10-22-2011, 08:34 PM | #1 |
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova Join Date: Aug 2010
BMR Radius rod bushing problem!!!!
Ok everyone!!!!... I just did the front suspension on my car today and i couldn't do the radius rod bushing cuz i could just not knock off that joint that goes on to the spindle. So i took it to the shop to get it done. Once at the shop the guy that was working on it (mechanic) showed me that the factory bolt that goes through the actual radius rod bushing and the chassis was thicker that the sleeve that came with the BMR kit. I just replaced every single bushing in my car and everything fit perfectly except of course for the last bushings which were the radius rod bushings. Like i said already... The factory bolt was thicker than the actual diameter opening of the sleeve provided by BMR. Have any of u guys and girls ran into the same problem? I got to the shop an hour before they closed so since the bolt could not go through the sleeve i had to go to the hardware store and buy an thinner bolt that could go through that sleeve so that they could bolt everything up and i could take my car home. -_- BMR is closed on weekends so i could not give them a call to see what i could do about it. Wanted to get my car alligned tomorrow but now i want to fix this problem. The bolt i used was a grade 8 bolt but had slight slack when inside of the sleeve. Not happy with that at all. SMH can anyone give some feedback on this??? BMR reps???
Performance- Kooks Headers w/HF cats, ZL1 Corsa exhaust, VMax, CAI Inc. CAI, MGW shifter, RX CC Suspension - KW V3 Coilovers/ Full PFADT & BMR suspension Appearance - ZL1 Fascia/Sides/ Diffuser, AAC Afterburners, RK Sport 3pc Spoiler, SLP Black out Kit
10-22-2011, 08:53 PM | #2 | |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
10-22-2011, 09:48 PM | #3 | |
10-23-2011, 11:18 AM | #4 |
Drives: 2016 Camaro 2SS Join Date: Aug 2009
First of all, sorry about your install problems. I'm sure we can determine the source of the problem and get this fixed for you.
The radius rod sleeve should be 1.00" OD. The wall thickness should be 0.219". The ID should be 0.562". We do not have a 1" sleeve with a smaller ID, so it is odd (but not impossible) that we would have used the wrong sleeve. Two possibilities come to mind. 1) Check for a burr along the ID of the sleeve. We deburr the ID on every sleeve, but it is possible that some of the sleeves were not deburred properly. 2) We fabricate rear sway bars from 1.0" x 0.250" wall thickness tubing. It is possible that the operator grabbed some sway bar tubing rather than the sleeve tubing when cutting these sleeves. I recommend that you inspect the ID for burrs. Hopefully that solves the problem so you can get everything fixed today. If that doesn't solve the problem, please measure the ID with a caliper and determine the wall thickness to determine if you received the correct inner sleeve. If you have the wrong sleeve, we will get you the correct one sent on Monday. On Monday, we will check our sleeves and verify that the correct sleeve tubing was used. |
10-23-2011, 11:40 AM | #5 | |
Yes, the BMR bushing will compress more during harsh cornering than a spherical bearing. This may cause changes to toe depending on how hard you are pushing the car. However, the BMR bushing compresses much less than the stock GM bushing. Remember, the radius rod was designed to compress by GM. The radius rod changes planes as it travels through its range of motion. The front suspension will bind if it doesn't compress. That is why we use a 3-piece bushing with a softer durometer polyurethane on the outside bushings. We have NEVER had any indication that there is a safety hazard with this product. We have sold hundreds of these bushings and have never had a failure that I am aware of. |
10-23-2011, 12:22 PM | #6 | |
10-23-2011, 12:24 PM | #7 | |
10-23-2011, 12:48 PM | #8 |
Pics
This is a few pictures of the Energy Suspension pieces in the eye of the radius arm. If the shop did not make sure the bush is in proper position when installed it will result in improper arm alignment. The bush needs to be in dead center on both ends. I also think this kit should come with some sort of adhesive to secure the bush in position to prevent it from moving during harsh maneuvers.
10-24-2011, 08:15 AM | #9 | |
Drives: Race Car Join Date: Sep 2009
Thread Tools | |
Similar Threads | ||||
Join Team BMR at LSX Shootout!! | BMR Sales | Dragstrip and Launch Techniques Discussion | 0 | 09-30-2011 11:28 AM |
New BMR Delrin Differential Bushing kit at Torq! | Erik@Torq | Suspension / Chassis / Brakes | 0 | 03-30-2011 12:45 PM |
BMR 2010 Camaro Adjustable Toe Rod Pics!!! | BMR Sales | Suspension / Brakes / Chassis | 6 | 11-10-2009 08:23 AM |
BMR 2010 Camaro Adjustable Toe Rod Pics!!! | BMR Sales | Suspension / Chassis / Brakes | 0 | 11-05-2009 10:11 AM |
