Old 11-03-2011, 08:18 PM   #1
Missionboi
SoCal HT5 [COTW: 8/12/13]
Missionboi's Avatar
Drives: 2013 2SS 1LE RS
Injen CAI filter clean
Was wondering if anyone can help me out on some tips on when and how should I clean my Injen CAI. i got the long tube CAI that goes to the bottom keep that in mind
Can someone help me out thanks!
Missionboi is offline   Reply With Quote
Old 11-03-2011, 08:38 PM   #2
Beauwulf
Beauwulf's Avatar
Drives: '10 LT RS A6 & '04 Acura RSX Type S
I've used the K&N cleaning and lube kit for years. Done properly, it works quite well! As to frequency of cleaning, depends on your conditions. In dusty climes, every 5-7K miles is good.. in cleaner areas, 10K
Beauwulf is offline   Reply With Quote
Old 11-03-2011, 10:03 PM   #3
Missionboi
Missionboi's Avatar
Awesome! I will get the kit and do it can this be purchased at Autozone? I live in pretty dry desert souther cali lol. And have had it for about 15k so I need to change quick!
Old 11-03-2011, 10:10 PM   #4
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
This works for dry filters too?
BaylorCamaro is offline   Reply With Quote
Old 11-03-2011, 10:13 PM   #5
Beauwulf
Beauwulf's Avatar
The cleaner does... yes. You just have to be gentle and let it air dry. No shop air....
Old 11-03-2011, 10:14 PM   #6
Beauwulf
Beauwulf's Avatar
Yea, I think I got mine at autozone.
Old 11-04-2011, 06:02 AM   #7
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Injen recommends blowing the dry filters out with shop air every 25K miles. Replace at 100K miles. But like Beawulf said dirty conditions require sooner cleanings.
I did mine at 13K and you couldn't tell the difference it was that clean still.
Old 11-04-2011, 01:53 PM   #8
Missionboi
Missionboi's Avatar
So just take the dry filter off and just blow dry it all out?
Old 11-04-2011, 02:00 PM   #9
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Yep, just use a shopvac on the dry filter!
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 11-04-2011, 03:03 PM   #10
Missionboi
Missionboi's Avatar
Awesome!!! Is it possible to just use a hair blow dryer or need something more powerful?
Old 11-04-2011, 03:08 PM   #11
mypuppysirius
mypuppysirius's Avatar
Drives: 2011 Cyber Grey V6
Don't use a hair blow dryer with any heat at all. It will shrink the cotton on the dry filter and you will lose filtration
mypuppysirius is offline   Reply With Quote
Old 11-04-2011, 03:22 PM   #12
Missionboi
Missionboi's Avatar
Ok what kind of dryer do you recommend me buying? Lol almost made a mistake!
Old 11-04-2011, 04:32 PM   #13
mypuppysirius
well you can still use a hair blow dryer if it has a non heat setting. Otherwise it wont hurt to use things like a vacuum hose to suck dirt out, or things like that. There is no "exact" way to do it, just don't use heat.
Old 11-04-2011, 06:39 PM   #14
Beauwulf
Beauwulf's Avatar
I have a bit of an issue with the 25K cleaning interval Injun "recommends". One of the reasons the Injun works so well at increasing airflow is by using the dry filter. It does a good job of catching larger particulates but, that type of media, doesn't do well with the finer stuff. That's the trade off when using these types of filters. You give up some filtration to gain more flow. So, it is prudent to shorted the cleaning interval based on the conditions where you operate the vehicle.
It may also be a good idea to change to a "wet" type filter if you live in a very dusty environment and want to keep the car in top shape for many years. This kind of change will usually require a tweak of the tune to compensate for the lower flow.
Using a vacuum from the outside or blow dryer from the inside of the filter is OK. Just make sure your working in the opposite direction of the airflow. A little tapping and shaking doesn't hurt either....
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3453 02-18-2018 02:39 PM
Breath clean Air GmPartsDirect.com Interior Parts & Accessories 0 03-30-2011 05:58 PM
ProperAutoCare.com New Products Angelo@Autopia Wash/Wax/Detailing and Cosmetic Maintenance Parts 9 11-18-2010 08:04 AM
when and how should we clean our cai filters camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 06-11-2010 06:32 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
