510 Race Engineering
Camaro Z/28 Forum - Z/28 Specific Topics Discussions related to the 5th gen Camaro Z/28 model
Old 11-03-2011, 02:33 PM   #1
shank0668
shank0668's Avatar
Drives: Pontiac
Send a message via AIM to shank0668
525 hp LS3
http://gmauthority.com/blog/2011/11/...ower-in-a-box/
Could have potential for a track car.
Old 11-03-2011, 03:08 PM   #2
2cnd chance
It Will Be Mine
2cnd chance's Avatar
Drives: A 2014 Z28 or a C7?
Ok I'm listening...any details???
2cnd chance is offline   Reply With Quote
Old 11-03-2011, 03:56 PM   #3
ShnOmac
ShnOmac's Avatar
General Motors is showing off a new 6.2-liter toy at this year’s SEMA show, and it’s not a concept. Yes, consumers will actually be able to purchase the LS376/525 crate engine, which comes from the factory with 525 horsepower at 6,300 rpm and 489 lb.-ft. of torque at 4,400 rpm. The engine is designated as part number 19259233 and carries a suggested retail price of $8,937.50.
ShnOmac is online now   Reply With Quote
Old 11-03-2011, 03:57 PM   #4
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
1LE plus this
Old 11-03-2011, 04:03 PM   #5
ShnOmac
ShnOmac's Avatar
Using the LS3 production engine – the same used in Corvettes and Camaros – as the foundation for the LS376/525 helped keep the retail price lower, while the ASA camshaft is a proven, power-building component that has been successful in the high-rpm world of circle track racing.
The ASA camshaft is a hydraulic roller with .525-inch lift on both the intake and exhaust sides, along with 226 degrees duration on the intake side and 236 degrees on the exhaust side. Coupled with a tight, 110-degree lobe separation angle, it helps the engine deliver excellent throttle response and breath exceptionally well at high rpm. Chevrolet Performance complements this high-performance camshaft in the engine with higher-rate valve springs.
I like that part...
Old 11-03-2011, 04:19 PM   #6
jmart53
jmart53's Avatar
Drives: 2012 Cruze LTZ RS
Wonder if you will be able to get the ASA (I'm assuming GMPP also) camshaft installed on a Camaro LS3 with all necessary parts needed (springs, etc...)
jmart53 is offline   Reply With Quote
Old 11-03-2011, 04:32 PM   #7
LOWDOWN
Downright Upright
LOWDOWN's Avatar
Drives: Daily
Part # 12480110
ASA Cam
I: 226 E: 236
I: .525 E: .525
110
Cam requires valve spring P/N 12586484; 'ASA' cam for off-highway use.
MSRP $459.60
I think you'll find the 525 hp rating is calculated differently than "as installed Net HP" as per RPO-equipped...
Believe me, this engine with this cam, will NOT outpower an LS7...
"It's what you learn, after you know everything, that's really important" ... Sam Foose
"NOTHING matters...until you CARE" ... and that's a LOWDOWN Truth
"GOOD ENOUGH"...NEVER IS...another LOWDOWN Truth.
"STAY TUNED"
LOWDOWN is offline   Reply With Quote
Old 11-03-2011, 05:44 PM   #8
LOWDOWN
Downright Upright
LOWDOWN's Avatar
Drives: Daily
A word about "crate" engines...and marketing...
19201992 - LS3 = 430hp (204*/211*, .551"/.522")
12594727 - LS376 = 480 hp (SAME Heads/Pistons, 219*/228* .525"/.525")
19259233 - LS376 = 525 hp (L92 Heads, 226*/236* .525"/.525")
Slightly different, non-CNC'd heads and a longer duration-but-lower lift cam = 95 hp? Over a base Corvette LS3?
Really?
"STAY TUNED"
Old 11-03-2011, 05:45 PM   #9
2cnd chance
It Will Be Mine
Yeah, 100HP just from a cam???
Old 11-03-2011, 07:23 PM   #10
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
Drives: Supercharged ZL1 in the future
That would be a cam and a set of L92 heads that will net you the 525 hp from the 6.2 LS3 ASA 376/525 package but the cam alone 376/485 package has a slightly more street friendly idle. I wonder which would be easier to certify for the 6.2 LS3's horse power swan song...... like the LT1 was to the LT4..... and like the LS1 was to the LS6.... we need a final bearer from the genIV for the 1LE or Z/28 boss killer.
