BeckyD@RodgersChevrolet
Old 10-24-2011, 06:21 PM   #1
BloodUSMC
Blood Sucking War Machine
Drives: Black 2011 Camaro 2LT/RS - A6
hypertech tune choices
i got my tuner in the mail today and i would like to get some feedback.
I changed my rev limiter to +500.
Transmission shift points.
+300 for all gears
Shift firmness 75%
Intake choice rotofab
What you guys think? Is this optimal, and safe?
I had the above settings but shift firmness was at 50% took it for test drive. Felt it shifting really hard but didnt chirp. I want to hear that chirp lol.
Also friday or saturday im going to the track to see if time improved. My last week best time was 14.32
Sent from my Evo Shift using Tapatalk
BLACK 2011 2LT/RS COUPE. Roto Fab Intake, MRT 1.0, OBX LT Headers, Magnaflow resonated x pipe, Trifecta Tune
BloodUSMC is offline   Reply With Quote
Old 10-24-2011, 07:14 PM   #2
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
tune should be easily returned to stock, and change back again, right? I would recommend running the stock tune, or your previous setting, then going to your new settings, all on the same day. good luck!
Old 10-24-2011, 07:21 PM   #3
BloodUSMC
yeah it takes 5minutes to change tune.
I didn't understand your post. did u mean u wouldn't recommend me chging tunes on the same day? if so y not?
Old 10-24-2011, 07:28 PM   #4
PoorMansCamaro
Drives: Really Slow
no, i'm saying you should change it while at the track. so you can compare your times from the same day, rather than a different day, when the temperature or track preperations are probably different.
I'm not sure if there is a learning curve for the hypertech tune though. For instance, i'm not sure if you have to drive 200 miles before the new tune kicks in.
Old 10-24-2011, 07:36 PM   #5
BloodUSMC
Oh i see. Yeah that make sense. I have 3 runs. So first i will run stock, second tuned. I will play with the tune on the 3rd run.
Thanks for the advice.
Old 10-24-2011, 07:40 PM   #6
BloodUSMC
Also i honestly dont feel any difference but when i am flooring it.
Old 10-25-2011, 07:58 PM   #7
cowboy1948
cowboy1948's Avatar
Drives: 10 LT2/RS-08 SILVERADO-05 COBALT
Cool
I put the hypertech tune in on a friday. Then put the port TB on the next friday. I ve been driving for about 2 1/2 weeks and it seemed to get alittle better each day. Alot more of the la has gone out of it.
Retired
cowboy1948 is offline   Reply With Quote
Yellow Lexus Type Fog Lights? phenixdragon Cosmetics and Lighting Modification Discussions 37 05-21-2017 10:49 AM
MarylandSpeed DYNO TESTED: Diablosport Predator Canned Tune on 2010 SS A6 MarylandSpeed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 05-18-2013 10:01 PM
Traficta tune or hypertech BloodUSMC Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 15 10-09-2011 11:01 AM
Standard vs Automatic Racing HarrisraTx Dragstrip and Launch Techniques Discussion 74 10-29-2010 09:26 PM
Its JUST a V6 ROD1 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 26 06-29-2010 02:57 PM
