Gen5DIY
Old 11-15-2011, 10:20 AM   #1
LOWDOWN
Downright Upright
Drives: Daily
There'Z Room At The Inn...
With today's pricing announcement for the ZL1...$54095 + Options + Frgt + Gas Tax...there would seem to be a large area of fiscal "no man's land" between the SS family and the ZL1. Like the $40s...
So, boyZ and girlZ, can there be a "proper business case" made for either, or BOTH, of the following:
1SS + 1LE mechanical components = low-low $40s
1SS + ZL1 mechanical components + LS7 = Z/28 = upper $40s
2SS content as an option
Coolers and 1LS trim as a "track-ready" option
Feedback please.
LOWDOWN is offline   Reply With Quote
Old 11-15-2011, 12:39 PM   #2
LOWDOWN
Downright Upright
Drives: Daily
It was mentioned, some time ago, the BOSS was a two-year iteration; MY '12 and '13. With the '13 Shelby housing a 5.8L blown behemoth, is it possible the BOSS follow-up will, in fact, be similar to the '71 follow-up to the '69-'70 BOSS 302? What followed was a 1-year version called the BOSS 351...or just slightly below 5.8L...
Will we see a normally aspirated version of the 5.8, at something around 500 hp, in a BOSS-style 'Stang? That, my friends, would make a helluva 50th Anniversary trinket...painted GOLD, of course...
Where's an LS7/1LE when you need one? Properly named, of course...
Old 11-15-2011, 01:33 PM   #3
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
The HUGE price gap is the problem here. GM has created a demand for a more performance geared Camaro, however many will want and not afford. Enter the Z28!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!
2cnd chance is offline   Reply With Quote
Old 11-15-2011, 01:49 PM   #4
LOWDOWN
Downright Upright
Drives: Daily
1LE + LS7 = Z/28
How 'bout we ACT instead of REACT?!
Old 11-15-2011, 02:10 PM   #5
Cam#7
Cam#7's Avatar
Drives: 2011 2LT IBM / SIM stripe 6M
Well, there's certainly a pricing model in the 40s that should work for a Z/28. There's every component to build it but the engine. I think not having the news out on the C7 Corvette certainly hurts any new engine announcement.
If we don't hear of Z/28 by the Detroit show, my money is the 1LE is a SS option.
Cam#7 is offline   Reply With Quote
Old 11-15-2011, 09:25 PM   #6
2cnd chance
Originally Posted by LOWDOWN View Post
1LE + LS7 = Z/28
That's a big YES!
Old 11-21-2011, 12:30 AM   #7
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Feedback please.
I like this idea...the ZL1 is pretty much...everything. You get no options in the mechanical department other than an auto, and of the cosmetics...we're taking things like wheels, stripes, and a clearcoat over the CF insert or not.
Not complaining...I did order it, after all. Very happy.
But I like where you're going.
Pull off the coolers, de-feature the interior back to a 1SS level, and give it the 1LE exterior treatment...you could be looking at high 40s, pretty easily I think...
The equipment group is worth at least $4000, I think, the LS7 is about $500 less expensive retail......and the coolers a little over $1000, maybe?
But......Would it make more sense to turn this proposal into a "Z28 package"? Because you're talking about offering 2SS content, as well as optional powertrain items...that could get complicated, and expensive to do.
OR - What about this:
Z28 Model:
1LZ trim: 1LE concept As-Is = low-mid $40s
2LZ trim: ZL1 minus interior content, LS7 swap, 1LE-body swap, High 40s
They could work to avoid the GG tax on the 2LZ trim level...and that would put the difference between it and the least-expensive ZL1 you could get arond $5000...That's a bigger difference than the Boss Laguna Seca and GT500 (actually, those two are almost identical in price...)...
EDIT:
OR....
Let the 1LE be an appearance package (GFX, hood, wheels, brakes) for the SS...
And do the Z28 as described in 2LZ, above. Pricing, and simplicity would seem to support this tactic...no?
Old 11-21-2011, 07:08 PM   #8
LOWDOWN
Downright Upright
Drives: Daily
1LE, as "conceived", makes a great addition to the Camaro clan as an SS add-on. Since the ZL1 is being offered in topless form, there's a definite case for the 1LE option to be available across the SS board: 1SS, 2SS, solid-roof or topless. Taking the "hard parts" and "cosmetics" into consideration, the MSRP for the 1LE Package should be under $10K.
BUT...
I personally don't see the 1LE/SS as an "exact" Z/28...
Just as in its original form, a Z/28 requires a lil bit more "steam" in the "boiler room". Contrary to brochure numbers, the 302 was NOT less powerful than the predominant SS engines. It made an honest 350+ hp, and was factored by NHRA as such.
What do we have to work with, on the shelf and good-to-go, that bridges the hp gap between the predominant SS engines (400-426 hp) and the ZL1's 580?
Only one...and the only one deserving of iconic nomenclature...
For those still scratching their craniums, read my "sig".
Working backwards from a ZL1 Coupe price of $54-ish, by substituting 1LS trim on a Base 1SS chassis, a lunch bucket track-taming LS7/ZEE should slide in at BOSS LS dough...and stun it like a bucking bronco's hoof to the head!
Even LESS, if you "option" the coolers and the body-stuff...not all Gen-1 ZEEs were festooned with spoilers 'n fancy threads...
Old 11-21-2011, 09:43 PM   #9
OldScoolCamaro
Sold. Nomenclature LS7, when can we buy it?
HEAD room Coupe v Convert v Sunroof JCSSCamaro 5th Gen Camaro SS LS LT General Discussions 15 03-18-2014 03:27 PM
Brus Room Sunrise 4th Anniversary Party and Car show- June 5th Sunrise, Florida thebeast916 USA - Southeast 2 06-02-2011 08:49 PM
Jameson Inn, Fri & Sat, $109 for both nights GMteSSted 2010 Camaro5 Fest (I) 1 04-09-2010 12:43 AM
Camaro5.com Chat Room camaro5 Site Related Announcements / Suggestions / Feedback / Questions 32 01-04-2009 08:15 PM
Foot ROom MerlinZero 5th Gen Camaro SS LS LT General Discussions 4 12-03-2008 08:22 AM
