11-10-2011, 12:39 PM | #1 |
Supercharged LSX
Drives: 2011 2SS/RS Black/Carbon Fiber Join Date: Dec 2010
Sprint Booster who has it, who's tried it?
So I was at SEMA and talked with the Sprint Booster reps. Who here has it, and who has personally driven a car that had it installed? I'm NOT asking for any opinions. Just want personal experience. I know it's pricey and the offer a 30 day money back guaranty. I told the rep that if I did try one that I would do a full write up on Camaro5 about it. Even if I don't like it. So before I try it I'd like to know what others thought from their personal experience.
11-10-2011, 02:18 PM | #2 |
Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
Don't waste your money. All it does is make the throttle blade move faster in relation to how fast you move the pedal. What's the point in that? Get a ported throttle body and your throttle response will be really improved, it's cheaper and you might pick up a few hp.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :( 2017 Silverado 5.3 all stock 2004 5.7 GTO 78mm turbo |
11-11-2011, 08:54 AM | #3 | |
Supercharged LSX
11-11-2011, 10:22 AM | #4 |
Drives: 2011 Camaro 2SS/RS (Black) L99 Join Date: Aug 2010
what is it even supposed to do?
11-11-2011, 10:34 AM | #5 | |
11-11-2011, 10:58 AM | #6 |
Drives: 2012 45th Camaro, 2SS/M6 Join Date: Mar 2011
i had one on my bmw 530i for about 5 days, took it off and sent it back. here's why:
they are actually completely worthless, for all intents and purposes. if you think about your pedal's angle of use from 0% depressed to 100% depressed, we can compare it relatively closely to a right angle. imagine that if every half inch of pushing down the throttle resulted in an equal throttle increase of 10%, then to get 50% throttle you would need to push down the pedal halfway. makes sense. with the sprint booster, it simply increases the percentage of throttle at lower pedal depressions. i.e. instead of normally having 10% throttle after depressing the pedal 10% of the way down, now you may see a throttle increase of 25% with the pedal 10% down. once you get up to the pedal being 75% of the way down, your throttle is maxed out and the rest of the accelerator pedal's travel is useless. that is what the sprint booster does. it sounds simple, but if you press more of the accelerator down without the sprint booster installed, you will get the exact same effect. people feel like with the sprint booster the car is faster because they barely move their foot at all on the pedal and the car will shoot off the line. it's just that less effort by your foot is deceiving you into thinking the car is moving faster, when in reality it's moving quicker with less physical effort by your foot. $300+ for an electronic lead foot is a waste of money. |
11-11-2011, 11:10 AM | #7 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Is this the same thing as the CoW booster that is on some threads here?
11-11-2011, 11:28 AM | #8 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
yeah that sounds stupid, just move your foot farther/faster and save the $$
11-11-2011, 11:32 AM | #9 |
Drives: Camaro SS Join Date: Mar 2010
I can think of a ton of other bolt-on's to spend dough on ($) which actually make HP/TQ.
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
11-11-2011, 11:47 AM | #10 | |
Supercharged LSX
11-11-2011, 01:28 PM | #11 |
the bimmer guys will swear up and down by them, mostly because there are not a lot of mods you can do on BMW engines that don't cost a fortune. so for them it is easy to praise any mod that doesn't break their wallet, and that's the only reason i was initially enticed. as another mentioned, you could spend $300 in exponentially better ways with the C5 however.
11-11-2011, 09:16 PM | #12 | |
Drives: 2011 IBM 1SS/RS L99 Join Date: Mar 2011
Just to play Devil's Advocate (cuz I'd never buy one): _IF_ this Sprint Booster doesn't void your warranty (I have no clue if it does), then on the autos, this might be a good thing for those who value their warranty. There have been forum members who state it works for them. Based on what I've read, it has potential because of the severe Torque Management on the L99s (and to a lesser degree on the LS3s). As I understand it, all the Torque Management does is limit your throttle by RPM. So if you floor it from a stop, at 1k RPM you get 30% throttle and it ramps up until it's at 100% at 3k RPM (my numbers might be off slightly, but I know I'm close based on previous threads). This is why the stock L99 guys have problems doing burnouts w/o brake stands. If the Booster were to open that by 10% at each RPM, you'd get 40% at 1000 RPM, which might be enough to light 'em up! Once again: I would NOT buy one. And I could be wrong. But based on what I've read, maybe there is something to it.
11-13-2011, 10:43 AM | #13 | |
11-13-2011, 03:01 PM | #14 |
Drives: G8 GXP manual Join Date: Sep 2010
Here's copy & paste from my post on the G8 forums:
At the risk of a flame war with those that opinionate on something they have NEVER tried ... ... I've had it on the GXP and my previous Mazda and is to me 1 of the first mods I like to do and the most enjoyable in day-to-day driving. The new generation won the SEMA award (so it ain't snake oil people ... it actually DOES do something) and has a button that you velcro under the dash where you can see it and allows you to re-map the throttle sensitivity from stock > stage 1 > stage 2. I generally run it on stage 1 unless I'm on the hiway where I'll put it on stage 2 ... just a small squirt of the gas pedal and you get instant response. Ya, it adds no HP but I don't mod to get more HP - I mod to make the car more enjoyable to ME and if HP comes along with it all the better. I like a more responsive car from throttle tip-in to handling than comes from the factory, always have ... the throttle part is now done and the handling is part way there with Lovells springs on currently and sway bars coming in the spring. You can push the pedal down more but that's not responsiveness to me, that's driving with a large wad of mash potato between your foot and the gas pedal. The reason people swear by it are because they've actually tried it ... the ones always arguing with us haven't. If you're close to a dealer ask them to do a test install ... mine did and I'm pretty sure they all will. If you don't like it nothing lost except your time. If you can get your tuner to re-map the throttle tables, go for it ... my unnamed tuner said there's nothing they can do (which I know is crapola) so I went with the Sprintbooster ... better choice in the end as it gives me the button anyway. This is akin to Subarus SI-Drive and BMW's M button where you have different choices of throttle sensitivity (albeit BMW's does more than just throttle). I LOVE mine.
2009 GXP, Manual with Sunroof
Zeta platform, LS3,TR6060 tranny ... ya, it's a 4-dr Camaro! Borla cat-back, H&R springs, & Sprintbooster & I love it! |
Thread Tools | |
Similar Threads | ||||
Sprint Booster Installed! | PercyJWellingtonIII | Off-topic Discussions | 10 | 06-17-2017 11:03 AM |
•► ► CoW BOOSTER!! ◄ ◄• | Sales@CoW | V8 Bolt-Ons & Tunes | 33 | 08-21-2012 03:03 PM |
Dont waste your money on sprint booster ever! | bmorecam | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 7 | 07-20-2011 11:44 PM |
SPRINT BOOSTER | cowboy1948 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 33 | 07-10-2011 12:29 AM |
sprint booster . looks good ? | mikeSS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 10 | 07-14-2010 06:16 PM |
