Old 02-09-2012, 11:28 AM   #71
Saint Alban
Saint Alban's Avatar
Drives: '14 Black 2SS RS
Originally Posted by vroomapunk View Post
For people who dont even want to go the LED route, or arent handy enough to do it, you can probably just paint the stock lens and leave a strip unpainted, using stock bulbs.
Wouldnt be as bright, and even, but would still look much better than stock IMO.
If you're gonna remove them to paint the lens, might as well go on eBay and get the little push in T10 LED bulbs.
Saint Alban is offline   Reply With Quote
Old 02-09-2012, 12:14 PM   #72
BloodUSMC
Blood Sucking War Machine
Drives: Black 2011 Camaro 2LT/RS - A6
Originally Posted by Saint Alban View Post
Bought the LEDs or the already made sidemarkers?
LEDs only
BLACK 2011 2LT/RS COUPE. Roto Fab Intake, MRT 1.0, OBX LT Headers, Magnaflow resonated x pipe, Trifecta Tune
BloodUSMC is offline   Reply With Quote
Old 02-11-2012, 08:48 PM   #73
willie_district
willie_district's Avatar
Drives: Black 2011 2SS
I followed your blue print but switched it up a bit. I bought some clear lenses and put strips of 6 leds in each. I painted the lenses as you did and then put tint film over top. I went with white LEDs in the front.
willie_district is offline   Reply With Quote
Old 02-12-2012, 10:33 AM   #74
Mach
Mach's Avatar
Drives: White M6 1LT RS
VERY NICE!!!! GREAT WORK!!!!!!!!!!!!!!!!!!!!!!!!
Love the white in the front!
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 02-12-2012, 10:51 AM   #75
Saint Alban
I like the havoc rims more. I may have to save up for those.
Old 02-21-2012, 12:20 PM   #76
jlugo
Drives: 2014 1LE 'Summit White'
Z-Flex Led's from; Radiantz LED Lighting
Alright, I received the lights yesterday!!!...
Here's what I've done so far...
jlugo is offline   Reply With Quote
Old 02-21-2012, 12:43 PM   #77
Saint Alban
Do you already have LED sidemarkers from Oracle and you're doing this to your factory markers that you removed? I'm just trying to understand why they're in an Oracle box.
Old 02-21-2012, 07:22 PM   #78
jlugo
I bought an extra set of OEM side markers from another member and he shipped them in that box...
Old 02-21-2012, 07:47 PM   #79
Saint Alban
Makes sense now. I have my OEM markers in that box too.
Old 02-22-2012, 03:02 AM   #80
Mach
Mach's Avatar
Jlugo.. NICE WORK!!
Next mod: Done!
Old 02-22-2012, 02:22 PM   #81
Grimlock
dey see me rollin
Grimlock's Avatar
Drives: the magic school bus
Any suggestions on how to split the sidemarker apart? I did the baking thing. Ended up warping one of them.
Grimlock is offline   Reply With Quote
Old 02-22-2012, 02:31 PM   #82
Saint Alban
Maybe a dremel? Or maybe theres a specific temperature. Mach would know.
Old 02-22-2012, 02:41 PM   #83
Grimlock
dey see me rollin
Grimlock's Avatar
I did 200 degrees for 10 minutes and then a second time when it got tough again.
Old 02-22-2012, 03:11 PM   #84
Mach
Mach's Avatar
I put mine in at 140 for like 10 mins. Anything more you will warp them. Sucks to hear.
The easiest way to split them is warm them up then take a fresh utility knife and start scoring the part where the lens meets the gray plastic over and over again. Until they break apart.
Next mod: Done!
2010-11 Camaro ACC LED Side Marker Mods for Turn Signals GearHeadPeter Cosmetics and Lighting Modification Discussions 44 03-13-2015 03:25 AM
DIY: Trunklighting with an LED strip **EASY!!** 13lade Camaro DIY & HOW-TO instructions & discussions 39 08-11-2014 02:55 PM
DIY: LED Strip Sidemarkers Mach Cosmetics and Lighting Modification Discussions 23 11-07-2011 11:17 PM
DIY - 2010/11 Camaro AAC LED Side Markers Install with Turn Signals GearHeadPeter Camaro DIY & HOW-TO instructions & discussions 0 03-03-2011 02:30 PM
DIY V-LEDS 28 LED 5202 Fog Lights High Output! I mean BRIGHT results. D1BADZ Camaro DIY & HOW-TO instructions & discussions 20 07-21-2010 02:57 PM
