Caryle Racing
Old 10-28-2011, 12:24 AM   #15
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Originally Posted by syr74 View Post
Dude! I cannot believe that you were unfamiliar with the 1LE prior to today! Personally, I always thought of the 1LE as a F-Body counterpart to the Z51 Corvette, albeit a lot more livable as a daily driver when compared to the fairly rough C4 Z51 package.
I know very little about the 3rd gens. I know even less about the 2nd gens.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 10-28-2011, 08:25 AM   #16
IOMZL1
IOMZL1's Avatar
Drives: 2017 Viper ACR Extreme
Also was available for the 4th gens. You learn something new every day though. Glad to see it return - even if only in concept form.
IOMZL1 is offline   Reply With Quote
Old 10-28-2011, 08:58 AM   #17
toilets
Drives: 2010 camaro
So, is this going to be like the ZR1 to Z06 kind of deal?
for example, the Zl1 camaro will still be king and actually be quicker on a race track than the 1le? like the Zr1 vs. the Z06. Or is this more along the lines of a full on race "track pack" designed to be quicker than any other camaro?
I guess what im getting at is this approach going to be that the 1LE is the Z06 of corvettes and the Zl1 is the ZR1 of corvettes?
toilets is offline   Reply With Quote
Old 10-28-2011, 09:03 AM   #18
LOWDOWN
Downright Upright
Drives: Daily
Not without an LS7...
LOWDOWN is offline   Reply With Quote
Old 10-28-2011, 09:08 AM   #19
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
Really looking forward on this one!
Hopefully this is the Boss killer!!
Old 10-28-2011, 11:07 AM   #20
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
2cnd chance is offline   Reply With Quote
Old 10-28-2011, 11:12 AM   #21
garcmol
garcmol's Avatar
Some 1LE history; I likes 3rd Gens!!
What The 1LE consisted of: (Categorized & Year By Year)
In 1988, the secret showroom stock racing 1LE option (option level 0 IROC-Z) was first available; however, only 4 were produced. Then in 1989, the option became more well-known as 111 were produced that year. The package was obtained by ordering the following:
Level 1 IROC-Z with 5.0 TPI engine (LB9) with 5 speed or 5.7 TPI engine (L98) with 4-speed automatic. These Camaro's had 145 mph speedometers and 5500 rpm redline tachs. Optional axle ratio (G92) (305/3.45, 350/3.27) and its required options G80 Limited-Slip rear axle
Package consisted of (G92 Was Ordered With A/C) [Street Vehicle]:
engine oil cooler 4-wheel disc brakes Performance exhaust system (N10) (dual catalytic converters) Tires P245/50 ZR16 Goodyear Gatorback
Note:
G92 ordered WITH A/C was classifieds as a Street vehicle.
G92 ordered WITHOUT A/C was classifieds as Race series.
Package consisted of (G92 Ordered Without A/C) [Race Vehicle]:
Aluminum driveshaft (JG1) (part # 10085375) G80 Differential with limited slip with 3.42 posi rear G92 Rear axle performance package Big front brakes adapted from the Corvette Larger (11.86 inch) front rotors (part # 18016035) Larger front spindles (part #'s 18016737 / 18016738) PBR front, dual-piston aluminum calipers (part #'s 10132827 / 10132828) Special swinging fuel pickup in gas tank and special 18 gallon baffled fuel tank for fuel pickup down to .5 gallon reserve to prevent fuel starvation in hard cornering specific front and rear shock absorbers Lower control arms (part # 10164151) Special deflected disc shocks Air conditioning delete (C41) (standard heater) (weight savings and better air flow to the radiator) Fog lamp delete (to release the air intake located behind) T-Tops delete Power accessories delete Aluminum spare wheel with smaller spare tire (N64) A Few RARE ones came with special 16" x 8" light alloy mesh wheels (XWL)
[edit]Yearly Information on the 1LE Option:
1988
Chevrolet built 4 "1LE" 1988 Camaro's for the SCC A Showroom Stock racing series. The reason only 4, virtually unknown to most Camaro racer-types at the time.
