Emblempros
Camaro V6 LLT Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 11-08-2011, 09:33 AM   #26
bmorecam
Originally Posted by DAL123 View Post
I am just curious where the Mace Intake insulators are non conductive . How much chasis Ground will be lost relying on just the bolt which will have a sealant arount the threads. will static electricity form and creat any problem and should a ground jumper be added from the intake to a good chasis ground.
Sorry but I am a little lost as to what you are trying to say. Can you elaborate a little more for my dumb A. Lol.
Old 11-08-2011, 09:45 AM   #27
DAL123
DAL123's Avatar
Drives: 2010 Camaro 2LT/RS/A6
Basically all your engine parts are bonded to chasis ground via neg of the batery most of the gaskets for heads, manifold, headers,TB, are metallic and help continuation of that good grounding potential. The intake insulator is non metallic and non conctive of electricity so being an electrician I always relly on a good ground. I was just wonderind if an aditional grond wire from the manifold to another bolt on the chasis such as a header bolt or even to a chsis bold would be usefull i am not sure how much or any static electricity occures through the system if any without a good groung. Just my curiosity
Trifecta Tune, Vararam CAI,Self ported Intake Manifold,3/8 Black Iceolator,Rx Catch Can, W/Breather, V8 Rear Diff. 3:45s W/Posi Mod, Mrt V2.0 Axel Back, Magnaflow Resonated X-pipe, Street Scene Front Splitter.,V-Max Trottle Body., Eiback Sway Bars., Phadt End Links.,
DAL123 is offline   Reply With Quote
Old 11-08-2011, 10:00 AM   #28
bmorecam
Oh ok, I see where you are coming from with this. The original gasket is just plain rubber and not metal material like the header gaskets. Also, mace send you one of those rtv gasket maker but after talking to mace the original recommendation was to use the original gasket but it will require two, one on each side. In my case I have two so I plan to use the original gasket.
So in this case I don't think grounding would be an issue since it use rubber gasket anyway.
Old 11-08-2011, 10:19 AM   #29
DAL123
DAL123's Avatar
Ok i was unsure if it was an aluminum gasket that came installed from factory.
Old 11-08-2011, 10:25 AM   #30
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Originally Posted by bmorecam View Post
Thanks tj. I got it. For anyone that change out their manifold in the future the bolt torque specs are 89in for the cover and 18lb for the actual manifold bolts. The bolt pattern sequence can be the usual criss cross and in and out.
I think I am going to wait and see if my AFR or the fuel trims change before asking vince to whip one up for me. I plan to hit the dyno more then once so let see how much extra a tune will get me. In other vehicles such as LS a tune is only good for about 5-6rwhp in my type of scenario.
Install pics and first impression to come this evening
CAMARO
Old 11-08-2011, 10:51 AM   #31
Demon Hunter
Demon Hunter's Avatar
Drives: 2010 Black Camaro LT
Would you hurry up and do the install already lol!!!!
Demon Hunter is offline   Reply With Quote
Old 11-08-2011, 11:56 AM   #32
bmorecam
haha It's already bad enough that I stopped working at my job lol. I never had so much excuse to be in front of a computer
I am probably as excited as you guys or even more but I am somewhat trying to downplay this whole thing and tell myself to not expect anything spectacular at all. It seem when you expect too much you always end up with less so this time I am going to downplay this whole thing and say I am expecting 5hp
Old 11-08-2011, 12:57 PM   #33
BaylorCamaro
AutoX is for fast DRIVERS
BaylorCamaro's Avatar
Drives: 2010 2LT/RS Supercharged
Probably really smart.
Automotive youtube channel. / My First Autocross / My automotive blog / Build Thread
RX Super Charged / MRT V1 / ARH LT Headers and Cats / 2.5" Entire System / Ported & Polished IM / IM Spacer / RX Ported TB / Trifecta Tune / Brembo Brakes / Pfadt Sways, End Links, Rear Trailing Arms & Springs / SS Rear Diff.
