sjm autoprod
Old 02-01-2014, 01:15 AM   #85
Knockoutpie
Knockoutpie's Avatar
Drives: 2014 2SS RS Coupe
Originally Posted by =Stephens= View Post
Knockout, you can tell a difference. All of my speakers in my car have replaced with aftermarket speakers. I don't even use any of the power from the Head unit, it all comes from the amps. The primary reason for replacing your head unit is the noise to signal ratio can be matched with the higher HU. If your stock HU is outputting 100, but your speakers are rated to over that you will never get the maximum out of your system.
I had to send in my dash kit to alpine for a recall, and had to put my stock head unit back in, I was still using the amps and subs, but I could never turn it up all the way with the stock head unit. I would get some distortion or also know as THD, total harmonic distortion. If I turned them up in volume, I would risk damaging my subs and speakers. So I just played it without cranking it. I hope I explained it correctly, this is how it was explained to me, my installer basically said don't crank it up real hard and you will be fine.
If you have your gains set properly you should be able to crank it. But good to know. I have my stock Mylink HU in and have some nice Rockford speakers all the way around. They sound great. But Mylink only is 22watt rms. Was thinking about adding a 2nd amp for the speakers. Not sure if I should though because I'm using the pac gm44 unit which is a loc that will support 2 amps.
Knockoutpie is offline   Reply With Quote
Old 02-01-2014, 12:36 PM   #86
cmoney89
cmoney89's Avatar
Drives: 2013 Camaro 2LT RS IOM
I've got 2 12 Sundown SD subs running off a JL JX1000/1D. Also have a JL XD 400/4 running the factory speakers for now.
cmoney89 is offline   Reply With Quote
Old 02-01-2014, 04:09 PM   #87
c5dreamer
Drives: Tacoma/2LTRS
Nice, are the 12s overkill for the factory speakers and the XD 400/4? Thinking of getting 2 12s too, and wondering if I really need to swap out the factory speakers.
c5dreamer is offline   Reply With Quote
Old 02-01-2014, 04:14 PM   #88
c5dreamer
Is that a ******** box?
Old 02-01-2014, 05:59 PM   #89
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
I got my Alpine back in my system now, so it isn't an issue. I was only out for 4 weeks. That was over a year ago.
=Stephens= is offline   Reply With Quote
Old 02-02-2014, 12:39 AM   #90
BudMC77
BudMC77's Avatar
Drives: 2011 Camaro 1LT
Originally Posted by Go big or Go home View Post
Mine is ported. The box design is a bit unusual but it does port into the cabin of the car.
Who makes your box? Is it custom built yourself?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
BudMC77 is offline   Reply With Quote
Old 02-02-2014, 03:48 AM   #91
Wink9110
Drives: 2012 Camaro 45th Anniversary
Audio HELP 2014 ZL1
I recently traded in my 2012 45th Anniversary Camaro SS for a 2014 ZL1. I need immediate opinion of where and if I can keep my factory Head unit with Navigation and add my 10" pro box sub and Focal Door Component Speakers without loosing my OnStar & talking on my Bluetooth thru my speakers. I really want to keep my bluetooth capabilities and factory head unit but this one Audio installer said that I haft to loose my on star and ability for my cell to come thru my speakers. I need your input if anyone has just added door speakers / back speakers & amp JL Audio 900/5 HD
Here is a pic of my 45th with the pro box installed (Sound Unreal!!)
Wink9110 is offline   Reply With Quote
Old 02-02-2014, 11:13 AM   #92
Go big or Go home
Go big or Go home's Avatar
Drives: 2010 Camaro 2LT RS
Yeah I built it myself..
Go big or Go home is offline   Reply With Quote
Old 02-02-2014, 03:02 PM   #93
BudMC77
BudMC77's Avatar
Any other pics of your setup? Build process? Or trunk view? Or box sitting outside your car?
Old 02-02-2014, 08:22 PM   #94
Go big or Go home
Here's a link to my stereo thread:
http://www.camaro5.com/forums/showthread.php?t=327663
All the details of the build are there, lots of pictures. I built the box inside the trunk and actually used the trunk lid to complete the box so there are no pictures of the box outside the trunk. It's a unique design but it worked out great.
Old 02-03-2014, 03:33 PM   #95
Knockoutpie
Nothing special like I had in my old truck, here's a thread I just found from a while ago when I had it, had 2 15" Rockford P3's and tuned the box to 20hz, that was fun!
http://www.gmt400.com/forum/showthre...703#post501703
Here's what I've got now :]
Old 02-03-2014, 08:03 PM   #96
gmpartsman
Drives: 2011 CAMARO 2SS IBM
how do you guys get these prefabbed big boxes in the little ass trunks these cars have.was thinking of getting a 2 12" ******** box but it looks like a pain to get in the trunk
gmpartsman is offline   Reply With Quote
Old 02-03-2014, 08:18 PM   #97
Knockoutpie
Gotta be smarter than the trunk to get the box in!
Old 02-03-2014, 09:59 PM   #98
Jus1dab
Jus1dab's Avatar
Through the rear seat. Lay it down, slide it in and then stand it up.
Jus1dab is offline   Reply With Quote
camaro, subs
Woodbury, CT Car Show Sun June 5th WoodburyMan USA - New England 4 05-24-2011 10:12 AM
Chevy Street Cruise to open Super Chevy Show Weekend in Houston Houston Raceway USA - Texas 0 08-08-2010 09:11 AM
The 2010 Pacific Coast Dream Machines Show Mindz USA - California 4 04-13-2010 09:41 PM
Consensus Feb 6th Plus lots of other key dates UCF w00t 5th Gen Camaro SS LS LT General Discussions 16 01-23-2009 12:39 AM
Global auto show scene in transition KILLER74Z28 General Automotive + Other Cars Discussion 0 09-08-2006 05:40 PM