1989
Chevrolet built 111 "1LE" 1989 Camaro's for the SCC A Showroom Stock racing series. But 1LE wasn't ordered like other RPOs. Ordering the RPO G80 Limited-slip rear axle & G92 performance axle with an IROC-Z Coupe triggered the 1LE RPO. Here's how it worked: When G92 was ordered, it forced several other options including engine oil cooler, 4-wheel disc brakes, dual converter exhaust and P245/50ZR16 tires. A 1989 Camaro with G92 had to have either the 350ci (RPO B2L) engine with 4-speed automatic transmission, or the 305ci (RPO LB9) with 5-speed manual. These Camaro's had 145 mph speedometers and 5500 rpm redline tachs. If RPO G92 was ordered with air condition ing, the cars were built as street vehicles. If air conditioning was not ordered, Chevrolet added 1LE equipment for the race series. This included aluminum drive shaft, big front brakes adapted from the Corvette, fuel tank baffles, specific front and rear shock absorbers, and different jounce bumpers. Also, fog lamps were deleted for weight savings and better air flow to the radiator.
1990
Chevrolet built 62 "1LE" Z28 Coupes for the SCCA Showroom Stock racing series with RPO G80 Limited-slip rear axle & G92 RPO G92 performance axle triggering the build. RPO G92 required one of two engine combinations, the 305ci LB9 V8 with 5-speed manual, or the 350ci B2L V8 with 4-speed automatic transmission. When ordered with air conditioning, RPO G92 included engine oil cooler, 4-wheel disc brakes, and dual-converter exhaust. When ordered without air conditioning, RPO G92 added heavy-duty front brakes adapted from the Corvette, aluminum driveshaft and spare wheel, special shocks and fuel pickup, and gas tank baffle. Fog lamps, normally included with IROC models, were deleted for weight savings and better air flow to the radiator. Option cost for RPO G92 equipment with air conditioning was $466.00. The cost when air conditioning wasn't ordered was $675.00.
1991
Chevrolet built 478 Z28 Coupes with "1LE" equipment for 1991. The exact amount of true 1LE's is not known this year as a majority of the 478 units were "B4C" Special Service (or Police package) RS Camaros which had the 1LE front brakes (1LE brakes were a mid year option on the 91 B4C as it was quickly realized that the standard front brakes were not suitable for police use -thus some B4C's got the 1LE brakes and some did not). As in 1989 and 1990, Ordering the RPO G80 Limited-slip rear axle & G92 RPO G92 triggered the build. RPO G92 required one of two engine combinations, the 305ci LB9 V8 with 5-speed manual, or the 350ci B2L V8 with 4-speed automatic transmission. When ordered with air conditioning, RPO G92 ($466) included engine oil cooler, 4-wheel disc brakes (except for a brief period when 4-wheel discs were deleted with a $287 credit), and dual-converter exhaust. When ordered without air condi*tioning, RPO G92 ($675) added heavy-duty front brakes, aluminum driveshaft and spare wheel, special shocks and fuel pickup, and gas tank baffle. Fog lamps were deleted for weight savings and improved cooling.
[edit]1992
Chevrolet built 705 Camaro's with "1LE" special performance components equipment for 1992. Of the 705 units, 589 of these were the "B4C" Special Service (or Police package) cars which all included the 1LE front brakes. Content was different in the B4C as air conditioning was standard and the aluminum driveshaft, spare tire and other heavy duty suspension components were not included. In reality there were only 116 1LE "race prep" cars produced. As in 1989, 1990, and 1991, Ordering the RPO G80 Limited-slip rear axle & G92 RPO 1LE was triggered by RPO G92. RPO G92 required either the 305ci LB9 V8 with 5-speed manual, or the 350ci B2L V8 with 4-speed automatic transmission. When ordered with air conditioning ($466), RPO G92 included engine oil cooler, 4-wheel disc brakes, and dual-converter exhaust. Without air condition ing ($675), RPO G92 added heavy-duty front brakes, aluminum driveshaft and spare wheel, special shocks and fuel pickup, and gas tank baffle. Fog lamps were deleted for weight savings and better air flow to the radiator. Available for Z28 Coupes only.
1992 should be recognized as the peak of 3rd generation performance with the two models, the B4C Special Service package and the 1LE Race Prep package being the most covetted for collectors as both were produced in relatively low numbers and each had different content. The 1LE was the best handling and lightest package available, although the B4C had most of it's content and was the only way to get the big heavy duty racing brakes along with air conditioning and power windows/locks and mirrors if you wanted them.
[edit]1993
Chevrolet built only 19 Camaro's with "1LE" equipment for 1993. This included larger diameter front and rear stabilizer bars, stiffer shock absorber valving, harder durometer control arm bushings front and rear, power sterring cooler, and radiator baffles for added engine cooling. Air conditioning, power windows/locks or mirrors was not available with 1LE.
[edit]1994
Chevrolet built 135 Z28 Coupes with "1LE" equipment for 1994. Content changes slightly as the rear sway bar for 1LE and Z28 are the same (downsized from previous year) and the new Koni double adjustable shock absorbers becomes available as factory installed content in the 1LE.
