LSR Performance
Camaro V6 LLT Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 11-09-2011, 08:36 AM   #51
bmorecam
I know Vararam was a very very tight fit. Maybe you can get away with 6mm but I don't know about anything bigger. I thought I was going to have a problem with my AEM but I was very surprised to see it fit right on like a glove even with the extra height. One thing I noticed is that the original gasket are very thick right around the edge of the holes. So when I put 2 gaskets with the insulators it almost increased the total height by another 4-5mm. I am very comfortable to say that we can raise our manifold up to 20+ mm safely.
The guys over at MACE engineering is already keeping their eyes on this thread but I will let them know of the results today.
Formare, you can purchase the 6mm now from MACE and my porting is done from darin D at high flow. He offer from mild stg1 to stg3 if you plan to get the most out of it and do the head work too down the line. Darin was here a while back but got the vince treatment from the mods.
First butt impression coming later on this evening
Old 11-09-2011, 08:38 AM   #52
bossbunny
Mrs. Bunny to you
bossbunny's Avatar
Drives: The Sassiest V6 in the South!
bossbunny is offline   Reply With Quote
Old 11-09-2011, 10:52 AM   #53
bmorecam
Originally Posted by badgebunny View Post
Don't eat too much popcorn now ms bunny.. you wouldn't want to mess up your beautiful figure now would you
Im just messing with ya Im sure you can eat as much popcorn as you want and still be beautiful.
Does anyone know how much ft pound 87 inch pound convert to? I am thinking 7.250. Is that correct?
Old 11-09-2011, 10:57 AM   #54
bmwdon
I refuse to go smurfy
bmwdon's Avatar
Drives: 2009 Challenger SRT8, 2010 Camaro
I told you guys getting to those rear bolts were a pain in the arse! so what's the butt dyno telling you so far?
-Bill...the Camaro was my wifes, now she's got a minivan
Challenger- 2009 Dodge Challenger SRT8 Procharger D1 Supercharger: 10.895 @ 126.720 MPH
bmwdon is offline   Reply With Quote
Old 11-09-2011, 11:03 AM   #55
bmorecam
if you take out the windshield wiper trim completely before working I think it might make it easier, but I think uninstalling the wipers and the trim itself could be a hassle.
I won't have my first butt dyno impression until tonight. I will be finishing up the install later this afternoon.
I will get some before/after logs for you guys also, then I should be on the dyno next tuesday
Old 11-09-2011, 11:32 AM   #56
Demon Hunter
Demon Hunter's Avatar
Drives: 2010 Black Camaro LT
Originally Posted by formare View Post
Is the ported intake a one off or is this a product that will be available for purchase?
I was wondering the same thing.
Edit: Never mind, didn't see the response where you already addressed this....
Demon Hunter is offline   Reply With Quote
Old 11-09-2011, 11:36 AM   #57
3859c1
Drives: 1997 Pontiac Grand Prix GTP L67
See here>>>
https://www.facebook.com/pages/High-...62540657151556
3859c1 is offline   Reply With Quote
Old 11-09-2011, 11:38 AM   #58
3859c1
Originally Posted by bmorecam View Post
I crapped in my pants when I seen that mach. I wish
Well.. it look like the install is going to be finished tomorrow After I got off work around 2:30pm I only had about good 2 1/2 hours to get everything test fit and installed. It got pitch black here right around 5:30pm.
Anyhow, taking out the stock manifold is not that difficult until you get to the 3 bolts all the way in the back of the manifold and under the windshield wiper trim. 1 is part of 6 actual manifold bolts and the other 2, well.. I guess it does not even matter since it will be useless once the insulator is installed and the manifold is raised. There's barely not any room back there so get ready to spend some time and scrape up your hands. Here's a pic of the bolts. The angle only show 2. The vertical standing bolt is the manifold bolt.
Attachment 304107
After I finished uninstalling the stock manifold the first thing I noticed is bunch of loose dirt right around the inlet holes. If you guys see the same then you might want to carefully take a wet rag and get all of the dirt off and away from the holes. One thing you do not want is those dirt getting inside your head. Here is a pic of what I am talking about.
Attachment 304113
Now this is one of the part that took most of my time. I figured if I can fit 18mm then this means that anything smaller then 18mm won't be a problem. So, I took out my RTV the right stuff gasket maker and put the 6mm and the 12mm together. This is my first time using the gasket maker(I just heard good things about the right stuff)so this is what I ended up with
Attachment 304115
The gasket maker said 1 minute..ummm, yhea ok After waiting for it to turn rubber and scraping and cleaning all that sticky crap off the insulator and myself I can already see the sun starting to go down.
