Caryle Racing
Old 11-02-2011, 12:15 PM   #1
Pt_killa
Pt_killa's Avatar
Drives: Black 2010 Camaro V6
FTI 3600 Stall Converter Installed!!!
After 52,000 miles of car abuse, 2 weeks ago I finally decided to put in a FTI 3600 stall converter from RX Performance. The car runs like a champ now. With my mods, I am able to bring the rpms up to about 3000-3200 without breaking the tires loose from a stand still. The car feels great and drives like near stock on the street. FTI builds a top class converter, there is very little slip at low speeds and my gas mileage has hardly suffered. You can hardly notice the stall is there when lightly cruising. I do use sports mode now since it holds the gear longer.
Also while cruising in lower gears, smashing the gas sometimes causes the tires to chirp even with traction control on, lots of fun for some inoccent showing off. The car pulls much stronger than before and the turbo is able to get into boost at lower speeds helping with acceleration even more. However, when cruising at highway speeds and the roads are wet, smashing the gas in Sports mode causes the backend to kick out a little bit since the turbo is at full boost when the tranny rengages at 3600. I don't think you NA guys will have that problem though with the stall. Also at half throttle and going up a hill or in any high load situation while using drive (not sports mode or manual) can cause the car to shift up or tranny slip (not sure which one its doing). Other than those gripes, the stall is perfect!
FTI custom made the stall for my car and my mods and was sold to me through their exclusive dealer for our car, Tracy at RX Performance. $599 for the converter, and $1000 for the install with full trans flush, new trans filter and gasket. I installed a trans cooler myself in about an hour (Tracy from RX supplied the cooler for $79). I dont have a tune for the stall yet but the car still operates great! Vince at Trifecta is whipping something up as we speak though. I wanted to wait and get results and videos before I started a thread but I've been super busy and winter time is here and there's been lots of bad weather recently so I decided not to waste anymore time. I'll add videos and 1/4 results as I get them. I do have two pics though!:
(Sold Sept 2015) Stock 18" Heritage w/ BFG G-Force ZR tires / Blacked out bowties and tail lights / DIY Remote-Mount Turbo Kit (Precision 6776S .81ar ex. @ 6.5psi, Tial 38mm WG, Greddy Type-S BOV) / RX Catch Can / RX-FTI 3600 Stall / Blue Well Lights / Team LLT
Pt_killa is offline   Reply With Quote
Old 11-02-2011, 01:20 PM   #2
Lgndryhr
Camaro Die-Hard
Lgndryhr's Avatar
Drives: 2010 2SS/RS L99 IOM
I've never heard of one of these before so care to explain what it replaces or aids? As well as what does it do basically? I read your post, but I am still slightly confused about it.
Phoenix (click for build thread)
13.282 @ 107.70 (100% Stock)
12.481 @ 110.92 (Current mods as of 5/6/16)
How to hug your camaro
Buy the car that you would most like to get beat in. The other guy will always be faster.
Live in or around Memphis? Check us out on here and Facebook
Lgndryhr is offline   Reply With Quote
Old 11-02-2011, 01:43 PM   #3
Pt_killa
Pt_killa's Avatar
Sorry about that, I replaced my stock torque converter from my automatic transmission with the FTI 3600 stall torque converter. Now under load the transmission will engage the engine at 3600rpm instead of the stock 1800rpm I guess. It's like having a manual and holding in the clutch and revving the car to 3600 and dumping the clutch. Now from a stop, the car can leave with more power at 3600 because 3600rpm is higher up in the powerband than the stock 1800. Look at any dyno graph of our v6 camaro and you will see that there is more horsepower at 3600rpm than 1800rpm. Also the FTI unit is made of billet therefore its lighter weight and stronger than the stock unit.
The only downside is that since the transmission has to slip in order to get to the set stall amount, more heat is created. Thats why an extra transmission cooler run inline with the stock cooler is neccesary to handle that heat.
