ADM PERFORMANCE
Old 10-26-2011, 12:18 PM   #1
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
BMR Weight Watchers Quest...
Everybody knows these cars are heavy but where is the weight? Better crash safety standards bring more air bags, sensors, and electronics, along with double and triple layered uni-body sheet metal panels and more rigid sub-frames. Higher luxury requirements requires more insulation and again more electronics and gizmos. The progressive trend towards larger diameter wheels makes a 65 lb. wheel/tire common place and now it takes a 26 lb. 14" rotor on all 4 wheels just to stop the thing. 14" rotors used to be the ultimate upgrade while now they have almost become the minimum standard necessary to stop these modern 2 ton cars.
It used to be physically possible to get a 4th Generation Camaro to 3100 lbs. while retaining a full interior, A/C and street wheels/tires. The 5th Gen is a different story and while all technological aspects of the 5th Gen are superior, it comes with a price. So how do they offer all of these new technological advances in the Z06 Corvette yet it only weighs 3100 lbs loaded? Aluminum, Magnesium, Titanium, and composites. It's hard to even find a steel component on a new Corvette, in fact I would be willing to bet that the majority of steel used in a Z06 is in the hardware holding it together! These exotic materials cost money of course and are the reason why a Z06 costs $80k and your Fifth Gen is under $40k.
Throughout the process of our suspension development, testing, and various forms of racing using our Project TriloG Camaro, we have had practically the entire car apart multiple times testing different combinations. We have a TH400 that we use for drag strip testing and a built T56 for road course and drivability testing. Over the last month the car was being built for a specific track and we wanted to get the car as light as possible. Along the way, if a part was off the car it was weighed. This is not a complete list of items, some of them were just weighed and re-installed or replaced but I figured you guys would like to know some of this information so I made a weight chart below:
ITEM
WEIGHT (LBS.)
LOWER REAR SEAT
10.2
UPPER REAR SEAT
28
DRIVERS SEAT
54.6
PASSENGER SEAT
44
A/C EVAPORATOR CORE ASSY.
13.4
A/C COMPRESSOR
13.2
A/C CONDENSER
6.4
A/C-HEAT BLOWER MOTOR ASSY
4.2
A/C LINES AND DUCTING
7.6
A/C FIREWALL COVER
3.6
DRIVERS AIR BAG
1.6
PASSENGER AIR BAG
5.4
SIDE AIR BAG (EACH)
3.2
FIREWALL INSULATION
2.8
FLOOR INSULATION
12
TRUNK CARPET AND WELL COVER
15.2
TRUNK COMPRESSOR
6
TRUNK-LID STRUTS (PAIR)
1
FRONT BUMPER
14.6
REAR BUMPER
26.4
RADIO
4
DOOR SPEAKERS (PAIR)
3.6
FLOOR MATS (FRONT PAIR)
4.8
CENTER CONSOLE
8.2
EMERGENCY BRAKE LEVER W/CABLES
6.2
FRONT SEAT BELTS (PAIR)
6
REAR SEAT BELTS (PAIR)
3.6
FRONT BRAKE ROTORS (EACH)
25.4
REAR BRAKE ROTORS (EACH)
24
FRONT CALIPERS (EACH)
11.4
REAR CALIPERS (EACH)
7.4
HOOD
25.3
HOOD INSULATION
1.2
HORNS (PAIR)
1.4
WIPER ASSEMBLY W/MOTOR
8.6
WINDSHIELD COWL PLASTIC
3.6
DRIVESHAFT – 6 SPEED MANUAL
24
FUEL TANK SHIELD
2.8
DRIVE SHAFT HEAT SHIELD
.8
STOCK AIR BOX
7
ENGINE COVER
4.4
CLUTCH ASSEMBLY (INCLUDING FLYWHEEL)
57
Of particular interest is just how light some of these components are. In the past you could save over 100 pounds by removing the air conditioning but with today’s highly efficient systems the weight is down to just 48.4 pounds for the entire system! The wiper motor, linkages, and wipers was only 8.6 lbs. combined and if you remove all 6 air bags out of the car you only save 13.4 lbs.