Attachment 304116
but at the end it came out really well
Attachment 304117
Attachment 304118
Well.. after test fitting everything, the 18mm fit without any issues but keep in mind that all of the supporting bolts to help hold the manifold in place will be useless due to the manifold being raised. The holes will not line up anymore unless some of you can come up with some creative ideas. So the only bolts that will hold the manifold in place will be the 6 actual manifold bolts which I think is more then enough. Once you guys see how big and long these manifold bolts are you will understand. Here are some pics
Attachment 304121
Attachment 304122
Attachment 304123
Attachment 304124
Just when I was ready to reinstall everything back and be on my way under 2hrs, here comes trouble again. You remember the bolts on the back I mentioned earlier? Now try to line up 2 gaskets, one insulator, the manifold itself, while trying to somehow get a 5" new manifold bolt under the wiper trim in the back where is almost impossible for your hand to go in well.. after almost breaking my back and my hands I finally got everything lined up and the bolts and the manifold in place. Now the problem is how in the hell am I suppose to bolt down the rear bolt that I just had a world war 3 with?? well.. this is where it all ended, with one bolt left to screw in. The day got pitch black and it was game over. Time to call it in for the day. I was able to get get the bolt down as far as I can screw it down just using both of my point fingers so tomorrow I will be heading to the tool house and search something small enough that will work. Oh.. and I forgot, the new bolts provided by mace are hex bolts
Attachment 304131
Attachment 304132
Attachment 304133
Attachment 304134
Is it just me, or did the insulators match up to the head ports??
It looks like it in the one picture. Any head port ledge?
Old 11-09-2011, 11:41 AM   #59
Mach
Mach's Avatar
Drives: White M6 1LT RS
The insulators are matched to the gasket. Bmorecam matched his head to his gasket.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 11-09-2011, 12:06 PM   #60
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
subscribed
My Build
When speed matter
hunterv6 is offline   Reply With Quote
Old 11-09-2011, 12:09 PM   #61
bossbunny
Mrs. Bunny to you
bossbunny's Avatar
Hahah. Its 100 calorie popcorn! Awe, thanks! I am really excited to see how this turns out.
Old 11-09-2011, 12:19 PM   #62
bmorecam
Darin, nope. The insulators does not match with the head. As we already know the insulator has almost the same exact hole size as the factory gasket. I have no idea why mace designed it that way but looking at their dyno graph and according to mace they confirmed to me that we won't see any negative effect so I guess we will just have to see.
Also, one thing I was very impressed with was the quality of the factory head's casting(inlet). I couldn't believe how smooth the casting looked and felt to touch.
Old 11-09-2011, 12:31 PM   #63
bmwdon
bmwdon's Avatar
get yourself a set of ratcheting box wrenches....they helped out alot when I pulled the ported one I sent to stacey recently. the space back there was rediculously tight, another instance where it's easy to put together and take off when the engine is out of the car, but to hell with the diy'er that has to work the engine in his garage.
Old 11-09-2011, 12:51 PM   #64
chozn4service
Five-O
chozn4service's Avatar
Drives: 2010 RS RJT
I'm all up in it!
http://www.cardomain.com/ride/3832170 : Praise The Lowered!
Flowmaster Catback Exhaust, Vararam intake, Solo HFC, VMax Ported TB, VMax "Black Ice" manifold insulator, Trifecta Tune, Mike Norris Catch Can, DRL Harness, Heritage grill, Razzi GFX, NLP Spoiler, MPD1 Spoiler and more!
chozn4service is offline   Reply With Quote
Old 11-09-2011, 01:06 PM   #65
bmorecam
Thank you don. The problem is that these are the new bolts that they sent me, just way longer. They are thumb allen bolts and not hex like I mentioned earlier lol.
I have no tools that can reach back there in my tool box that will work with those bolts so I am about to head out to sears or somewhere and see if I can find something that will work.
I also just noticed that my brand new cheap powerbuilt torque wrench is not clicking at all So it look like I will have to go and return that also.
