Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 10-30-2011, 08:45 AM   #1
Brents91z28
Drives: z28
How do I determine how many splines my axles are?
My rear end is making a terrible roaring noise but doesn't do it under load. Anyone know how many slpines are on the axles? Jegs offer axles replacement but there's to diff spline counts 26 and 28.
Brents91z28 is offline   Reply With Quote
Old 10-30-2011, 08:56 AM   #2
toesuf94
toesuf94's Avatar
Drives: THR #11 E-force supercharged
Send a message via MSN to toesuf94
Pull one out! Simple as that.
Or, check your SPID code for the rear end of your 91 and use that information to order new axles after checking with the dealer to confirm. I am 99% certain that the rear axles in a 91 Z28 with the G92 limited slip rear are 28 spline.
Also: That should have the G92 limited slip as it is a Z28 - make sure the additive for the limited slip is in your rear end housing or it will howl and you will hear a clunking noise when backing up as the rear end binds.
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
toesuf94 is offline   Reply With Quote
Old 10-30-2011, 09:29 AM   #3
Brents91z28
Drives: z28
preciate it. I just bought it, was thinkin bout putting a whole nother rear end under it but if I can upgrade it would rather do it that ways. Also you wouldn't happen to know of upgrading the rear brakes would you?
Old 10-30-2011, 09:33 AM   #4
toesuf94
toesuf94's Avatar
There are lots of upgrades for brakes...yours should have rear disks already. If not, I am curious of what the codes under the center armrest say.
Old 10-30-2011, 10:01 AM   #5
Brents91z28
Drives: z28
Yeah ive got disk just changed the rear pads and resurfaced the rotors yesterday. Is there a dual piston out there?
Old 11-05-2011, 09:22 PM   #6
The Project
Don't Mess with the Zohan
The Project's Avatar
Drives: 89 IROC
89 was the year they started to put 28 spline axels in. If your 91 is original rear, it's a 28 spline. Might want to pull and count anyway.
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you."
The Project is offline   Reply With Quote
Driveshaft Shop axles, The real reason they work so well.... Driveshaftshop V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 52 03-11-2014 02:01 PM
Best Deal on DSS Camaro 2010 - 2011 Axles & Powder Coated Paschal Performance Transmission / Driveline 2 07-15-2011 11:31 PM
Gforce Engineerings 4340 and 300m axles for the 5th Gen Camaro GFORCE1320 Transmission / Driveline 12 12-04-2010 09:53 PM
Best Deal on DSS Camaro 2010 - 2011 Axles Paschal Performance Transmission / Driveline 8 09-19-2010 12:23 AM
Hot Deal For DSS 2010 Camaro Axles Paschal Performance Transmission / Driveline 3 03-04-2010 09:36 PM
