JDP Motorsports
Old 11-27-2011, 05:05 PM   #141
Asylum
Asylum's Avatar
Drives: 2010 2SS RS Black on Black Manual 6
Originally Posted by JANNETTYRACING View Post
I have to disagree with your assessment, As a Tuner with 30 years experience and Last year Had an Advanced Training Class with Greg Bannish, that it is NOT always in the Tune, We covered this extensively in my Class.
If you put 10 lbs. of crap in a 5 lb. bag it is going to break.
The currently available cats can NOT handle the Exhaust Gasses from a supercharged 6.2 liter Engine
Put 10 Liters of Air through a 6 Liter Hole and it is going to over heat, melt and fail which if left unchecked will Fail a Piston in the engine.
Ted.
I have to disagree with you,
Last I checked I routinely overload my grocery bags, not all of them break.
Asylum is offline   Reply With Quote
Old 11-27-2011, 05:07 PM   #142
Asylum
Asylum's Avatar
I think this discussion should be more.
"If running a supercharged application, it is 'wise' to remove the cats."
Old 11-27-2011, 05:33 PM   #143
Blacknight11
Blacknight11's Avatar
Drives: 2011 Black 2SS/RS
Confused
Since I read the initial thread I have been researching and still confused. I have looked at Callaway site and they say nothing about this issue. The package listed below is with the stock exhaust I think. I can't see how a company like this would install a SC and leave oem pipes on if they knew it would cause an issue. Just trying to get a better understanding on issued before throwing money away.
Eaton Roots-style TVS2300 supercharger, with black powder-coated housing
Liquid-to-air intercooler, integral to intake manifold base (pat. pend.)
Increased flow rate fuel injectors
Callaway carbon fiber injector covers
Callaway high flow intake system
Callaway low restriction exhaust system
Callaway embroidered headrests
Callaway embroidered floor mats
Callaway anodized aluminum door sill panels
Callaway Camaro key fobs
Callaway badging, exterior and interior
Callaway Camaro authenticity documentation
Callaway 3 year/36,000 mile limited warranty
Blacknight11 is offline   Reply With Quote
Old 11-27-2011, 05:36 PM   #144
TCAT
TCAT's Avatar
Drives: Has Wheels
I'm thinking companies like Callaway, SLP, etc that sell modified Camaros with Forced induction keep the stock cats on the vehicle so it passes even the toughest emissions standards regardless of the State it will be registered in (like Cailfornia for example).
TCAT is offline   Reply With Quote
Old 11-27-2011, 05:53 PM   #145
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
I think the performance vendors thought all these CAT's for the 2010+ Camaro's were a quality product, and up until recently (once peeps started complaining) will encourage maintaining stock CAT's if upgrading to an SC.
I've never heard anyone before say there were issues with aftermarket CATS and / or SC's until I found this thread very recently.
The curious thing is why none of the manufacturers are piping up here to either defend their position or communicate any changes in products.
For example: When I see something like this advertised, the last thing I'm thinking is "These CATS are not made for high-performance vehicles and will melt."
http://www.dynatechheaders.com/access_powercat.html
calbert1999 is offline   Reply With Quote
Old 11-27-2011, 06:32 PM   #146
grocerygetter
instigator
grocerygetter's Avatar
So like the other guy asked...stock cats supercharged is fine if under 600?
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 11-27-2011, 08:09 PM   #147
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
It all comes down to Usage, if you have a supercharger on board that makes 30 lbs of boost but never push the gas pedal hard enough to make 1 lb of boost it will never be a Problem
If you have a supercharger that puts out 10 lbs of boost and you use it frequently there will be a Problem.
Again it can't be nailed down to a Horsepower number too many Variables.
If you never us all the power No problem.
If you use all the power all the time it will be a problem.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 11-27-2011, 08:37 PM   #148
MarylandSpeed
MarylandSpeed's Avatar
Drives: 2012 ZL1 & 2010 2SS/RS
This thread is turning into a bunch of nonsense. After reading the thread, you would get the idea that pretty much everyone with a supercharger is certain to have their high flow cats fail. Also, you probabaly come away with the idea that Kooks cats are terrible, and the most likely to fail.
However if you read the thread, and count..only 4 people actually posted that their high flow cats failed on their actual Camaros. Of those four, one was Kooks, one was SLP, one was ARH, and one was undetermined. I did not go to the trouble to see who they were tuned by, but that could be relevent. That is after 3500 views in this thread. So while a lot of people might claim to know someone who had cats fail, or heard a story, this thread makes it pretty obvious it is the exception, not the rule and it can happen with any header set up. A trip to Camaro5fest, or any new Camaro show for that matter will tell you how many Supercharged Camaro's there are.
Here are some more thoughts-
1- Callaway, SLP, and so forth do not sell their cars with LT headers because you can't sell a car new without factory cats. It will not pass most states initial inspection since headers relocate the cats and are for off road use only. SLP offers a new 600+ HP supercharger package on their website that includes their LT's with cats.
