Old 02-27-2012, 08:25 AM   #113
JWMotoring
JW Motorsports LLC
JWMotoring's Avatar
Drives: 2018 SS Hyper Blue
Originally Posted by Mach View Post
Yes Sir!! I laid the wires over the contact point and wedged the bulb back in. But remember to snip of the bulb wire. You want that bulb to be dead.
I am really glad you guys are loving this DIY. When I did my led side markers I couldn't believe how good they looked. I knew I had to share it with my fellow members. We accomplished something that looks better then some vendors for cheaper. A win/win.
They take a 194 bulb stock right?
JWMotoring is offline   Reply With Quote
Old 02-27-2012, 08:44 AM   #114
Saint Alban
Saint Alban's Avatar
Drives: '14 Black 2SS RS
Originally Posted by buzzy56 View Post
I guess that is what I get for coming into the thread late and not reading it in its entirety !
It happens
Yup
Saint Alban is offline   Reply With Quote
Old 02-27-2012, 09:48 AM   #115
Bill F
Bill F's Avatar
Drives: 2011 CGM 2LT/RS 2005 Silverado Z71
I ordered some empty 194 bases to solder the LED wire to, then plug that into the factory light socket. Hopefuly it will work and stay sealed at the same time.
EDIT: Here's what I ordered. I got 6 of them in case I screw up a few.
http://www.autolumination.com/images...94_base_wm.jpg
TEAM LLT
VMaxx TB, MRT v1, Roto Fab CAI, Custom Painted Bowties, DT Headers(On order!)
Bill F is offline   Reply With Quote
Old 02-27-2012, 10:58 AM   #116
Mach
Mach's Avatar
Drives: White M6 1LT RS
I recommend everyone to do this. It is more secure. No risk of wires shorting and a better connection.
go here.... http://autolumination.com/connectors.htm
this is what you want.. Standard bulb bases with a plug-in 2-wire pigtail 12"- 18 gauge wires
order 4 194's
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 02-27-2012, 11:24 AM   #117
Bill F
Bill F's Avatar
order 4 194's
Yep, that's what I got, except I ordered 6 because I get impatient sometimes.
TEAM LLT
Old 03-14-2012, 11:13 PM   #118
jlugo
Drives: 2014 1LE 'Summit White'
Cool
Rear sidemarkers 'Done'
jlugo is offline   Reply With Quote
Old 03-15-2012, 01:05 AM   #119
Mach
Mach's Avatar
Good Work!! It's really hard to capture how bright they are and how good they look with a camera.
Next mod: Done!
Old 03-15-2012, 03:23 PM   #120
jlugo
Few more pic's...
Old 04-03-2012, 10:22 PM   #121
camaro104
camaro104's Avatar
Drives: 2017 Nightfall 50th Annivers Camaro
Send a message via AIM to camaro104
I see my next project coming.....
camaro104 is offline   Reply With Quote
Old 04-05-2012, 01:21 PM   #122
11SynergyGr&Bl
JZ
11SynergyGr&Bl's Avatar
Drives: 2011 Synergy Green Camaro
Amazing!! Going to match my sgm will be a choir. Haha. ^.^ i cant wait to tackle this project! Great dyi thnks!
*2011 SGM Camaro*
Hi/low 8k HID kit, Injen WB long tube, Pfadt stage 2, Rx black ice-olator, Rx catch can (color matched =D).
11SynergyGr&Bl is offline   Reply With Quote
Old 04-06-2012, 12:14 AM   #123
awfarley
awfarley's Avatar
Drives: 2011 5.7L Tundra Double-Cab X-SP
That looks like another one on my long long list of To-do's....
That wouldn't violate any auto-lighting laws ya think?
awfarley is offline   Reply With Quote
Old 04-06-2012, 09:40 AM   #124
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
it wouldnt break any laws, you arent covering up the light, and actually making it brighter and more noticeable, mercedes, porsches, etc already have the same led markers
Old 04-06-2012, 11:41 AM   #125
Mach
Mach's Avatar
I don't think anyone has even gotten pulled over for LED sidemarkers. Ours retain the reflector so its legal. AAC on the other hand I am not sure because the reflector part of the lens goes away.
Next mod: Done!
Old 04-06-2012, 03:23 PM   #126
Sleez
Sleez's Avatar
Drives: 2010, 2LT, RS, 6M, ABM (#1893) SOLD
just crunched the numbers; i assumed it would be much cheaper than the plug and play versions available, but not really.
142.58 shipped for the leds
15.96 shipped for the 194 sockets
60.00 shipped for used sidemarkers (want to be able to return to factory, would be able to do that if i bought plug and play ones as well.)
plus paint and primer. have to assume 25.00???
so 243.54 total plus the satisfaction of doing it myself versus 280.00 shipped for a vendors product. so, all in all not saving anything really. but you may see benefits to this DIY as mentioned earlier; the thinner slit, retaining reflector, personal satisfaction, etc.
hmmmmm, not sure where i stand on this, leaning toward DIY, since i do enjoy working on my own car as much as possible.
Sleez is offline   Reply With Quote
2010-11 Camaro ACC LED Side Marker Mods for Turn Signals GearHeadPeter Cosmetics and Lighting Modification Discussions 44 03-13-2015 03:25 AM
DIY: Trunklighting with an LED strip **EASY!!** 13lade Camaro DIY & HOW-TO instructions & discussions 39 08-11-2014 02:55 PM
DIY: LED Strip Sidemarkers Mach Cosmetics and Lighting Modification Discussions 23 11-07-2011 11:17 PM
DIY - 2010/11 Camaro AAC LED Side Markers Install with Turn Signals GearHeadPeter Camaro DIY & HOW-TO instructions & discussions 0 03-03-2011 02:30 PM
DIY V-LEDS 28 LED 5202 Fog Lights High Output! I mean BRIGHT results. D1BADZ Camaro DIY & HOW-TO instructions & discussions 20 07-21-2010 02:57 PM
