Cold Air Inductions
Old 10-22-2011, 03:15 AM   #1
ThunderJolt
Drives: 2011 2LT/RS V6 Camaro
Camaro Lower Grill
Hey guys,
can anyone help me find a lower grill to match the heritage grill on my 2011 camaro? I looked at the T-Rex but they don't look as good as these:
Where can i get the lower insert? I've searched everywhere for just that lower insert but came up with nothing
ThunderJolt is offline   Reply With Quote
Old 10-22-2011, 03:31 AM   #2
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
Check out street scene. Here's a pic of mine with the optional ports that I had painted. You can get a grille that goes all the way across without the ports.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 10-22-2011, 03:37 AM   #3
ThunderJolt
yeah but i was wondering where can i get that lower grill. because the ones that came on my camaro looked like these:
meanwhile i wish to install these:
Old 10-22-2011, 03:41 AM   #4
yotaman96
yotaman96's Avatar
Both grilles you are referring to are stock. One is the SS grille and one is the V6 grille. They are different sizes and not interchangeable.
Old 10-22-2011, 03:43 AM   #5
ThunderJolt
I have a 2011 V6 2LT/RS. Can't I purchase the SS lower grill?
Old 10-22-2011, 03:48 AM   #6
yotaman96
yotaman96's Avatar
You can purchase it, but as I said, the lower grilles are different sizes between the SS and the V6 cars. An SS lower grille will not fit your V6 car unless you replace the entire front bumper with an SS bumper.
Old 10-22-2011, 03:50 AM   #7
ThunderJolt
okay that helps a lot. Any ideas where i can get ones that fit the V6 with a similar pattern?
Old 10-22-2011, 04:21 AM   #8
ThunderJolt
can i still install my "RS" embelem on the new H Grille?
Old 10-22-2011, 08:34 AM   #9
chvyman
chvyman's Avatar
Drives: 2SS 45TH,gfx,blade spoiler,h grille
you can install your RS emblem, but you have to trim the braket that holds it in.
chvyman is offline   Reply With Quote
Old 10-22-2011, 08:38 AM   #10
Man1acs
Drives: 2010 IOM Camaro SS
I was not a huge fan of those. Somewhat because of the problem matching. This is what I did.
Man1acs is offline   Reply With Quote
Old 10-22-2011, 09:00 AM   #11
cajun2010
cajun2010's Avatar
Drives: 2010 1LT/RS
Street scene
2010 1LT/RS Eibachs, Doug Thorleys, Flowmasters, Stillen, hmm a few other things...
cajun2010 is offline   Reply With Quote
Old 10-22-2011, 02:24 PM   #12
pnyklr
Drives: A Gift From My Wife
How exactly did you attach the RS to the grill. I have my SS emblem in the same spot but it held in by temporary means at the moment.
-Funk
2012 Convert 2SS/RS SW/IO LS3 - Build #1081
07/21/2011 - (3800) Order produced and vehicle is being prepared for shipping.
08/09/2011 - (4200) Shipped (vehicle is shipped to the dealer or interim point of delivery).
08/16/2011 - (5000) Vehicle has been delivered to dealer.
08/19/2011 - In my possession.
pnyklr is offline   Reply With Quote
Old 10-22-2011, 07:15 PM   #13
chvyman
chvyman's Avatar
its been a year and a half ago now, so i went out and took a look. I had to trim the 2 legs of the rs emblem and attach it to the grille with 2 clips like the ones that came off the factory grille when it was removed. you had to trim the emblem in such a way that it woul line up with the bars of the heritage grille. you don't cut the legs off, just make them thinner to fit between the bars. I did't use the original back-up bracket from the RS emblem, just the 2 clips. A picture is worth a thousand words but I don't have one so I hope this helps.
custom body kits, grille