For this particular event the car did not need any creature comforts so the common weight loss tactics were employed (rear seats, one light weight drivers seat, A/C delete, etc) along with some other questionable weight removal such as insulation, sound deadener, etc. Keep in mind that a lot of these items will be going back in the car but we were able to shave 269 lbs. off the car! Basically everything that wasn’t necessary was removed. We also removed the bumpers which dropped 41 pounds by themselves. The rear bumper can be removed without any issues (off highway only) since the bumper cover does not use it for support. The front however, requires some sort of support to hold the nose stable at high speeds. We fabricated two “bumperettes” to accomplish this (shown below) and they only weigh 1 lb. each.
Our car has a custom 10 point chrome moly roll cage, Magnuson TVS supercharger, and Snow Performance alcohol injection kit adding a combined weight of 180+ lbs to an already heavy car. We at least wanted to offset that weight and get it back to the OE weight if possible. We were pleasantly surprised when we scaled the car and it weighed 3650 when all was said and done. While the current configuration is set up for the road course, this gives me a little hope that you could easily get these cars down below 3400 lbs. in drag race mode.
We achieved 3650 lbs. with all of the above components and the car outfitted with 20” CCW wheels and Wilwood 14.5” diameter brakes. A set of 17” Weld Drag wheels and tires can easily drop another 100 lbs. Lightweight brakes and a naturally aspirated motor could pull another 150-180 lbs. off the car bringing it down below 3400 lbs. I am also convinced that a 3-link or torque arm-equipped solid axle conversion using a 9” rear with aluminum center could knock another 100-200 lbs. off the car if someone was building a hardcore street/drag car. This is finally getting the car down into 4th Gen territory.
Most people will never go to these extremes but regardless this information is interesting and since we are gathering this data anyways I figured I would throw it out there for you guys to use however you wish. Ultimately, the lighter the car is the more responsive it will be while
handling, accelerating, and braking.
BMR guy is offline   Reply With Quote
Old 10-27-2011, 06:40 AM   #2
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
Awesome! Thanks for the info!
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Old 10-27-2011, 07:59 AM   #3
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
Cool.
1977and2010 is offline   Reply With Quote
Old 10-27-2011, 08:13 AM   #4
Black5thgen
Drives: 2007 C6
It seems like GM did everything they could to keep the weight down. I hate to say it but I think we're fighting a losing battle with the bulge.
Black5thgen is offline   Reply With Quote
Old 10-27-2011, 10:57 AM   #5
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Good resource for future Biggest Losers.
I decided just to stick with the basics: exhaust, wheels, passenger seat, etc.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 10-27-2011, 01:32 PM   #6
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Padre
We definitely figured it was some good information for people to have. We know most people won't go as far as we did but atleast the data is out there.
BMR Sales is online now   Reply With Quote
Old 10-27-2011, 03:38 PM   #7
gotpball44
Boost Is Your Friend
gotpball44's Avatar
Drives: 2016 Hyper Blue 1SS Camaro
Send a message via AIM to gotpball44
Can you guys make and sell bumperettes that go all the way across for front a rear? So we can have a light weight bumper support option that we can buy.
gotpball44 is offline   Reply With Quote
Old 10-27-2011, 04:18 PM   #8
BMR Sales
BMR Sales's Avatar
Drives: Race Car
If we can get enough interest we could definitely build something like that for the guys looking to lose a little extra weight.
Old 10-27-2011, 04:35 PM   #9
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
I'd be in for a set of front and rear as long as the net gain was close to the total weight of the two bumpers. No point in replacing something heavy with something else heavy.
HufferSS is offline   Reply With Quote
Old 10-27-2011, 06:54 PM   #10
Three of Swords
Three of Swords's Avatar
Drives: 2011 IBM 1SS/RS L99
Great info! Thanks for taking the time to post.
Three of Swords is offline   Reply With Quote
Old 10-28-2011, 04:36 PM   #11
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
There is definitely no easy way to lose a significant chunk of weight while retaining 100% streetability. Those that are willing to sacrifice a few things can probably drop 100 lbs. or so permanently without compromising too much. 100 lbs. is a tenth at the drag strip and you can pull that off pretty easily. It's the next 100 that forces you to evaluate your dedication to weight loss. Below are a few simple things (in order of compromise) that will net the easiest reduction:
Round 1 - Road course / AutoX / Drag strip:
This would be the entry level to weight loss, kind of like trimming a few pounds for the class reunion.