Old 11-02-2011, 01:48 PM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
FTI torque converters are some of the best on the market! Talk to Greg over at FTI and he will make a believer out of you. I use him for all my personal stuff and will not use anybody else. The product is amazing and the customer service is even better.
Old 11-02-2011, 01:53 PM   #5
10RsCamaro
Slow v6
10RsCamaro's Avatar
Drives: Automatic Automobile
Send a message via Skype™ to 10RsCamaro
Wow. a stall speed converter for a camaro. Must see these slips now!
Full bolt on 2lt/Rs. Any questions? always a pm away!
Obx/Mace/Rx/Mrt/Vararam/Bcam/4.11 Gears/SS Brakes
USAF. Stationed in TX
10RsCamaro is offline   Reply With Quote
Old 11-02-2011, 04:13 PM   #6
blackTT600
Drives: 2011 2LT M6 SC
We need so new vids!! sounds awesome enjoy
blackTT600 is offline   Reply With Quote
Old 11-02-2011, 07:00 PM   #7
SC2150
The V6 LLT converters are a joint venture between both FTI & RX Performance Products and the results are amazing. These are NOT restalled OEM units requiring a core...they are purpose built for your build.
Old 11-03-2011, 12:20 AM   #8
KMPrenger
KMPrenger's Avatar
Been waiting so long to see results from one of these puppies...I know of one r two other members here with a stall installed but have yet to see results
Old 11-03-2011, 12:29 AM   #9
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
BaylorCamaro is offline   Reply With Quote
Old 11-03-2011, 01:08 AM   #10
SIXJAK
SIXJAK's Avatar
Drives: MO's only SC'd LLT.
Hmmmm why did think you had a stick?
Congrats on the new mod.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
SIXJAK is offline   Reply With Quote
Old 11-03-2011, 02:01 PM   #11
Pt_killa
Pt_killa's Avatar
I hope that the local drag track will be open tomorrow so I can have something for you guys.
Old 11-03-2011, 03:04 PM   #12
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
thats awesome. Great write up. Im surprised about the gas milage though, i think I would get eaten with the conditions I drive through but I have an M6 so no worries.
Cant wait to see some vids, and i love the black intercooler, quite the sleeper
CAMARO
Old 11-03-2011, 03:06 PM   #13
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
technically speaking, if were getting high 11s/ sub 12s with a 125 shot of nitrous, then, if you get it to launch right and have the power all the way through, which the converter allows for, then we might just have a new beast in the 1/4mile
CAMARO
Old 11-03-2011, 04:43 PM   #14
Pt_killa
Pt_killa's Avatar
thats awesome. Great write up. Im surprised about the gas milage though, i think I would get eaten with the conditions I drive through but I have an M6 so no worries. Cant wait to see some vids, and i love the black intercooler, quite the sleeper
Thanks TJ, from reading around and talking to people depending on what type of converter lockup vs nonlockup and the quality of the converter can all play a part in the gas efficiency. Like the saleman at BMR says, FTI is one of the best if not the best converter on the market. The car drives near stock when cruising around. My cousin had an early 80's firebird with an "off the shelf" 3000 lockup stall and the car was hard to drive around town because the car could hardly move without flooring it and burned lots of gas. At first he warned me not to buy a stall but when he drove my car recently he was amazed at how the car performed on the street and the great throttle response for such a high stall. FTI & RX FTW!
11's or low 12's would be nice! I do have some small DR's that were used on my old mustang that I may try it out but my front tires will be taller than the rear.... I think the nitrous camaros will still have the crown though because their powerband is way better than the turboed powerbands I have seen for our car. The nitrous cars that spray off the line will have way more torque off the line unless I can launch at 4000+rpm or run more boost. I have a feeling that I'll run mid to high 12's or maybe even a low 13. We shall see...
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3448 01-15-2018 12:30 AM
6l80 torque converter stall ToddSS V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 42 12-08-2017 01:51 PM
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 08-16-2014 03:07 AM
my oh my.. L99 burnout with yank torque converter installed DanD V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 75 06-12-2010 06:42 PM