P.S. I would take an assembly line built 7.0 LS3 if it was to save some money if that is more reasonable for the Camaro without the some of the expensive Z06 parts, just a suggestion, call it an LS5.
Swift....Silent....Deadly
RLHMARINES is offline   Reply With Quote
Old 11-03-2011, 07:37 PM   #11
b4z
Drives: '06 Pontiac GTO M6, '09 V8 SRX RWD
Isn't the 525 hp version for carbs?
EDIT"
My bad. this is a new version.
b4z is offline   Reply With Quote
Old 11-03-2011, 07:39 PM   #12
PQ
Drives a Maro
PQ's Avatar
Drives: Hybrid SS Camaro
9k and no ECU........
Big cam, and think about some FI.......
Old 11-03-2011, 07:55 PM   #13
b4z
With that lift and the only 110 LSA it's gonna have a lot of lope. Probably more than a lot of people would like.
Old 11-03-2011, 09:12 PM   #14
2cnd chance
It Will Be Mine
That would be awesome!
Old 11-03-2011, 10:23 PM   #15
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2012 Camaro ZL1
Wow!!! That's...WOW
The question before asking for it in a production car...is its emissions output...
Still - WOW!!!
"Keep the faith." - - Read Before You Post.
Old 11-04-2011, 03:14 AM   #16
Runin11z
Drives: 11 CGM 2RS-SS
That cam is not going to be able to pass emissions to much overlap and tight lobe separation, that's why it is a off road package. But here is a thought, back in the day my dad told me about the dealer saying they could switch his cam in his chevelle to a 427/425 cam. Maybe dealers will become more passionate about cars like back in the day and start offering customers these sort of options. Like let's say a LS9 cam upgrade for the LSA.
2000 Camaro SS M6 onyx modded
2003 Silverado SS AB stock
2006 TBSS Black modded
2011 Camaro Ls3 CGM stock
Runin11z is offline   Reply With Quote
Old 11-04-2011, 11:42 AM   #17
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Is this the same engine as what they showed in the SSX last year?
Quote: In 2014 the camaro will have ... a twin turbo v6 ... around 350 to 360HP
No. Let me repeat that. No. FbodFather
Camaro5 Fest III Information
Camaro5 Fest III pre-registration
Old 11-04-2011, 12:04 PM   #18
slick rick
SoCal Mayhem
slick rick's Avatar
Old 11-04-2011, 12:20 PM   #19
Runin11z
I would say pretty close with the SSx using dry sump oiling.
Old 11-04-2011, 12:30 PM   #20
LOWDOWN
Downright Upright
LOWDOWN's Avatar
Drives: Daily
The SSX, being a year-ago teaser, probably had a similarly-modified engine, but NOT likely this specific cam... IIRC, no specific HP figures were disclosed.
2011 CHEVROLET CAMARO SSX TRACK CAR CONCEPT
Ever since the new Chevrolet Camaro's launch last year, owners have explored the performance potential of the car. The Camaro SSX Track Car is a concept for transforming a street Camaro SS into a closed-course track car, and a showcase for new performance parts.
"The SSX concept explores taking Camaro's excellent street performance and extending it into a road course context," said Chris Perry, vice president, Chevrolet marketing. "The car expresses Camaro performance while also signaling Chevrolet's new commitment to developing and offering a portfolio of performance parts for racing enthusiasts."
The Camaro SSX Track Car has a purposeful aesthetic, with exterior appointments and suspension modifications aimed at road course performance. They include carbon fiber aero parts – front splitter and adjustable rear wing – lightweight carbon fiber body panels, revised lower grille and unique brake cooling ducts. The carbon body panels significantly lower the Camaro's weight, as does the elimination of much of the production car's sound-deadening material, carpeting and rear seat.
Low-gloss Icy White Metallic exterior paint is contrasted with the carbon aero parts, door graphics/racing number and red details; and this competition-ready Camaro rolls on dedicated track wheels and tires. This concept was constructed with input from Pratt and Miller, Chevrolet partner in Corvette Racing, and Riley Technologies using parts proven in the Grand Am racing series.