Check out video's of my current set up! ==> RX Super Charged
BaylorCamaro is online now   Reply With Quote
Old 11-08-2011, 01:26 PM   #34
rtcat600man
having FUN now
rtcat600man's Avatar
Drives: 2010 2LT IOM
:dr inking:
Old 11-08-2011, 01:34 PM   #35
MichaelH
SOCAL HT5
MichaelH's Avatar
Drives: 2010 Camaro RS cybr gry/blck strps
but we all know your expecting much more than that haha. so you may say 5hp, but your looking more for like 20hp
Upgrades: BBK Longtube Headers W/ High Flow Cats, MRT V 1.0 Exhaust, Airaid CAI V2 tube, VMAX Throttle Body, Trifecta E-85 Tuned, powder coated black rims, window tint,GM Heritage Grill, Rx Oil Catch Can, black out gills, blacked out lights:
Other Vehicles:
2008 Kawasaki ZX6R-115 RWHP in mid summer
2006 Chevy Trailblazer SS- (winter tune) getting forged this spring
MichaelH is offline   Reply With Quote
Old 11-08-2011, 01:37 PM   #36
mhog
mhog's Avatar
Drives: 2010 V6 Camaro 2LT/RS
I'm betting 20+
mhog is offline   Reply With Quote
Old 11-08-2011, 03:20 PM   #37
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
your probably not going to feel a thing! I dont expect to see any results
I wish I did this for Transformers 3 lol
Fast 5, heck I didnt think it could get any worse and came out of the movie thinking WOW they hit a new low in a parallel universe
CAMARO
Old 11-08-2011, 06:46 PM   #38
Ventmaster
Ventmaster's Avatar
Drives: 2010 Camaro RS 1LT M6
Oh my! This does have potential!
And BTW, tighten manifold bolts to 25N-m (18 lb ft) and use a tightening sequence like you're changing your tire- alternate in a diagonal fashion.
Thanks for taking the time bmore!
Oops, just saw you knew that- I got excited by the pics!
Old 11-08-2011, 07:01 PM   #39
MINI HLK
MINI HLK's Avatar
Drives: LS A6
Add me to the fray... cant wait.
MINI HLK is offline   Reply With Quote
Old 11-08-2011, 07:46 PM   #40
Mach
Mach's Avatar
Drives: White M6 1LT RS
I think bmorecam isn't responding because gained so much tq he accelerated into another dimension.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 11-08-2011, 09:11 PM   #41
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
hapisok is offline   Reply With Quote
Old 11-08-2011, 09:12 PM   #42
bmorecam
I crapped in my pants when I seen that mach. I wish
Well.. it look like the install is going to be finished tomorrow After I got off work around 2:30pm I only had about good 2 1/2 hours to get everything test fit and installed. It got pitch black here right around 5:30pm.
Anyhow, taking out the stock manifold is not that difficult until you get to the 3 bolts all the way in the back of the manifold and under the windshield wiper trim. 1 is part of 6 actual manifold bolts and the other 2, well.. I guess it does not even matter since it will be useless once the insulator is installed and the manifold is raised. There's barely not any room back there so get ready to spend some time and scrape up your hands. Here's a pic of the bolts. The angle only show 2. The vertical standing bolt is the manifold bolt.
After I finished uninstalling the stock manifold the first thing I noticed is bunch of loose dirt right around the inlet holes. If you guys see the same then you might want to carefully take a wet rag and get all of the dirt off and away from the holes. One thing you do not want is those dirt getting inside your head. Here is a pic of what I am talking about.