1) Rear seat delete - 38.2 lbs. - this is a simple mod that can easily be re-installed after a day at the track.
2) Aftermarket front seats - up to 50 lbs. - There are plenty of really nice aftermarket seats from Sparco, Recaro, Corbeau, etc. that can drop a lot of weight if you are willing to give up your power features.
3) Coil-overs - up to 15 lbs. - smaller springs, aluminum components, etc. help make aftermarkecart coil-overs lighter than the OE parts and you get improved valving and spring rates at the same time.
4) Remove the dead weight - 30 lbs. - For a day at the track you can easily ditch the floor mats, plastic engine cover, trunk compressor and well cover. These items re-install in no time and don't compromise anything at the track.
133 pounds total and 65 of it is permanent.
Round 2 - Drag strip:
1) This one is easy. Install a set of drag wheel and tires. This will net you 100+ lbs. instantly and is just a wheel swap away. Not really a permanent weight reduction, kind of like using a girdle to hide the bulges.
Combo 3 - Drag strip:
This is the round where mods start changing the versatility and usability of the car. Most people would never consider the majority of these mods but the hardcore dragstrip racers have been doing them for years. Some weights shown below are estimated since products are not available yet except through custom fabrication.
1) Bumper deletes – Knocks 40+ pounds off the car but not recommended for street use for obvious reasons.
2) Lightweight Braille battery – Save 38 lbs.
3) V6 or aftermarket light-weight brake kits – Aluminum centered 12” rotors with a lightweight Wilwood or Strange caliper could easily save up to 60 lbs. over the 136 pounds of OE calipers and rotors. Will not perform as well as the OE brakes but still completely streetable.
4) Tubular front and rear cradles – Save 20+ lbs. each.
5) A/C delete – 48 lbs.
6) Power steering delete – 12 lbs.
7) Horns, wipers, radio and insulation removal – save 35+ pounds
8) Solid rear axle conversion – up to 150+ pounds
9) Composite panels – Sebon makes carbon fiber trunk lids, hoods, fenders, and doors already. I would imagine you could save at least 40 lbs. with these parts if you replaced all of them.
There are probably a few things I forgot about and a bunch of little things I didn't even mention that can knock another 30-50 lbs. off the car. As you can see if you want to get crazy, you can drop over 700 lbs! or depending on how you look at it...
Old 10-28-2011, 08:31 PM   #12
Synner
Drives: 2011 2SS/RS M6
Well go ahead and get to making them already.
Old 10-28-2011, 08:55 PM   #13
Farks Supercars
Farks Supercars's Avatar
Drives: F1R 2010 Camaro
Im an 3620 lbs right now with a full cage and still have both stock seats and front and back crash bars in. Gonna see how much I can get that down this winter!! I thought about fiberglass doors, but roll down windows are too awesome.
I noticed your weight distribution at 53.5% on the front, im at 51% on the front.
Couple things for drag only cars:
Trunk mounted fuel cell
Front sway bar removed
BTW your trailing and toe arms work awesome!
Farks Supercars is offline   Reply With Quote
Old 10-30-2011, 05:05 AM   #14
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Soon as someone makes an affordable front/rear tubular kmember, I"m all over it. The xtreme piece is way too pricy for me. v6 brake and 2pc rotors def save weight, but again, pricy as all get out...
DietCoke is offline   Reply With Quote
1 inch and 1.4 inch BMR Lowering Springs Now Available At APEX Motorsports!!!!!!!!!!! Apex Motorsports Suspension / Chassis / Brakes 273 04-25-2016 05:17 PM
Apex speed and BMR NOT GOOD! tbss1 Suspension / Brakes / Chassis 29 08-04-2011 03:00 PM
BMR endlinks failure.... my experience! ssmike Suspension / Brakes / Chassis 10 07-06-2011 11:51 PM
weight loss CamaroSpike23 Off-topic Discussions 8 09-17-2009 07:16 PM
