SDPC
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 11-18-2011, 03:15 PM   #1
bftcamaro
Drives: 92 rs v6
92 camaro rs stalling and car turns off. smh
i own a 92 camaro rs will turn off while running and also stalls any ideas
bftcamaro is offline   Reply With Quote
Old 11-18-2011, 04:03 PM   #2
garcmol
garcmol's Avatar
Welcome to the site!
My '91 did this when I got it as well.
Fuel filter
ignition control module
clean distributor contacts inside, replace if corroded too badly
clean rotor tip, replace if corroded too badly
replace the spark plugs
inspect plug wires for any melting/tears
dilectic grease in the ends of the plug wires where they contact the plugs and distributor cap
check your timing
check your vacuum lines
You can find a lot of good info on thirdgen.org Again, welcome!
Old 11-18-2011, 04:16 PM   #3
bftcamaro
Drives: 92 rs v6
i have already changed the spark plugs,spark plug wires, distributor cap,fuel filter,belt,rotor button,pcv valve,and air filter
Old 11-18-2011, 04:26 PM   #4
garcmol
garcmol's Avatar
It's throttle body injection correct?
If yes, the fuel pump may be going bad or have a loose connection. Or, you may have an injector going bad.
Old 11-18-2011, 04:43 PM   #5
bftcamaro
Drives: 92 rs v6
im not sure i kno its MFI though but i dont kno what that means
Old 11-18-2011, 04:52 PM   #6
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
Check the fuel pressure and is it tpi or tbi?
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires.
2000 1500 silverado extra cab
Camarowguy is offline   Reply With Quote
Old 11-18-2011, 04:56 PM   #7
bftcamaro
Drives: 92 rs v6
its mechanical fuel injection
Old 11-18-2011, 04:58 PM   #8
garcmol
garcmol's Avatar
It's multi port injection. But I really don't know how the V6 is set up.
If it has a traditional air cleaner on top with the wing nut, take it off. If there is a carb there it should have two bulb looking things inside it. That will be the throttle body injection and those bulbs are your injectors. If this is the case and the engine starts then the injectors are doing their job but the fuel pump can't get enough fuel to them.
Old 11-18-2011, 05:10 PM   #9
bftcamaro
Drives: 92 rs v6
i could post a pic of the engine if it will help
Old 02-12-2012, 03:05 AM   #10
Third-Gen
Olson Kustom Works
Drives: 91 Camaro, LS3, TVS2300, TR6060
check the other post you made. fuel pump to pickup tube hose. turns to mush at 120-130k.
Third-Gen is offline   Reply With Quote
Tips for first time Manual Transmission Drivers from a new Camaro Owner (First post) LoneCynic 5th Gen Camaro SS LS LT General Discussions 45 04-03-2016 03:46 AM
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 08-16-2014 03:07 AM
Camaro Still winning - Mustang sales not enough to sustain Flat Rock plant Rogue Leader 5th Gen Camaro SS LS LT General Discussions 141 07-02-2011 08:19 AM
My LLT engine is blown on my 2LT, any recommendations? Camarodriver 5th Gen Camaro SS LS LT General Discussions 173 12-17-2010 07:17 AM
The Day Has Finally Arrived - Pictures of my brand new Camaro!! :) Embalmer Camaro Photos | Spyshots | Video | Media Gallery 179 04-25-2009 07:29 PM
