sjm autoprod
Old 11-02-2011, 10:53 PM   #1
martinezj454545
Drives: 2011 Camaro LS V6
Unhappy ***AAC HALO & Multi Function Remote HELP*****
Okay i ordered and installed amber halos from AAC for the headlights and fog lights on my 2011 LS. I installed them with the Multi Function Remote control and had trouble switching the settings and turning them off and on like on the videos. it says it has a 100 feet distance you can operate the remote but i stand just 2 feets away from it and it does not change functions or if i want them on or off it does not respond once i press the buttons. I tried replacing the battery, buying a new remote and nothing seems to work. The only time it works is when i disconnet the power and put it back on and then it works like its suppose to but after a couple of minutes it starts up again. theres no loose wires and every thing is connected properly. I checked the ground to the box and everything is good. what can i do to fic this problem? Thanks in advance.
martinezj454545 is offline   Reply With Quote
Old 11-02-2011, 11:05 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Have you contacted Jonathan at AAC about the issues you're having? He should be able to help.
Click to view my build thread
Old 11-02-2011, 11:08 PM   #3
martinezj454545
I havent yet, most like there going to tell me to return it and thats the last thing i would want to do. I want to know if there is something that im doing wrong before contacting AAC. Hopefully they will look at this and let me know if im doing something wrong.
Old 11-02-2011, 11:09 PM   #4
The Stig
The Stig's Avatar
Well they'll ask you to return it and then they'll send you a new one. The whole lifetime warranty thing.
Old 11-02-2011, 11:09 PM   #5
martinezj454545
When i first bought it I called AAC talked to Jonathan and he told me to put it under the hood by the fuze box. i wonder if all the heat is making it act up?
Old 11-03-2011, 01:13 PM   #6
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
Aac will be bit a delayed since they are all out at sema as well as I am. I will talk to them today . Make sure the little white antenna is extended and unobstructed and if posible as close to the exterior as possible
camaro4mybday is offline   Reply With Quote
Old 11-03-2011, 03:24 PM   #7
martinezj454545
I still have the old box looking controller not the new one where the antenna is connected to the controller. Thanks for talking to them, wish i would have gone but thats military life. Thanks again for everything and if anybody knows how to get this problem fix please let me know becouse i am growing tired of this.
Old 11-03-2011, 08:26 PM   #8
camaro4mybday
"Camaro Joe"
ah you did not specify it was the old style controller. water can be the issue there depending where it is located. give them a call tuesday after they have had a chance to back in to the shop and speak to a tech and they will help you figure it out and if you have to send it back or not
Old 11-03-2011, 08:33 PM   #9
gman1970
gmans 10
gman1970's Avatar
Drives: 2010 victory red ls
i bought a scanner from them it made it only 6 months..similar to you it would work if i disconnected it and then reconnected but eventually that stop working too.
k&n intake,borla catback
trifecta tune, doug thorley headers
gman1970 is offline   Reply With Quote
Old 11-04-2011, 01:19 PM   #10
martinezj454545
I will call them after they are back from SEMA but this problem was happening the same day i installed it and it has been giving me a headake ever since. Im almost wanting to buy the new controler just cuz of this issue.
Old 11-04-2011, 09:38 PM   #11
camaro4mybday
"Camaro Joe"
there tech's are great they will help you out. a 2 channel multi function controller is a nice upgrade over the old style especially since it is coded specifically for your remote and controller
Old 11-20-2011, 12:59 PM   #12
martinezj454545
So I contacted AAC to see if i can send back my Multifunction Remote Control or get the upgraded version if they dont make those anymore, and hoefully they can fix it or upgrade me. I will keep yall posted
Old 11-20-2011, 01:12 PM   #13
Haole
2017 SS
Haole's Avatar
Drives: 2017 Summit White 2SS
I would just upgrade to the colorshift 2.0. I love mine
Haole is offline   Reply With Quote
Old 11-20-2011, 01:24 PM   #14
martinezj454545
yeah i would love to upgrade but if they do the same thing and my old box actually work then i wont waste my money on buying something thats going to do the same thing.
aac, fog light, halo, multi fuction controler
Remote Start on an M6 djb525 5th Gen Camaro SS LS LT General Discussions 65 12-23-2013 11:47 AM
AAC Halo Fog Lights Function Judge Cosmetics and Lighting Modification Discussions 7 09-12-2011 04:48 PM
car alarm push start remote start nokia Audio / Visual / Electronics/ Gauges / Nav 0 08-27-2011 03:24 PM
remote start and halo headlights larietrope 5th Gen Camaro SS LS LT General Discussions 10 11-11-2010 12:41 PM
Does anyone have an L99 1SS with Automatic Start? SamIyam 5th Gen Camaro SS LS LT General Discussions 29 02-25-2010 05:58 PM
