Old 10-23-2011, 01:59 AM   #15
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
^ brain fart, they make the pancake mounts i was thinking of, not energy. Edited my post
DietCoke is offline   Reply With Quote
Old 10-23-2011, 10:00 AM   #16
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
I have maggie car. They would be a good addition although I have no problems except my car is cammed and when the engine is first started and warming up I do here some pipe clinging from the engine movement but once its warm and smooth out I dont here it; niether do I hear it when i punch the gas. I will probably get them though when I do my 416ci block.
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 10-23-2011, 10:24 PM   #17
MJ
MJ's Avatar
Drives: 2010 Camaro SS/RS
I had the Prothane motor mounts installed at Jannetty's. Cammed with blower 680 to the wheels had a lot of engine movement, but not anymore. Vibration did increase, but is not annoying. Nice product... Glad I had them installed.
MJ is offline   Reply With Quote
Old 10-24-2011, 01:26 PM   #18
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
Originally Posted by Inferno LS3 View Post
After a while I can't even tell I have the Pfadt mounts. They started off almost unbearable, but either I got use to them or they softened up. But from vids of my engine from dyno pulls the engine doesn't move at all.
Yeah, after being installed for a bit, they will loosen up a little more. Plus you probably got used to them more.
Really they aren't very bad, they do increase noise and vibration a little, but the benefits far outway this. They use graphite-impregnated polyurethane bushings for long life and performance.
They give the engine excellent mounting, won't allow it to rock back and forth which may cause hood interference, or damage to other parts. If you have a cam, they will actually cause the car to shake a little less (more mass for the engine to shake). They will also actually improve throttle and power response, since the engine doesn't use power and time to twist the engine until the stock mounts hold it back. If you have a cam and/or make big power, these are a must IMO.
With our free shipping, the Pfadt Engine Mounts cost about the same as those fake Pfadt mounts, plus they look much better, and you get an actual quality part!
JDP Tech is offline   Reply With Quote
Old 10-24-2011, 01:46 PM   #19
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Thanks MJ I was wondering how you liked them.
These are Really Beefy Units, Well thought out and Minimal Vibration from our experience.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 10-24-2011, 01:52 PM   #20
jmart53
jmart53's Avatar
Drives: 2012 Cruze LTZ RS
I just installed the Pfadt engine mounts about 9 days ago... You feel it a decent amount right away but they settle in and now I barely have any movement/noise that I recognize..mainly it's just the start in 1st gear that I can still feel it... definitely worth the upgrade to stop the engine play that the stock mounts have, as well as saving some weight from those huge ass OEM mounts!
jmart53 is offline   Reply With Quote
Old 06-23-2013, 02:26 AM   #21
hcoll003
Proven Wicked Suspension
hcoll003's Avatar
Is it necessary to add the Polyurethane tranny mount with the motor mounts?
hcoll003 is offline   Reply With Quote
Old 06-23-2013, 09:51 AM   #22
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Necessary no... Recommended, yes... The primary reason to add more solid mounts is to limit drivetrain movement so power is transferred... As well as limit movement if piping is in close quarters.
Why not add the trans mount... It's inexpensive, and easy to do...I use the prothane motor mounts, and modified a urethane trans mount to work on my car... But my trans cross member and trans are one off pieces...
Old 06-23-2013, 12:25 PM   #23
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
Pfadt mounts here and I hear ppl talk about vibration and added noise and I don't or never had any added noise/vibration with mine .
Whipped416 is offline   Reply With Quote
Old 06-23-2013, 12:29 PM   #24
Inferno LSX
Supercharged LSX
Inferno LSX's Avatar
Drives: 2011 2SS/RS Black/Carbon Fiber
Same here. Pfadt ones work great and the solid mounts are bearable
Inferno LSX is offline   Reply With Quote
Old 06-24-2013, 10:01 AM   #25
hcoll003
hcoll003's Avatar
Thanks for the info on the tranny mounts guys. How much more hp do you think the mounts help put down at the rear wheels? I'm guessing something insignificant, like 2-3hp?
Old 06-24-2013, 10:39 AM   #26
GLGJR
Drives: 09 CTS-V
I have the Pfadt on my CTS V. We had to rotate to lower part of the mount 180* and drill a new locator hole in the subframe. I hope we will be testing them out soon.
GLGJR is offline   Reply With Quote
Old 06-24-2013, 06:13 PM   #27
hcoll003
hcoll003's Avatar
Dude, what a sick build!!! A freakin' turbo V!!! Nice my dad is pushing 595rwhp with the stock blower in his 12' Coupe.
Attachment 526922
Old 06-24-2013, 07:47 PM   #28
GLGJR
Drives: 09 CTS-V
Thank you very much.
ADM Performance has done a ton of beautiful work and fixed most of the stuff I did lol. I sold the complete engine out the car. It made 640/640 with the 1.9L blower through completely stock exhaust. I can't wait to break in the new combo.
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 06-07-2011 01:09 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
Pfadt Engine Mounts installed, first and second impressions... robertway Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 03-03-2010 10:35 AM
The BEST Break for a new car. "very long" Darin Morgan General Automotive + Other Cars Discussion 346 02-04-2010 07:49 PM
