Old 11-01-2011, 06:54 PM   #1
mypuppysirius
mypuppysirius's Avatar
Drives: 2011 Cyber Grey V6
Ported throttle body and CAI still show good gains?
if you have a CAI and get a Ported throttle body, will you still see some good gains from the Ported TB? or with they dilute each other a good respectable amount?
mypuppysirius is offline   Reply With Quote
Old 11-01-2011, 07:58 PM   #2
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
i have a injen CAI and i recently installed a ported throttle body. I can't speak to exact hp numbers, but after i installed the TB i noticed a noticable increase in the low-midrange rpms. Also, there was an imporvement in throttle response. I have had my CAI for 2 years, so the performance increase from that has become normal for me, however after i installed the tb i did notice my car responded better.
JohnZ is offline   Reply With Quote
Old 11-01-2011, 08:28 PM   #3
SC2150
Depends on if it is a hand ported or a CNC cut TB. Both are worth it for the throttle response and the CNC unit will give additional power.
Old 11-01-2011, 11:14 PM   #4
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
I can offer up this from my setup. My first mod was a CAI Inc intake. helped with throttle response and sound of course. Still lagged though when i punched it. I added a CNC Vmax TB and all the lag was gone and it had some giddy up. This was short lived though as very shortly after install the car was hesitating and surging. Would bog down on the shifts as well. I discovered i had a "weak" MAF sensor. I dropped in a "strong" one and presto. Everything cleared up and it now runs like a champ.
It was determined that once i added the additional airflow from the TB along with the intake that the weak MAF could not handle that properly. With the combination i have now it has way better response than stock. My 1/4 times dropped by about 2 tenths as well.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 11-01-2011, 11:15 PM   #5
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
thanks to tracy, i just received my CNC TB this evening. took all of 15 min to swap out. i've already got the Injen CAI, LT headers w/ hi-flo cats, and exhaust. i haven't really had the opportunity to test it out yet...that'll come tomorrow. but what i did notice is that at low idle, the peddle i normally use to cruise through the neighborhood is more than what i need now. at 15mph it was that noticeable.
im 99.9% sure that everybody who has added a ported TB has some kind of intake sitting right in front of it. and i haven't seen anybody post a negative comment or negative feedback on the ported TB yet. if you still have questions...do a bit more research. there is a lot of info and testing that has already been done.
good luck
hapisok is offline   Reply With Quote
Old 11-01-2011, 11:19 PM   #6
mypuppysirius
Thanks hapisok. I appreciate the input. Time to start saving up some more cash money.
Just for fun, does anyone have any before and after pic to kind of show how much of a difference it make inside of it???
I know there is an awesome write up of the process, but there wasn't a before pic.
Old 11-03-2011, 10:44 AM   #7
hapisok
hapisok's Avatar
left is before...right is tracy's cnc'd throttle body. best mod I've invested in so far.
Old 11-03-2011, 12:12 PM   #8
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
I am going to see Tracy on Saturday for the install.
Just out of curiosity, I see no difference between the 2 (but obliviously there is a difference), can you point to what is different.
FSP tuned: 377/389
Old 11-03-2011, 12:26 PM   #9
efpardo
Deep6
efpardo's Avatar
Drives: 2016 Camaro #182300 | 2SS | HBM
Send a message via Skype™ to efpardo
I've got one on order. Wish I had ordered it sooner to try it out on the track on Saturday.
My Journals:
Erick's Mistress - Violet 2016 2SS
#182300 | 2SS | HBM |
Erick’s Mistress - 2010 2LT
#8212 | 2LT | RS | CGM | Litho #165 |
efpardo is offline   Reply With Quote
Old 11-03-2011, 02:45 PM   #10
hapisok
hapisok's Avatar
if you look at the thickness of the wall...the opening of the one on the left is much thicker compared to the one on the right where it has been CNC'd out.
Old 11-03-2011, 03:13 PM   #11
nyrfan
Let's go Rangers!
nyrfan's Avatar
Thanks, that what I was thinking might be the difference are staring at the pic.
FSP tuned: 377/389
Old 11-03-2011, 03:13 PM   #12
hapisok
hapisok's Avatar
Old 11-03-2011, 03:14 PM   #13
nyrfan
Let's go Rangers!
nyrfan's Avatar
Thanks again.
FSP tuned: 377/389
Old 11-03-2011, 03:21 PM   #14
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: Longest things on Earth
same exact setup and time frame!!definately a good choice! my results are indentical.
its a syn is offline   Reply With Quote
CAI and ported throttle body question eL_777 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 10-21-2011 11:06 AM
VMAX Ported Throttle Body The good and the Bad Snake Slayer Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 95 07-14-2011 01:05 PM