Well.. off to the tool land
Old 11-09-2011, 01:29 PM   #66
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
Is that a Harbor Freight special? I bought 2 torque wrenches from there and neither one clicked. I resorted back to my old-fashioned torque wrench with the pointer.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 11-09-2011, 01:48 PM   #67
tmac1granger33
NM HT5
tmac1granger33's Avatar
Drives: COTW 3/5/12
Status 22" Staggered painted wheels/Eibach 1" Pro Kit Lowering Springs/Heritage Grille/Razzi Ground Effects Kit/RK Sports 3 piece Spoiler/DT Shortie Headers/Injen CAI/MRT 1.0 /Resonator Delete/Oracle Dual Red-white halos/Knight Rider grill Light/Sparks RS emblem/LED Sidemarkers/Red interior lighting/Gm fuel door/Halo Foglights/Trifecta Tune/IGGEE Seat covers/ Sinister Hood,VMAX throttle body/VMAX Black Iceolator/Technostalgia LED Taillights/3dCarbon Fender Vents/AAC Concept mirrors/zl1 bumper/AAC Plasma's/Scosche kit
WL-BMR Strut Bar/Custom rear vents
tmac1granger33 is offline   Reply With Quote
Old 11-09-2011, 02:25 PM   #68
Amenti
Amenti's Avatar
Drives: 2010 1LT RS A6, C&C, Victory Red
Eating too much popcorn can give you direticulitis (sp?), a very painful stomach ailment.
Anywho, this is looking pretty damned awesome Bmore. You're going to have a monster V6 before you know it. Personally, I'm going to TRY to save up for a custom supercharger kit, since Vortech is literally halfway across town (maybe 10 minutes, tops) from my house and they make a number of different centrifugal superchargers. It'll be a bit difficult, since I just bought a house a few months ago and my wife is about to give birth. LOL
*sigh*
Performance Mods: Injen Powerflow CAI, Doug Thorley Cat-Back Exhaust, Doug Thorley Shorty Headers, Trifecta Tune, TSW Nurburgring Wheels 20x9, 3.45 Ratio LSD Swap, VMax Black Ice-Olator
Appearance Mods: RiderGraphix LS7 Front Fascia Blackout Vinyl, Gill Insert Vinyl, Rear Deck Lid Vinyl (Gloss Black), Gary's Customs Painted Bowties
Coming Soon: BMR Trailing Arms
Amenti is offline   Reply With Quote
Old 11-09-2011, 02:28 PM   #69
Amenti
Amenti's Avatar
Thankfully, I've been lucky with Harbor Freight tools. My friend and I picked up a 300 ft. lbs torque wrench (went halfers on it) from there not too long ago, when I did my rear differential swap.
Everything he and I have gotten from there has been working well for years.
Old 11-09-2011, 05:47 PM   #70
bmorecam
Well guys... I really don't have too much time tonight to give you guys my full impression but so far things are looking good, really good lol.
The first thing that I noticed is that the car feel about 300 lb lighter. No matter what gear you are in you give some throttle and the car just go with no question asked. Even in 6th gear under 2000rpm the car just go. If that ain't torque I don't know what it is.
I have reset the ecm just as mace recommend so for about next 50 miles or so will be easy miles so the ecm can learn the new mods correctly.
And I almost forgot, after driving for about 20 minutes in the traffic I opened up the hood and I was shocked to feel that the manifold was not warm but cool to the touch.
I will give you guys my full review tomorrow when I have more time.
So far it was definitely worth every penny and a very good start to project #2.
Old 11-09-2011, 05:58 PM   #71
bossbunny
Mrs. Bunny to you
bossbunny's Avatar
Now I want this, bad.
Old 11-09-2011, 06:00 PM   #72
bmwdon
bmwdon's Avatar
so you found a tool to get at those allen headed bolts? good! I was going to suggest you find a cheap allen tool that fits, and the ratcheting box wrench that will hold that allen. Take the allen to a cutting disk and cut you off a short piece like 3/4" long, enough to go into the bolt and leave something for that ratcheting box wrench onto.
But the important thing is you got the spacers on there and the results sound promising! glad to hear it!! it only took those dudes a year to get back to anybody, but sure glad they did
Old 11-09-2011, 06:10 PM   #73
BaylorCamaro
AutoX is for fast DRIVERS
BaylorCamaro's Avatar
Drives: 2010 2LT/RS Supercharged
Awesome, can't wait to hear more!
Automotive youtube channel. / My First Autocross / My automotive blog / Build Thread
RX Super Charged / MRT V1 / ARH LT Headers and Cats / 2.5" Entire System / Ported & Polished IM / IM Spacer / RX Ported TB / Trifecta Tune / Brembo Brakes / Pfadt Sways, End Links, Rear Trailing Arms & Springs / SS Rear Diff.
Check out video's of my current set up! ==> RX Super Charged
BaylorCamaro is online now   Reply With Quote
Old 11-09-2011, 06:16 PM   #74
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
titties!
hapisok is offline   Reply With Quote
Old 11-09-2011, 06:18 PM   #75
hapisok
hapisok's Avatar
one question though...any plans to dyno the spacer separately from the ported manifold?
Anyone Dyno'd with a Ported Intake Manifold? TitoSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 04-04-2011 08:48 AM
Ported intake manifold antivenom Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 52 10-20-2009 09:50 AM
