ADM PERFORMANCE
Old 10-25-2011, 11:37 PM   #1
Ice Demon
Ice Demon's Avatar
Drives: 2010 Camaro SS
Alcohol burning LLT
Is it possible to convert a LLT engine from gas to alcohol not e85???? I know that it is not a problem to convert a engine that has a carb but is it possible to covert the LLT with direct injection?
Ice Demon is offline   Reply With Quote
Old 10-25-2011, 11:43 PM   #2
Mach
Mach's Avatar
Drives: White M6 1LT RS
If you have the $$$$ anything is possible!
Not to many gas stations sell alcohol last time I checked.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 10-26-2011, 12:18 AM   #3
Ice Demon
Ice Demon's Avatar
Yea I would have to buy a 55gal drum most likely and how much $$$ would it take to convert?
Old 10-26-2011, 08:40 PM   #4
Superfly1
Superfly1's Avatar
Drives: 2010 Camaro 2LT #2197
From what I remember on the race car, you also use twice as much methanol as gas too. All the pills in our injector almost doubled when we switched. You are probably looking at a new pump, bigger lines, injectors, throttle body, sensors, plugs, special tune, and who knows what else...
I imagine the cost would be far greater than the reward, but it would be interesting none the less.
CAI intake | OBX LT Headers | Flowmaster AT Exhaust | Trifecta Tune | SS Rear Diff, Axles & Driveshaft
Zex 100 Shot Nitrous | Konig Airstrike Wheels | Custom Engine Cover, Fuse Box & Underhood Bowtie
Eibach Springs & SS Sway Bars
| BMR Strut Brace | Drake Shifter | Vitesse Paddles | 13.26 @ 105.88 mph
Superfly1 is offline   Reply With Quote
Old 10-26-2011, 10:45 PM   #5
SC2150
We use 2.5-3 times the methanol vs gas in our drag motors. Very destructive fuel as far as the corrosiveness and the amount of water it wicks....probably could do it, just not anywhere near the power gasoline will give as the HPFP will not keep up if 2-3 times the fuel delivery is needed.
Join TEAM LLT social group RSokie Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 2849 02-10-2014 10:41 PM
my dyno today(base for e85 tune) bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 51 06-08-2011 12:35 PM
L99 Burning Smell At WOT nitto85 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 11-14-2010 07:39 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