2- Preemptivly gutting your cats is nonsense. I have never seen a customer of mine, nor have I seen posted where a failed cat caused a motor to fail. Can it happen?..yes..but for it to happen you would have to ignore some pretty HUGE driveability issues. Cats have failed since the product was introduced..plenty of people have had it happen over the last 30 years. However often when you have seen it happen to do you recall a cars motor being blown? The odds must be astronomical, and even then are part the owners fauilt for ignoring obvious warning signs. When you mod cars, you have to balance out these different things. Yeah..there is a 1 in a million chance your cat could fail..and that could lead to somehow you ignoring it and blowing your motor. But there are plenty of other things with a much greater chance of failing. I mean hell..the stock oil pump toasted my supercharged motor..anything can happen.
The bottom line however is, gutting cats you paid $400 for because you heard somewhere that someone had them fail, and there is a 1 in a million chance if you ignore the warning signs your motor could blow is non sense. While the risk of failure is higher on a supercharged car (like any part really) assuming you have a decent tune, you have a good chance of your cats never failing or giving you an issue. On the outside chance they do fail, you should have plenty of warning in terms of drivability issues...they have a warranty..just get them replaced.
As for people talking about putting the stock manifolds/cats on over this issue..that is even crazier. Take off parts you paid good money for that work fine, to end up losing 60+ HP because there is a chance a part might break. The odds of your superchager breaking something very expensive in the engine or drivertrain is much higher than cats failing and causing signifigant damage. I don't see people taking their superchargers off.
443-730-9428 - www.marylandspeed.com - Great Prices and Free Shipping!
* CURRENT SALES * ORDER TERMS * DISCOUNT POLICY
MarylandSpeed is offline   Reply With Quote
Old 11-27-2011, 08:49 PM   #149
Asylum
Asylum's Avatar
However if you read the thread, and count..only 4 people actually posted that their high flow cats failed. Of those four, one was Kooks, one was SLP, one was ARH, and one was undetermined. I did not go to the trouble to see who they were tuned by, but that could be relevent. That is after 3500 views in this thread. So while a lot of people might claim to know someone who had cats fail, or heard a story, this thread makes it pretty obvious it is the exception, not the rule..and it can happen with any header set up.
I love how you post with information, supporting evidence, and logic. To bad other Vendors like Janetty couldn't follow your lead.
The purpose of a forum is to educate people, not badger whos got a bigger prick... Write that down Ted.
I'm siding with Maryland,
Old 11-27-2011, 09:20 PM   #150
Big Daddy Kane
Big Daddy Kane's Avatar
Drives: Red 1SS
Whoa! This is starting to get ugly!!
I believe Ted is just saying high flow cats aren't junk, they're just not built to hold up to the abuse a supercharged motor can put out.
Kooks LT Headers/catback exhaust, E-force supercharger, JRE fuel line upgrade, JRE differential, 3.91 LPE gears, Roto-fab intake, JRE tune, DSS Carbon Fiber driveshaft, MGW shifter, Hotchkis chassis braces
Big Daddy Kane is offline   Reply With Quote
Old 11-27-2011, 09:29 PM   #151
MarylandSpeed
It's not something I want to be vendor vs. vendor. I am just presenting another view and trying to get people to think more. The bottom line is, I want my customers to be happy, and I would not run cats on my own supercharged car, or recommend them to customers if I thought there was an abnormal chance of them failing. With a supercharged car, the chance of everything failing is higher no doubt. However I have enough of a customer base to know that threads like this make the issue seem way bigger than it is.
Old 11-27-2011, 10:06 PM   #152
BackinBlack
KASPR
BackinBlack's Avatar
Drives: 2010 Black 2SS RS LS3
Asylum, at what point did you think this thread was vendor vs vendor? You are declaring sides when there aren't any sides to be claimed. Just opinions; some of them experienced, some from their own observations, some from reading nothing more than this thread.
BackinBlack is offline   Reply With Quote
Old 11-27-2011, 10:44 PM   #153
Asylum
Asylum's Avatar
Ted.
This was the tipping point for me..
May I ask someone to comb over this entire thread, find out who posted that HAS Melted cats, or an engine problem, and then provide the shop they received the work from?
I anticipate the response will rhyme with Serengeti. or Spaghetti, or Fast Eddie.. Or. well you get the point...
Also it's fun from time to time to be devil's advocate
Old 11-27-2011, 10:48 PM   #154
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Not at the expense of any vendors on this site. Please take care not to single anyone out just for the sake of "playing devil's advocate"...Thank you.
SLP Headers / High Flow Cats (CHECK ENG LIGHT ON) HELP LENN2010Z28 Tuning / Diagnostics -- engine and transmission 10 01-23-2012 06:55 PM
Question about JBA High Flow Cats fitment with Flowmaster American Thunder Catback TCAT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2011 03:04 PM
Those with LT's, RESET your check engine light! TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 107 08-18-2010 02:51 AM
Thew check engine light... need help!! Spiffyguitar Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 08-10-2010 03:26 AM
Dynojet results for intake, headers, exhaust with SOLO hiflow cats! topgun1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 07-02-2010 07:52 AM
