Old 10-28-2011, 09:16 AM   #1
Larz29
Larz29's Avatar
Drives: 2010 camaro ss LS3 cyber grey
AAC LED fog light bulbs both went bad. void the lights part of the warranty potential
So let me start by saying I don't want to get too deep into the blame game but let me give you my situation with AAC fog light bulbs.
The good:
Super bright and very sweet looking.
Easy to install.
The bad:
So I installed these bulbs around the April timeframe. When I called AAC to order them, I asked if they are a direct replacement, and will not void my factory warranty? They stated that no ballast is needed, and they said these bulbs are a direct replacement and will not void my factory warranty, and will not cause any electrical problems. So the lights we're working up until about 2 weeks ago. No abuse, no out of the ordinary use. As a matter of fact I only used them a handful of times. So I took my car to the dealer and they diagnoced the electrical and lights. They indicated the lights are bad and the reason is the current is off, and a sensor within the electrical for the lights possiblly caused the problem. Also, he said both lights are bad as well. This is not the first time I had a problem with aac parts. I feel bad knocking on them, but I think people need to know this info to make an informed decision before altering your fog lights with AAC LED replacements. Thank god they didn't charge me anything, but a lesson learned for sure.
Larz29 is offline   Reply With Quote
Old 10-28-2011, 09:25 AM   #2
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
Hello Larz, if the GM tech says that there is no current going to the fog lights that is the reason that they are not turning on. Did the technician check the fuse or do any further diagnostics?
It it very common for the dealership to blame any problems with the car on aftermarket parts. We have seen them blame problems with the radio, for example, on an aftermarket intake being installed.
If you would like to speak to one of our techs I am sure we can help troubleshoot. Give us a call 1(800)407-5776.
Edit: Could you have the technician that looked at your car call me please? (504)835-0055 ask for Justin.
The good:
Easy to install.
The bad:
www.AACstyle.com
AACstyle is offline   Reply With Quote
Old 10-28-2011, 09:25 AM   #3
Jus1dab
Jus1dab's Avatar
Are they plasma lights?
Jus1dab is offline   Reply With Quote
Old 10-28-2011, 09:28 AM   #4
linkwpc
The punching cat
linkwpc's Avatar
Drives: '10 Camaro SS Black W/Hugger&W/IOI
I will never buy AAC stuff. My AAC fog lights died in two days...
My car build (COTW 7/23/12) - - - - - - > CLICK HERE! : http://www.camaro5.com/forums/showthread.php?t=80725
linkwpc is offline   Reply With Quote
Old 10-28-2011, 09:30 AM   #5
C586
Drives: 2011 Camaro LS
Yea. I have a couple of the "kitt" lights and when strobing on red and blue half the red ones are blue. All their stuff is overpriced to. Everyone has problems with their bulbs.
C586 is offline   Reply With Quote
Old 10-28-2011, 09:39 AM   #6
AACstyle
AACstyle's Avatar
The RGB night rider scanner is designed to have half blue/ half red strobing. That is one of the functions.
www.AACstyle.com
Old 10-28-2011, 09:42 AM   #7
white ss
white ss's Avatar
Drives: 2011 white ss
i have had good luck with all my stuff from aac... white and amber halos... markers...and fogs...i luv them....sorry for your issues...but i bet they will help ya out..
white ss is offline   Reply With Quote
Old 10-28-2011, 09:56 AM   #8
Shuffler
God Bless Dawson
Shuffler's Avatar
Drives: Synergy for my Daughter
Lol I have had no problems with AAC. The OP has a problem with his dealer. He's evidently unaware that some dealers will do anything to keep from warranteeing a part. A bulb pulling a different current will only cause the system to think a bulb is out if anything. A car manufacturer who would make a car that could be disabled by a wrong bulb would not be around long.
Your statement is far beyond misleading. It's just downright untrue.
Shuffler is offline   Reply With Quote
Old 10-28-2011, 09:58 AM   #9
Larz29
Larz29's Avatar
correction: My fault by saying the bulbs are bad. Something in the wiring or current or something is off. I know LED lights draw less current than general purpose lights. So I apologize for stating the bulbs are bad
Old 10-28-2011, 10:18 AM   #10
DraggnFrameGMC
DraggnFrameGMC's Avatar
Drives: 2011 Synergy Green Camaro LT
Like everyone else said, dealer is trying to put it off. They will do absolutely nything to get out of warranty work, which I find weird because GM pays them to do the work, its just not the $120/hr they would get if YOU were paying them. And no worries, they cannot void your warranty for aftermarket parts..........its a FEDERAL CONSUMER LAW prohibiting them from doing so. And i've been installing AAC for a few years and have not had any significant issues and if you do have one they are quick to help you out.
DraggnFrameGMC is offline   Reply With Quote
Old 10-28-2011, 10:23 AM   #11
DJBullitz
DJBullitz's Avatar
Drives: 2011 Camaro 2SS
NOT EVERYONE
This is not correct. I have AAC almost every where I can on my car in and out. My plasma DRL's have been installed and working since January 2011.
You need to restate your post to read "I had problems" as you cant say everyone.
Just saying speak up for yourself and not the world.
And lo and behold it was not the lights...
DJBullitz is offline   Reply With Quote
Old 10-29-2011, 09:15 PM   #12
C586
Yea. And when on that mode the blue half is purple because half the less are red and half are blue on the blue half. And its not supposed to be that way. And my dealers all get paid the same no matter who pays for it. One gets 93 an hour and the other gets 105 an hour.
Old 10-30-2011, 06:55 AM   #13
~Stacy~
~Stacy~'s Avatar
Drives: 14 camaro 16 sentra
AAC
My guess is your dealer is one of those who are too lazy to figure out the problem and blame one aftermarket part. My dealer is just the opposite. They installed all of my AAC products I had a problem with my headlight switch not working they couldn't find any issues but they still ordered me one and did not complain about my aftermarket lighting issues. AAC products have all been running great. I had a few issues going on with the sidemarkers and reverse lights a few times but Jon took great care of me
~Stacy~ is offline   Reply With Quote
Old 10-30-2011, 08:16 AM   #14
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
aac halos and sidemarkers...had a prob with sidemarker and aac was quik to replace it...we all know there are/were some issues with moisture and i believe aac has corrected that problem...they are good to respond to issues and as much stuff as they sell, there are def gonna have issues....but service has been good from 98% of the people i have seen and talked to...my service with my led was excellent...could not of been better...now if you needed a heater hose for the 2012 camaro and went to the only company that sells them, which by the way is a multi billion dollar company{gm}...you could be waiting 6-8 weeks for this part....fog lights are not rocket science....any decent tech with a test light, should be able to test fogs and switch...when fogs are turned on , it completes a circuit which sends power to fogs...if there is no power to fogs, then it is not aac fog lights...imo...good luck..keep us informed..
mikepage0007 is offline   Reply With Quote
AAC Halo Fog Lights Function Judge Cosmetics and Lighting Modification Discussions 7 09-12-2011 03:48 PM
Those with LT's, RESET your check engine light! TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 107 08-18-2010 01:51 AM
Laws Protecting Consumers for Aftermarket Parts strauchpete Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 9 01-17-2010 08:31 AM
Some Texas Lighting Laws Mecha USA - Texas 5 10-20-2009 01:49 PM
IMPORTANT Part 1 Warranty Disputes Zeus Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 11 08-25-2009 11:37 AM
