ADM PERFORMANCE
Old 11-10-2011, 08:37 PM   #1
Ls3Power
Drives: Black 2ss/rs
ls1 is sick!
I got a 2001 6spd ss camaro. Mods are slp air lid, jantzer TB, TB bypass, QTP long tubes with y pipe and slp loudmouth exhaust, w/ O2sims and extensions, red optima battery, corvette o2 sensors up front. Car has 128,000 miles on it. Spark plugs, wires, and fuel filter are fairly new.
Here's the problem, if I rev the car passed 3000 to 4000 rpms the lights in the car will flicker, the gauge lights dim and the volts drop. In addition to this the low trac or asr light would pop up even though the car is in neutral. The car will also pop and sputter at that range and if I rev it passed 5000 rpms, once the rpms drop to idle the car shakes and sputters as it tries to stay turned on. So I'll give some gas and the car will catch itself and idle normal.
At the track doing burnouts or launching the car from the line would create the sputtering and hesitation symptoms and would fix itself and then return at higher rpm. I would get the p0300 random misfire code, which means it can be anything. I also keep getting the 1637 code ecm/abs.
I need some help with this gremlin
Ls3Power is offline   Reply With Quote
Old 11-11-2011, 12:30 AM   #2
helmincamaro
Official Lounge BAMF
helmincamaro's Avatar
Drives: '97 Camaro
Send a message via AIM to helmincamaro Send a message via Yahoo to helmincamaro
could be a few different things..... I'd check the free stuff first..... make sure all your plug wires are on securely, alternator cables are snug, check you don't have a fouled plug etc. I know on mine, when the alternator was going bad, my gauges would flicker or get dim at times, especially when the defroster was on. If it is your alternator.... don't cheap out, get the good one, not a crappy remanufactured one..... I did that, and after the 5th replacement in a year, I just got a new one and haven't had an issue since. Make sure all your electrical connections are good, if its still having trouble, might be a bad coil. Plenty of people here with plenty of good knowledge to help ya out
Originally Posted by BowtieBelle View Post
I so didn't want to see poor dead white mouse butthole
helmincamaro is offline   Reply With Quote
Old 11-12-2011, 02:00 PM   #3
Ls3Power
what if I told you a while back that the red alternator cable that connects on top and goes to what I believe is the pcm, ripped off while doing a alternator replacement. I bought a new connector and just crimped the wires together and did not solder it. Could this be my problem?
Old 11-12-2011, 02:57 PM   #4
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
...Ripped off the connector? I take it you did it as a shadetree repair? I'd put cash money down that the power going to the PCM are getting fouled due to resistance issues on the wiring. Have a diagnostic test done on the PCM, I'm thinking that with a 'broken' (and it still is broken, not a single continuous wire) positive line, you may have ground, but power just isn't getting there like it should.
Leading to possible PCM issues which would cause all sorts of issues with the car's electronic systems. Kinda like duct taping someone's spinal chord back together after a broken back.
Zabo is offline   Reply With Quote
Old 11-15-2011, 12:53 PM   #5
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
Sounds like when you are under a serious load your power(electricity) is grounding from something, somewhere.
Thats a good bet its something from the alternator or battery, something causing that much trouble and is even messing with gauges, etc. Will be from a battery or alternator.
If it was just a plug wire, coil, or something you would just have poor performance, not blinking lights.
Make sure all of the major wires that carry the most current are done right, its cheap enough to do
What do you think, will it look sick? Tires with white lettering outside Fantasm Cosmetics and Lighting Modification Discussions 89 06-16-2013 10:57 PM
What is the best motor oil to use in a 1998-2002 LS1? Blueovalman Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 10 04-13-2011 02:29 AM
Tips for shopping for a 1998-2002 LS1? Blueovalman 4th Generation Camaros 8 04-12-2011 03:19 PM
Anyone go from an LS1 an LS3? MustangKillr Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 45 01-02-2011 12:48 AM
4th Gen's now in the 9's, cam only danhr Dragstrip and Launch Techniques Discussion 5 11-22-2010 12:24 PM
