BeckyD @ James Martin Chevy
Old 10-22-2011, 11:58 AM   #1
dymndave
dymndave's Avatar
Drives: 02 mustang roush
LFX THROTTLE RESPONSE
First off, i have a manual v6 LFX and only have about 200 miles on her.
I have a very noticable delay in throttle body response from an idle. When i give it gas (from an idle) there is an audible "fwopping" noise (which i assume is the throttle body opening) and almost a second delay before any rpms at all. Now I could assume this could be normal, just slow response but, if i just very quickly tap the throttle and let off, i get the "fwop" noise and a drop in rpm where it sounds like the engine almost dies.
There are no throttle response issues at all over 1000 rpms, in fact it performs extremely well at speed. It's just coming from an idle the delay will almost make you stall trying to pull out in 1st.
I took it to the dealership and got the expected "this is normal, it's just the nature of these cars".
Anyone else notice this at all?
2012 45th ed.
08/31/2011 (1100)
08/31/2011 (1102)
09/05/2011 (2000)
09/06/2011 (2500)
09/07/2011 (3000) (TPW 9/26)
09/16/2011 (3300)
09/21/2011 (3400)
dymndave is offline   Reply With Quote
Old 10-22-2011, 06:08 PM   #2
KMPrenger
KMPrenger's Avatar
Hrrmmm....well my 2010 LLT doesn't seem to have a bad delay. I can't say that it is instantaneous or anything (off idle), but if I give it a good amount of the go juice it seems to take off quick enough that I don't notice anyting abnormal.
Of course I can't speak of the LFX.
Going to be hard to determine this without you trying another owners V6 or maybe even posting a video.
Old 10-22-2011, 07:08 PM   #3
bmorecam
What do you mean by "fwopping"?? I am really trying to comprehend that term but I jut can't no matter what, sorry.
There is a delay and it's normal but when you give gas it should be instantaneous but somewhat lazy due to our computer controlled throttle system. It almost sound like you are saying that when you take off from stand still there's 1 sec delay. I can tell you this much, I have a 2011 and mine does not have 1 sec delay from stand still. Maybe the 2012 throttle control is programmed with more delay or restriction but that would just be my wild guess of the night.
Any other 2012 owners experience anything similar?
Old 10-22-2011, 07:43 PM   #4
Kurushio
Kurushio's Avatar
Drives: 2011 CGM 1LT RS (M6)
Sounds kinda like the 300 i drove. I would hit the peddle and it would be a good 1-2 seconds before it did anything. Kinda made driving it a little harder than it should be.
Kurushio is offline   Reply With Quote
Old 10-22-2011, 07:49 PM   #5
dymndave
dymndave's Avatar
OK, "fwop" was probably not a good word to use. It is definitely a mechanical sound that i am hearing, like two pieces of plastic hitting together, and i believe i can hear a rush of air also before it spools up. (LOL, this is how i got fwop)
The noise wouldn't bother me a bit except for this delay as i feel like it is related. Like i said before, this may be normal but i have a 2002 V6 mustang 3.8 that does not have near the delay as the camaro.
I really don't know how else to describe it, but i thought i would give it a shot.
2012 45th ed.
08/31/2011 (1100)
08/31/2011 (1102)
09/05/2011 (2000)
09/06/2011 (2500)
09/16/2011 (3300)
09/21/2011 (3400)
Old 10-22-2011, 08:23 PM   #6
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM 2SS
Maybe a messed up throttle body? One of the v8 guys in my club, had a similar issue and he kept hearing some weird clicking sound from his throttle body.
I think GM replaced it.
Blade is offline   Reply With Quote
Old 10-23-2011, 10:46 PM   #7
Ozzie RS
Ozzie RS's Avatar
Drives: '11 Camaro RS 2LT
I'm assuming you haven't done any mods yet with only 200 miles. Go to another dealer and test drive another Camaro or go to another dealer and let them look at your car. Mine has no delay to speak of but different people interpret things differently. My 2 cents.
Ozzie RS is offline   Reply With Quote
Old 10-25-2011, 12:17 PM   #8
PsychoZL1
PsychoZL1's Avatar
Drives: 2015 Challenger SRT
Sounds normal to me. Most cars nowadays are drive by wire for the throttle and all drive by wire vehicles have some throttle lag, which is especially noticeable in the lower RPM band.
As suggested, go test drive some others to see if it does the same thing, but chances are it is normal. If it bothers you too bad, I would suggest looking into a SprintBooster or equivalent mod that helps in making the throttle respond better to driver input.
PsychoZL1 is offline   Reply With Quote
Old 10-25-2011, 03:07 PM   #9
TexasCamaro5
Bayou City Muscle Cars
Drives: 2010 Camaro 2LT/RS
There's a Vmax Motorsports CNC ported throttle body out for the LLT motor in the 2010 and 2011 Camaros that killed the dead spot in the 2000 rpm range, so maybe it's a similar issue with the 2012's just in a different spot in the RPM range? Although at that low of an rpm, may just be curable by getting into the drive-by wire throttle control and adjusting it there.
TexasCamaro5 is offline   Reply With Quote
Old 10-25-2011, 03:51 PM   #10
Chevrolet Customer Svc
Drives: GM Vehicles
dymndave, have you tried testing other v6 2012 Camaros at all to check them against your vehicle? That would be a good place to start to see if your dealer was correct in their analysis. Let me know how you decide to progress with this. I'd like to help all I can.
Jeff Morris, Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 10-25-2011, 07:14 PM   #11
JoshBobGuptaMarley
Emerald Coast Camaros
JoshBobGuptaMarley's Avatar
Drives: '12 2SS/RS LS3 GBA
By Monday I'll have a new cai and scoop installed and I'll see then how the car feels. We're the lucky guys who get to see how the LFX will respond to upgrades.
Muffler Delete, Cold Air Inductions intake, Technostalgia Sequential LED Tail Lights, Vmax CNC Ported TB, RX Catch Can, AAC LED Interior Lights (Aqua)
JoshBobGuptaMarley is offline   Reply With Quote
Old 10-25-2011, 10:17 PM   #12
dymndave
dymndave's Avatar
I will see if i can go test drive some others to see if it does the same.
Someone else recommended the SprintBooster. Would this mod void warranty or be something the service dept. might have a problem with? Also, do you think a CAI would help this particular problem?
2012 45th ed.
08/31/2011 (1100)
08/31/2011 (1102)
09/05/2011 (2000)
09/06/2011 (2500)
09/16/2011 (3300)
09/21/2011 (3400)
Old 10-25-2011, 10:19 PM   #13
dymndave
dymndave's Avatar
Josh, i assume you haven't noticed this problem at all with yours?
Old 10-25-2011, 11:44 PM   #14
RubyCamaro
Jan
RubyCamaro's Avatar
Sounds like you need a good cold air intake to me. IMHO
•► ► CoW BOOSTER!! ◄ ◄• Sales@CoW V8 Bolt-Ons & Tunes 33 08-21-2012 04:03 PM
Report: 2012 Camaro to get new LFX V6 Engine Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 183 08-02-2011 10:05 PM
VMax CNC Throttle Body Dyno Test Data Mike Norris Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 01-15-2011 09:28 AM
DREV PROUD TO CARRY PORTED THROTTLE BODIES BY VMAX JDRspeed2 V8 Bolt-Ons & Tunes 3 11-20-2010 02:14 PM
