BeckyD @ James Martin Chevy
Old 10-22-2011, 04:16 AM   #1
bowtie628
Auto body and paint guy
bowtie628's Avatar
Drives: 2010 Camaro LS
v6 engine ping?
when i drive my car at low speeds like between 5-15 MPH and the RPM'S are low im hearing a pinging coming from the engine, once im over a certain speed its stops.. i know its not a knock.. kinda sounds like when theres bad gas in a car.. i also use 87 octane, i dont know if this has anything to do with it?
bowtie628 is offline   Reply With Quote
Old 10-22-2011, 07:04 AM   #2
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
I would try running some higher octane...
scrming is offline   Reply With Quote
Old 10-22-2011, 08:12 AM   #3
gml1998
gml1998's Avatar
Drives: 2010 Synergy Green Camaro
I would also try higher octane to see if the pinging gets better .If the pinging gets better with higher octane you will know it is pre detonation issue.However you should be able to run 87 octane with no issues.I think a trip to the shop is in your future.
Test higher octane first,that way you can tell the shop you have tried gifferent fuel. Good luck
gml1998 is offline   Reply With Quote
Old 10-22-2011, 11:24 PM   #4
bowtie628
bowtie628's Avatar
funny thing is.. when my car was doing this last night my tank was on dead empty and the low fuel warning was on.. once i re filled the noise went away...
Old 10-23-2011, 01:57 AM   #5
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Could be sucking crap from the fuel tank into the fuel filter and the fresh tank cleared things up?
BaylorCamaro is offline   Reply With Quote
Old 10-23-2011, 10:36 PM   #6
bowtie628
bowtie628's Avatar
thats what im thinking..
Old 10-23-2011, 10:43 PM   #7
Fuel Fire Desire
Fuel Fire Desire's Avatar
Drives: 2011 M6 LS
Pre-ignition, or Detonation. Two different things.
Fuel Fire Desire is offline   Reply With Quote
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 08:50 PM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 06-07-2011 01:09 PM
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 09:33 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Suspension / Brakes / Chassis 6 01-15-2010 01:58 PM
