JUICEDMOTORSPORTS
Old 10-22-2011, 11:57 AM   #1
SamSS
SamSS's Avatar
Drives: '10 Camaro SS
Arrow HELP! Spring Installation
So we tried to install my PFADT springs on my car yesterday and pretty much an epic fail. We decided to put everything back together and just take it to a shop. But the problem is that some of the holes are not lining up so we can put the screws back in. The hardest one to line up is the control arm and the piece that's connected to the roter. We tried jacking up the control arm so it can go in it. But that doesn't work because it just pushes the other one up too. So does anyone have any advice?
2010 Camaro SS A6, Rotofab intake, Flowmaster American Thunder exhaust, JBA off-road pipes, PFADT sway bars and lowering springs, Dyno tuned by CMS
SamSS is offline   Reply With Quote
Old 10-22-2011, 12:28 PM   #2
SamSS
SamSS's Avatar
The lower control arm to the spindle bolt is our problem
Old 10-22-2011, 12:34 PM   #3
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I haven't done this mod yet so this my best guess, but it appears to me if you go to the local autoparts store and rent/borrow a spring compressor. Take the tension off the strut by compressing the spring and the arm should move pretty easily after that into position.
Just a thought until one of the experts arrives.
Old 10-22-2011, 12:41 PM   #4
SamSS
SamSS's Avatar
We already have the compressor, we connected the strut to the control arm and the bolt is in there now. Now we just have to connect the roter piece to it, that's the problem.
Old 10-22-2011, 02:22 PM   #5
SamSS
SamSS's Avatar
Now we got the bush in but need to get it lined up
Old 10-22-2011, 02:35 PM   #6
ssmike
Missing Big Red
ssmike's Avatar
Drives: '13 Equinox CRT
I just did my outer trailing arm bushings and I had the same problem! I had to keep working at it but ultimately I got the bolt to line up by moving the lower arm back and forth while pushing the bolt in! Hope this helps!
Old 10-22-2011, 03:23 PM   #7
mhog
mhog's Avatar
Drives: 2010 V6 Camaro 2LT/RS
Things don line up well when your suspension is hanging. You have to push pull and wiggle to get things back in place.
mhog is offline   Reply With Quote
Old 10-22-2011, 03:34 PM   #8
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
Yea that's a bitch to reline up. Gets easier as you go.
chevy 3 is offline   Reply With Quote
Old 10-22-2011, 03:57 PM   #9
SamSS
SamSS's Avatar
So do i jack the control arm up? what should i do?
Old 10-22-2011, 03:59 PM   #10
SamSS
SamSS's Avatar
Should i disconnect the upper control arm so i can tilt the roter so is hopefully goes in?? would that help or make it worse?
Old 10-22-2011, 11:22 PM   #11
SamSS
SamSS's Avatar
So it's finally done haha
Old 10-23-2011, 08:45 AM   #12
ssmike
Missing Big Red
ssmike's Avatar
Yay! How did you get it to line up?
Old 10-27-2011, 02:17 AM   #13
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Now that you have it all back together it is time to time the bushes and get a quality alignment.
Bush Timing
Step 1. Pull the car up on to a drive uplift.
Step 2. Loosen the following bolts/nuts:
Front:
---Inner Control Arm Bushing
---Inner Radius Rod
Rear:
---Trailing Arm Bushings (both ends)
---Toe Rod Bushings (both ends)
---Lower Control Arm Bushings (Inner)
---Upper Control Arm Bushings (Rearward)
---Lower Strut Bushings
Step 3.
Grab the subframes or sway bars, and jounce the car up and down a few times.
Step 4.
Tighten all of the nuts/bolts to spec.
Step 5.
Align the car at the new ride height.
Pfadt Race Engineering DIY Drop Spring installation procedure PfadtRacing Suspension / Chassis / Brakes 20 09-23-2011 10:31 PM
SPRING into SPRING - 5% OFF ALL LOWERING SPRINGS! Meister@Torq Suspension / Chassis / Brakes 2 04-14-2011 03:37 AM
Raising/Lowering the car Rocky918 Suspension / Brakes / Chassis 28 03-19-2011 12:03 AM
Whipple SC installation compared to Maggie installation Fiftydriver Forced Induction - V8 8 02-12-2011 12:56 PM
BMR Lowering Springs - How It's Made BMR Suspension Suspension / Brakes / Chassis 40 06-22-2010 11:32 AM
