HeadlightArmor
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 11-06-2011, 07:56 PM   #1
nitto85
Caffeine Injected
Drives: Chevrolets!!
Looking For A Good Shop Heater
Any suggestions for a good "shop" heater? I want to hook my dad up with a good heater for his basement/garage so he can work on his chevelle and truck without freezing.
Preferably electric and won't break the bank. This will be for a 3 car garage that is big enough for 4 cars in terms of space.
Thank you.
nitto85 is offline   Reply With Quote
Old 11-06-2011, 08:04 PM   #2
Iomcamaro
The enjoyment never ends
Iomcamaro's Avatar
Drives: 2010 1LT/RS IOM #25223
I would go with a propane heater. The heating elements in them are better than electrics and they are way safer than kerosene.
Iomcamaro is offline   Reply With Quote
Old 11-06-2011, 08:12 PM   #3
Mr Twisty
Mr Twisty's Avatar
How about a heater that burns used motor oil. Been a few years since I looked at them, don't know if they do synthetic.
Or if there's free wood, you could do a wood stove if he has room.
1200+ sq ft is a lot to try to heat with a small electric heater.
-- Benjamin Franklin
Old 11-06-2011, 09:28 PM   #4
doubletrouble
doubletrouble's Avatar
Drives: 2012 Camaro 2SS 45th Anniversary
Propane or natural gas depending on were you live.
doubletrouble is offline   Reply With Quote
Old 11-08-2011, 02:30 PM   #5
NavyDood
Retired Navy
NavyDood's Avatar
Drives: 2010 2SS/RS
Most definitely. Need to have something with a fan to circulate the air.
Retired Navy... A Husband. A Dad. A Veteran as of 2011. 2010 2SS/RS A6 - FlowMaster CatBack - I'm not a Amsoil dealer and will never be one. I believe in its capabilities from personal use with oil analysis reports backing up my OCI's. Besides, I know more than most cut and paste Amsoil dealers which are at least 95% of them.
NavyDood is offline   Reply With Quote
Old 11-17-2011, 03:23 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS and Twin Turbo'd SRT8
You can build a wood burner out of 2 55 gal drums suppose to really good lots of radiant heat
Old 12-08-2011, 12:15 PM   #7
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
I have a "Mr. Heater" it works great out in the Garage. It's just a single burner that screws right on to a propane tank.
Lnch Mny is offline   Reply With Quote
Old 12-18-2011, 10:37 PM   #8
RocketRod
Drives: 69 Camaro
I just installed Mr. Heater Big Maxx 45K BTU unit. The unit hangs from the ceiling, runs on natural gas connected to a wall mounted thermostat set on 50 degrees. I would highly recommend it and wish I had installed this years ago.
RocketRod is offline   Reply With Quote
Old 12-20-2011, 09:31 AM   #9
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
I would go with a gas F/A heater that fits between the 16" 2X4's - it will direct vent out the back.
Set the thermostat & you are good to go.....the brand I have is Williams.
I have had/tried kerosene, electric, & propane
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 12-20-2011, 09:46 AM   #10
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
Modine Hot Dog
I put an HD30 in my two car when the Camaro came home in 2009. Awesome heater. Very econimical, all-around. Easy to bump the thermostat on an afternoon I have a project. Heats up in 15 minutes from 50 to 70 when its single digits outside.
The trick is to no go too big. Most people do. You WANT the heater to run long enough to dry the condensation in itself or it starts to build up and you will find all your toys and tools sitting with sweat on them.
http://www.modine.com/v2portal/page/...ontent_014.htm
chef-beavis is offline   Reply With Quote
Old 12-31-2011, 10:33 AM   #11
NEGXXIS
NEGXXIS's Avatar
Drives: 2016 Camaro SS A8
This is what I use in my shop that is 1200 sq ft.
OP.... I see that you are in GA, so your weather is similar to mine.
Here is like what i use . http://www.amazon.com/Mr-Heater-MH12...345717&sr=1-10
NEGXXIS is offline   Reply With Quote
Good Kansas City Exhaust Shop? FLYBOY USA - Rockies / Midwest 2 03-26-2011 01:58 PM
Good paint/ body shop in S A? mpiper USA - Texas 1 03-25-2011 01:59 PM
Good Performance Shop in Missouri njdad61 USA - Rockies / Midwest 5 03-17-2011 09:02 PM
Looking for Good Tint Shop in South Jersey...... Help! MAZZ77X USA - NY / NJ / PA 11 11-21-2010 09:23 PM
Need a good detail shop Rob191288 USA - Mid-Atlantic 4 11-12-2010 11:25 AM