[edit]1995
Chevrolet built 106 Z28 Coupes with "1LE" equipment for 1995.
[edit]1996
Chevrolet built 55 Z28 Coupes with "1LE" equipment for 1996. Air conditioning becomes standard in all camaros including the 1LE cars which was previously unavailable. Other power options are still restricted in the ordering process.
[edit]1996
[edit]1997
Chevrolet built 48 Z28 Coupes with "1LE" equipment for 1997.
[edit]1998
Chevrolet built 99 Z28 Coupes with "1LE" equipment for 1998. If 99 were built why do the production number say none were built? I know where there is an SS 1LE. According to SLP it is the only one.
[edit]1999
Chevrolet built 74 "1LE" equipped camaros for 1999.Of these 74 units, 66 were Z28 and 8 were SS optioned (one of the SS's was an automatic and would be quite the collectible today!) This is the last year of the 1LE as installed from the factory. SLP adds 1LE as an option in later years but does not include previous content and is not factory installed by GM.
Old 10-28-2011, 11:17 AM   #22
OldScoolCamaro
Note:
1988
1989
1990
1991
[edit]1992
[edit]1993
[edit]1994
[edit]1995
[edit]1996
[edit]1996
[edit]1997
[edit]1998
[edit]1999
Great historical info, thanks!. I don't remember the pricing...do you have those numbers for a matter of reference.
Old 10-28-2011, 11:32 AM   #23
garcmol
garcmol's Avatar
I've been looking for old pricing too.
Old 10-28-2011, 11:37 AM   #24
LOWDOWN
Downright Upright
Drives: Daily
As the attached table will show, the '86 A4Q (the only '86s with L69-305 carb'd engines) and '87 A4U F-cars (IROC and T/A) predated and contributed the direct development of the 1LE package, which arrived in '88 (again, on both Camaro and Firebird). By 1989, the "Canadian" package was re-assigned the R7U option code.
http://www.playerschallengeseries.ca/Production_nos.htm
ALL R7Us are 1LEs...but NOT all 1LEs are R7Us...
Imagine being able to go to your local Canadian Chev or Pontiac dealer and being able to buy a roll-caged BIG-braked exhaust-dumped F-car right off the showroom floor! A4U-A4Q-R7U made that possible...and I sold three of 'em...
The Canadian MSRP, for these very special cars, was about $17,500, circa '86-'88.
The Player's Challenge races paid $5,000 to win, $4,000 for 2nd, $3,000 for 3rd, $2,000 for 4th, and $1,000 for 5th...plus a new set of Goodyears for each of those positions. Good money...and a possible good ROI...
The Team we sponsored in '86 won $10,000...and all the tires they needed for the season. They missed one event, and still finished 6th Overall. Repairs at year-end was less than $500, total. They sold the car for $12,000...a pretty cheap season of racing!
Some Teams wrote off more than one car...
Old 10-28-2011, 12:21 PM   #25
LOWDOWN
Downright Upright
Drives: Daily
The 1LE option price varied from year to year...and even during the MY. There were supply issues and/or "re-rationalization" of including the adjustable Konis. Without the Konis, the RPO price for 1LE was about $500 in '95 as an option on the one-of-two Firebird Formula I sold. With the Konis, near $1,000. That was NET, as there were no credits for deleted features.
Old 10-28-2011, 12:53 PM   #26
OldScoolCamaro
While only a concept, it borrows production components from both the Camaro SS and forthcoming Camaro ZL1 to deliver a competition-ready package.
Verbage sounds hauntingly familiar to another thread discussed here about the 26th letter of the alphabet with the numbers 2 and 8, doesn't it Lowdown?
Old 10-28-2011, 12:58 PM   #27
garcmol
garcmol's Avatar
That would be cool. Or to see the SSX hit the showroom...... or both
Old 10-28-2011, 01:20 PM   #28
2cnd chance
For the same reasons that the SSX and the 'track pack' are there
But according to the listing above the 1LE's built were Z28's first with a 1LE option added. In other words the 1LE's were Z28's+. Also wasn't the ZL1 information (before known to be a ZL1) in the Z28 threads not general?
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
GT5 Camaro pics brantley847 Camaro Photos | Spyshots | Video | Media Gallery 93 05-27-2013 09:35 PM
SEMA Show 2010 - New Camaro Products Showcase - pictures & descriptions! Sean@Phastek Camaro Photos | Spyshots | Video | Media Gallery 59 06-23-2011 01:56 PM
