sjm autoprod
Old 11-15-2011, 11:15 PM   #1
wake12
Drives: 2011 SS2 Black
different Volant Cold air intakes
Does anyone know the differences between the volant cold air intake part #15062 and #415062? Also will the powercore (part #61503) work with either of them or just the 415062?
wake12 is offline   Reply With Quote
Old 11-16-2011, 02:46 PM   #2
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
Not sure if that filter would fit but the differance between the two kits is that one comes with an oiled filter and one comes with a dry filter. The rest of the kit is the same.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is offline   Reply With Quote
Old 11-16-2011, 09:10 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
You might want to check to see if they got the problem fixed where they caused high LTFT's. They would throw a code for this. Haven't heard if they fixed it though.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 12-27-2011, 01:46 PM   #4
DVAS
Drives: 2011 Camaro 2SS
Can you tell me what the lftfs mean, and has anyone heard of a fix ? I saw another thread on this intake, and no problems reported, but hints of issues before........ I had a volant on a 08 hummer h2 and loved it, so wanted to use it again but on the SS...
Thanks
DVAS is offline   Reply With Quote
Old 12-27-2011, 02:11 PM   #5
Kiowa88
Out Front!
Kiowa88's Avatar
Drives: OH-58D (R)
I've had the Volant dry filter since March of 2010 and have had no codes thrown because of the filter.
I will say this though, the plastic tube that connects the filter housing to the throttle body doesn't seem to fit properly/isn't quite long enough and has come loose. Threw a CEL saying the engine was running lean. Other than that no issues!
B Troop, 3-17CAV - Out Front
Kiowa88 is offline   Reply With Quote
Old 12-28-2011, 02:08 PM   #6
DVAS
Thanks kiowa88
Old 12-29-2011, 08:34 AM   #7
axis
Search Ninja
axis's Avatar
LTFT's are long term fuel trims. They are adjustment values to your fuel trims that are stored in the PCM.
High LTFT's can throw the lean CEL.
Some have blamed the filter but I don't buy that. If I remember correctly, there was an physical issue with the molding around the MAF hole. It was never confirmed, but the general consensus was that this might be causing turbulent airflow and disrupting the MAF readings. I know at least one vendor had notified Volant about the issue. Like I said it was never confirmed by Volant but several people had the same issue and it was documented to be high LTFT's. Others haven't thrown CEL's but I never saw if their LTFT's were elevated. I'm thinking they won't throw a code till they hit high teens/low twenty's.
Halltech CF 102 fed
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 08:50 PM
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
Roto-Fab | Cold Air Intakes | Engine Covers | Washer Reservoir Relocation Kit | Fuse+ AutoAgenda V8 Bolt-Ons & Tunes 7 07-11-2011 07:50 PM
Breath clean Air GmPartsDirect.com Interior Parts & Accessories 0 03-30-2011 05:58 PM
AirAid Cold Air Intake anyone? FLYNNZL1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 10:05 PM
