Gen5DIY
Old 04-11-2009, 04:55 PM   #1
sdill
sdill's Avatar
Drives: 2010 CGM 1SS/RS
Question Manual Transmission Driving Questions
Hey guys I just have a general manual driving question.
Back when I was considering several other cars, I was on a forum and the topic was manual driving. One of the guys on the forum was saying that when he stops at a light he leaves the car in first with the clutch fully engaged. He said this was not "riding the clutch." But to me that seemed odd because every time ive seen somebody driving manual they left it in neutral at lights.
So my question is, is leaving the car in first like this at a light considered riding the clutch? And if not then what is "riding the clutch"?
Thanks
sdill is offline   Reply With Quote
Old 04-11-2009, 05:03 PM   #2
snizzle
Recalled user
snizzle's Avatar
Drives: '12 2SS MT 45th AE
That's not riding the clutch. Riding the clutch implies it's partially disengaged. Basically it's like keeping your foot rested on the clutch while you drive or partially pressing in the clutch while backing up short distances.
Unnecessary wear and tear.....
Old 04-11-2009, 06:48 PM   #3
toehead93
Drives: 2014 2SS/1LE
Hey Snizzle, where is the Drizzle?
toehead93 is offline   Reply With Quote
Old 04-11-2009, 07:01 PM   #4
New2010CamaroLover
New2010CamaroLover's Avatar
Drives: 2015 Ashen Grey Metallic 2SS/RS M6
that's not riding the clutch but it's not good to keep it engaged like that at a light... wears them out quicker...
"The Golden Age of muscle cars was not 30 years ago, it's now, long live the Camaro!"
New2010CamaroLover is offline   Reply With Quote
Old 04-11-2009, 07:09 PM   #5
mxkx250
mxkx250's Avatar
Drives: 12 ZL1, 98 Camaro SS, 67 RS/SS
Send a message via Yahoo to mxkx250
Which is worse? Leaving the clutch disengaged, pedal to the floor, wearing the throwout bearing. Or putting the transmission in neutral, wearing the transmission bearings without the gears moving to splash fluid on them.
mxkx250 is offline   Reply With Quote
Old 04-11-2009, 09:13 PM   #6
spd98
Drives: had a goat
There is no wear on an engaged clutch. The only wear occures when the clutch is slipping before it's fully engaged.
This is not riding the clutch. Riding the clutch is when you leave weight on the clutch and leave it partially engaged.
spd98 is offline   Reply With Quote
Old 04-11-2009, 09:21 PM   #7
Blownhotrodder
Blownhotrodder's Avatar
Drives: Z06
Leaving the car in gear at a light with the clutch to the floor wont hurt anything. You can either put it in gear or in neutral, doesnt matter that much.
Blownhotrodder is offline   Reply With Quote
Old 04-11-2009, 09:30 PM   #8
Gramps69Z
Still waiting on the Z
Gramps69Z's Avatar
Drives: 69 Z/28, 06 Denali, 09 CTS
Send a message via AIM to Gramps69Z Send a message via Yahoo to Gramps69Z
What he said.
Been driving like that for 37 years.
October 31, 2015 at 0700 - officially retired
1969 Chevrolet Camaro Z/28
2006 Denali
2009 Cadillac CTS
The Six Old Guys
The last thing we want is to ship something that isn't right.
Gramps69Z is offline   Reply With Quote
Old 04-11-2009, 09:32 PM   #9
dougmac
Drives: 2011 V6 MCA & 1969 GT Mustang
I think the "correct" way to drive a manual (at least how it is normally taught) is to have the trans in gear with the clutch pedal to the floor and your right foot on the brake at a stop.
Personally, I knock mine out of gear as I come up to a light without even touching the clutch pedal and roll to a stop ... then push in the clutch / put it in gear right as the light is about to change. This saves wear & tear on the T-O bearing and my left leg.
Doug
dougmac is offline   Reply With Quote
Old 04-11-2009, 09:38 PM   #10
Boogie832
12-08-08 Arrived 06-02-09
Boogie832's Avatar
Drives: 1967 Camaro Richmond5-speed
Doug
Same here. A lot of town driving (stop & go) redlights etc. will take a toll on the leg, foot. I've driving quite a few large trucks and some of them have pretty stiff clutch petals. I do have a habit of putting it in netural while setting at a light.
Ordered 2SS/RS IOM,12/08/08.
Arrived at Dealer 06-02-09
Brought Home! 06-09-09
Boogie832 is offline   Reply With Quote
Old 04-11-2009, 09:59 PM   #11
wjones14
wjones14's Avatar
Drives: 2015 BMW M235i
Doug
I've been doing the same thing ever since I figured out that you can easily pop the car out of gear into neutral without clutching, as long as you let the revs die first. I mean I don't do it every time, but when I'm lazy.
But I never did understand WHY it's so easy to pop the tranny out of gear with only an easy tap on the shifter and no clutch - does anyone know?
2015 BMW M235i 6-speed
Sold: Screaming Yellow 05 Mustang GT 5-speed
Other vehicles: 2011 Candy Lime Green Kawasaki Z1000 (1/4 mile - 10.38 @ 129.61 mph - stock); 2003 MINI Cooper R50 5-speed
wjones14 is online now   Reply With Quote
Old 04-12-2009, 07:10 AM   #12
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
You can shift into gear without using the clutch too, you just have to rev-match 100% perfectly (which is impossible to learn with a modern synchronized transmission, which gives you no feedback as long as you're close). I don't recommend making a habit of it unless you've got an ancient unsynchronized transmission.
The purpose of the clutch (in this context) is to unload the drivetrain, removing all torque from it, so that you can shift. As long as you unload it, it doesn't matter how you unload it - clutch or otherwise. To pull it out of gear, it's easy to unload since it's already perfectly rev-matched, so you just need to make the engine keep its own RPM up but not push or pull on the transmission. To do so, you have to have pretty accurate timing, which is easy to learn and somewhat harmless if you're wrong.
I like to pull it out of gear without using the clutch and do it often when I just need to be in neutral. In my car, I take my foot off the gas and about 1/2 second after fully removing my foot from the gas pedal, a small push puts it in neutral (it feels exactly the same as if I had used the clutch).
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 4242 02-17-2014 08:57 PM
Tips on Driving a Manual Trans Zabo General Automotive + Other Cars Discussion 23 01-14-2013 03:35 AM
Why aren't there any Aqua Blues yet? txcamarogirl 5th Gen Camaro SS LS LT General Discussions 40 08-20-2009 10:05 AM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 05:11 AM
