used white LEDs?
or do they offer white?
seems like they would be even brighter.....
Sleez is offline   Reply With Quote
Old 11-11-2011, 11:53 PM   #49
Ivan @ Southwest Speed
Nicely done! They came out clean and look pretty good man.
Ivan
Old 11-12-2011, 06:22 PM   #50
Mach
Mach's Avatar
Not even sure if they offer white. I wanted the colored LED's to help with the sharpness of the color. Does that make sense?
Next mod: Done!
Old 11-12-2011, 06:23 PM   #51
Mach
Mach's Avatar
Ivan
Thanks very much Ivan!
Next mod: Done!
Old 11-16-2011, 01:27 PM   #52
JWMotoring
JWMotoring's Avatar
Drives: SS Camaro
Send a message via Yahoo to JWMotoring
Nice!
JWMotoring is offline   Reply With Quote
Old 11-17-2011, 09:44 AM   #53
KalCorp
Space Coast Camaros
KalCorp's Avatar
Drives: 2012 Camaro Vert
What LEDs did you get at Radiantz?
The only 100 Led per foot i see is the Z-Flex Leds and they come with a tube.
Did you get these and just take out the LED strip?
Thanks
KalCorp is offline   Reply With Quote
Old 11-17-2011, 09:46 AM   #54
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
Thanks
I think somewhere else in the thread he said he took it out of the tube
Old 11-17-2011, 11:12 AM   #55
Mach
Mach's Avatar
Thanks
Yes that's what I did.
Next mod: Done!
Old 12-05-2011, 04:50 PM   #56
puertoricanfont
Drives: 2016 scat pack charger
instead of painting. Would you be able to use vinyl? thats what im thinking of doing
puertoricanfont is offline   Reply With Quote
2010-11 Camaro ACC LED Side Marker Mods for Turn Signals GearHeadPeter Cosmetics and Lighting Modification Discussions 44 03-13-2015 02:25 AM
DIY: Trunklighting with an LED strip **EASY!!** 13lade Camaro DIY & HOW-TO instructions & discussions 39 08-11-2014 01:55 PM
DIY: LED Strip Sidemarkers Mach Cosmetics and Lighting Modification Discussions 23 11-07-2011 10:17 PM
DIY - 2010/11 Camaro AAC LED Side Markers Install with Turn Signals GearHeadPeter Camaro DIY & HOW-TO instructions & discussions 0 03-03-2011 01:30 PM
DIY V-LEDS 28 LED 5202 Fog Lights High Output! I mean BRIGHT results. D1BADZ Camaro DIY & HOW-TO instructions & discussions 20 07-21-2010 01:57 PM