VEHICLE HIGHLIGHTS
Exterior:
• Icy White Metallic color with red accents and door graphics
• Carbon fiber hood, fenders, door and deck lid
• Exposed carbon fiber front splitter, rockers and adjustable rear wing
• Unique lower grille and brake ducts
Interior:
• Carpeting, sound deadener and rear seat deleted
• Ace suede-covered racing steering wheel and shifter
• SCCA-approved roll cage and window net
• Racing driver's seat with five-point harness
• Racing pedals
• Fire suppression system
• Fuel cell
• Video camera system mounted on the roll cage
Performance:
LS3 6.2L V-8 enhanced with Chevrolet Performance Parts' camshaft, cylinder heads and dry-sump oiling system
• Production six-speed manual transmission with Corvette ZR1 twin-disc clutch
• Low-restriction air induction and exhaust systems
• Four-wheel disc racing brake system with six-piston front/four-piston rear calipers and drilled and slotted rotors
• Modified production suspension with Pfadt licensed components
• 20-inch racing wheels and tires
"STAY TUNED"
Old 11-04-2011, 12:34 PM   #21
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Iam intrested in this cam, it might make for a pretty nasty street car with bolt-ons! Nasty sound and good torque so the 480hp is the ls3 with just this cam, so mabey with headers and intake your looking at a 520-530hp ls3! I would love to see this cam tested.
AMB SS M6, cammed, headers, tuned 12.3 116.4
Bad70supreme is offline   Reply With Quote
Old 11-04-2011, 12:42 PM   #22
LOWDOWN
Downright Upright
LOWDOWN's Avatar
Drives: Daily
Again, folks, these "power" ratings are NOT "as-installed in a Camaro", and that's where some of their "optimism" comes from...
Getting 100 honest net extra hp from a relatively mild cam (.525" lift) and non-CNC'd heads (L92's are NOT the be-all and end-all of LS cylinder heads!), "as installed" with exhaust (regardless of whose you have) and emissions compliance and a streetable tune is a very TALL order to deliver... Remember, ASA runs "spec" fuel, NOT the stuff you'll find in CA., where emissions and tune are two words you can't avoid.
For liability's sake, as well as day-to-day practicalities, GMPP states "for off-highway usage"...
I repeat, this is NOT a street-legal alternative to an LS7 for us...
A hell of a choice for your "non-emissions necessary" hotrod, though!
"STAY TUNED"
Old 11-04-2011, 01:49 PM   #23
mgoodbar
White 2ss, LT, CAI, Tune
Drives: 2010 L99
Am I understanding that the l92 heads ar better than the LS3/L99 heads??
just wondering.. I had a old lunati cam with a 110 lobe sep and i loved that cam...
mgoodbar is offline   Reply With Quote
Old 11-04-2011, 02:18 PM   #24
LOWDOWN
Downright Upright
LOWDOWN's Avatar
Drives: Daily
Slightly (italix'd for a reason) better flow numbers...but NOT equal to LS7 heads...
The 110* guarantees a great "drive-in" lope...badass, to use a popular phrase...but hell for vacuum for your power brakes!
"STAY TUNED"
Old 01-21-2012, 09:21 PM   #25
Fraxum
Fraxum's Avatar
Drives: 2011 LS3 2SS
Originally Posted by LOWDOWN View Post
Part # 12480110
ASA Cam
I: 226 E: 236
I: .525 E: .525
110
MSRP $459.60
Spoil Sport.
Mods: Bigflow LTs and Cats, MagnaFlow, CAI CAI, ADM Scoop, Ported TB, Vararam Wedge, No Tune,
BMR/Pedders Suspension, Barton Shifter, SubThump tunes Build Thread, South Jersey Camaro
Stop confusing me with the facts.
TRI-COUNTY CAMAROS { TCC } RedDragonSS USA - Florida 17662 Yesterday 10:35 PM
Tucson Camaro's Flynnaz USA - Southwest 8334 Yesterday 04:16 PM
Introducing our hand ported, polished, and powdercoated LS3 throttle body! ThePowderPro V8 Bolt-Ons & Tunes 111 03-11-2012 07:55 PM
From L99 to Ls3 LEADfoot927 5th Gen Camaro SS LS LT General Discussions 30 06-07-2011 09:01 PM
LS3 and L99? black2black10 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 05-07-2010 12:58 AM