Now this is one of the part that took most of my time. I figured if I can fit 18mm then this means that anything smaller then 18mm won't be a problem. So, I took out my RTV the right stuff gasket maker and put the 6mm and the 12mm together. This is my first time using the gasket maker(I just heard good things about the right stuff)so this is what I ended up with
The gasket maker said 1 minute..ummm, yhea ok After waiting for it to turn rubber and scraping and cleaning all that sticky crap off the insulator and myself I can already see the sun starting to go down.
but at the end it came out really well
Well.. after test fitting everything, the 18mm fit without any issues but keep in mind that all of the supporting bolts to help hold the manifold in place will be useless due to the manifold being raised. The holes will not line up anymore unless some of you can come up with some creative ideas. So the only bolts that will hold the manifold in place will be the 6 actual manifold bolts which I think is more then enough. Once you guys see how big and long these manifold bolts are you will understand. Here are some pics
Just when I was ready to reinstall everything back and be on my way under 2hrs, here comes trouble again. You remember the bolts on the back I mentioned earlier? Now try to line up 2 gaskets, one insulator, the manifold itself, while trying to somehow get a 5" new manifold bolt under the wiper trim in the back where is almost impossible for your hand to go in well.. after almost breaking my back and my hands I finally got everything lined up and the bolts and the manifold in place. Now the problem is how in the hell am I suppose to bolt down the rear bolt that I just had a world war 3 with?? well.. this is where it all ended, with one bolt left to screw in. The day got pitch black and it was game over. Time to call it in for the day. I was able to get get the bolt down as far as I can screw it down just using both of my point fingers so tomorrow I will be heading to the tool house and search something small enough that will work. Oh.. and I forgot, the new bolts provided by mace are allen bolts
Old 11-08-2011, 09:40 PM   #43
Victoryred69
Victoryred69's Avatar
Drives: RS Victory Red/BS V6
Well thats just a darn party pooper eh Lol!
It looks sweet though man im glad its coming together and your doing a great job being very meticulous... so you said they were hex head bolts so im guessing you cant you a wrench to wrench them down a bit eh?? if you can do that then try to use a wratchet or whatever you were using to bring er all the way in to torque it.
Just an idea i could be totally wrong :P
2010 Camaro 2LT RS M6 VR/BS
Flowmaster AMT Axle Back
Vararam Ram Air Intake
P13 Plazma Bulbs
DT Shorty Headers
Heritage Grill
Blacked-Out Taillights and Side Markers
Victoryred69 is offline   Reply With Quote
Old 11-08-2011, 09:50 PM   #44
hapisok
hapisok's Avatar
great write up and thanks for the pics.
Old 11-08-2011, 10:16 PM   #45
formare
Suspension by Pedders
formare's Avatar
Drives: Synergy Edition 13.71@102 1.95 60'
Is the ported intake a one off or is this a product that will be available for purchase?
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 11-08-2011, 10:47 PM   #46
KMPrenger
KMPrenger's Avatar
Drives: '10 ABM LT/RS, 01 Ford Ranger
Thanks for the write up thus far....more to come!
Popcorn anyone??
Shes ALL MINE! - 8/24/2009 2G1FB1EV2A9133373 Custom Magnaflow Exhaust, Vararam intake, MACE Ported Intake Manifold, RX Ported TB, RX "Black Ice" manifold insulator, Trifecta Tune, Mike Norris Catch Can, DRL Harness, Heritage grill, Street Scene lower grill, NLP Spoiler, ZL1 rockers, Switchblade silver interior, Defenderworx sills, and more!
Old 11-08-2011, 11:26 PM   #48
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
wow man that sounds like hell. I had knee surgery and I remember working on getting the vararam in KILLED my knee.
Tough work man but hopefully the end result will be worth it!
CAMARO
Old 11-09-2011, 01:02 AM   #49
BaylorCamaro
oh man this is awesome. Good right up Jay, I look forward to see what your butt dyno and real dyno tell you!!!
Old 11-09-2011, 07:43 AM   #50
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
Very sweet, can't wait to see how this turns out. So with the increased height of the manifold - do you think the Vararam would still be able to mate up?
ChadG is offline   Reply With Quote
Anyone Dyno'd with a Ported Intake Manifold? TitoSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 04-04-2011 08:48 AM
Ported intake manifold antivenom Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 52 10-20-2009 09:50 AM
