Solo Performance
Old 11-20-2011, 09:03 PM   #29
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by 69 Rebel View Post
Thats crazy, if that can be proven i would be looking for a good lawyer. Thankfully my cats are gutted
The problem with this is, most manufacturers will only issue a warranty on THEIR parts...that's where an enthusiast needs to take care to avoid these problems by doing some research and protecting themselves...some aftermarket parts don't work well with each other.
I'm curious....do any of these Hi-flow cat's claim to be for use with FI applications?
Originally Posted by TCAT View Post
So, all these supercharged cars like the ZL1 and GT500 both putting out great power, should there be many problems with te stock cars for future customers? I would assume so, because there running stock cats and not even high flows.
Nope. Because they've been designed from the factory to handle their own power, heat, and pressures. I'm not sniping at the aftermarket when I say this...but there is an inherent advantage to OEM equipment where durability is concerned...
Old 11-20-2011, 09:24 PM   #30
Black GT
Banned
Drives: 2006 Mustang GT
The ones I know of are all FI motors( one a built stroker motor with less than 5000 miles)
In Febuary,when the TVS goes on my car the cats are gone.
Black GT is offline   Reply With Quote
Old 11-20-2011, 10:31 PM   #31
FloMoCamaro
FloMoCamaro's Avatar
Drives: 2010 Camaro SS
Originally Posted by IROCanSS View Post
600... Wheel or crank? Big difference and important.
Ooops - sorry - 600rwhp
FloMoCamaro is offline   Reply With Quote
Old 11-20-2011, 11:03 PM   #32
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Originally Posted by HufferSS View Post
No it can't bust your motor or smash valves into a piston. It could overheat a cylinder if it plugs up BUT the engine will run very poorly and you will know something is wrong....if you keep driving it that way then you get what you deserve for being stupid.
I think much of the issue is that many tuners run their FI tunes extremely RICH in order to keep the motor from detonating and therefore blowing up.....RICH......kills the cats. It isn't the cats fault...it's the tuners fault, imho.
Mine was tuned a few times, initially running a bit rich but that was corrected and we had it tuned just right.
My engine actually went; piston #6 damaged too. I've done research on my exhaust and supposed to be the best of the best from the partular vendor I used. However, I'm still going to have my CATs looked at just to make sure they're not melted.
I don't want 2nd. motor busted if this was the cause. There was no detonation, no codes, but valve bent, and hole in piston. We just assumed it was due to crappy hollow GM exhaust valves and we should have changed them along with the rest of the head assembly.
This is quite rediculous in my mind. I can't get my head wrapped around, upgrading exhaust, with HF CATS which are designed for high performance engines and they melt, blowing back into cylinders? I don't understand that logic. I've never seen a vendor quote their CATS will melt if more than x-hundred HP. There is really something very wrong with this picture, and I agree with 69 Rebel could be cause for lawuits if this is in fact causing engine issues for most people.
Might be a good idea to post brand and model of CATS everyone has to get the vendors and / or manufacturers to pipe up and let us know whats going on or how to avert this type of issue.
Buying CATS just to gut them, just to avoid a blown engine doesn't seem the way to go.
calbert1999 is offline   Reply With Quote
Old 11-20-2011, 11:14 PM   #33
YOUNGnRECKLESS
Building the Beast
YOUNGnRECKLESS's Avatar
Drives: 2010 VR LS3
Originally Posted by Black GT View Post
It's a known problem in the Mustang community that the KOOKS high flow cats are crap.
There have been a couple people lost their motors because of them.
interesting.....cant believe it.
YOUNGnRECKLESS is offline   Reply With Quote
Old 11-21-2011, 09:33 AM   #34
HumanWiki
Drives: Car
Interesting.... I have a rattle in my left HF cat.. I've not opened the pipes to look at them though..
HumanWiki is offline   Reply With Quote
Old 11-21-2011, 09:44 AM   #35
TCAT
TCAT's Avatar
Drives: Has Wheels
Hmm...That's interesting, thank you.
I wonder if these cars (ZL1 and GT500) will start to see stock cat issues when the power is raised to the levels some folks have on here 600rwhp or more). It's so true though, OEM and aftermarket parts may have two different ideas of what "quality" components are.
Now I'm trying to figure out whether I should sell my High Flow Cats (JBA) that I haven't installed yet, and just go with Mid-pipes without cats. I don't want to have future problems with the cats. Once I get them installed and have the car retuned, I plan to hit 600-650rwhp.
TCAT is offline   Reply With Quote
Old 11-21-2011, 09:54 AM   #36
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Most Cat Converters are Sized and designed around the Cubic inches of the Engine.
In this case 6.2 Liters, they will live a Happy and Productive Life.
Add a Supercharger with Say 7-8 PSI they 6.2 Liter Engine just became 9.3 Liters which far exceeds the Cat Design which causes Overheating and Failure.
The Cats need to be Double they're current Size to handle the Additional cubic inches.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 11-21-2011, 09:58 AM   #37
TCAT
TCAT's Avatar
Drives: Has Wheels
Ted.
Does that apply to the high flows as well. Can some of the high flow cats on the current market handle boosted LS3's at 8-10psi? How long do high flow cats usually lasted on turbocharged or supercharged LS3's?
I wonder if it would be better to go with mid pipes w/out cats. High flows would be a waste of money if they keep blowing out all the time. I'm nervous about this and I'm on the stock cats.
Old 11-21-2011, 10:26 AM   #38
JANNETTYRACING
YES.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 11-21-2011, 10:45 AM   #39
TCAT
TCAT's Avatar
Drives: Has Wheels
Thanks Ted. Well, I guess I'm selling my high flow cats and getting mid pipes, lol.
Old 11-21-2011, 11:25 AM   #40
calbert1999
Camaro SS Lover
Ted.
Can you recommend brands you know that will hold up to 9.3+litres?
Old 11-21-2011, 11:37 AM   #41
JANNETTYRACING
If they existed
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 11-21-2011, 11:43 AM   #42
TCAT
TCAT's Avatar
Drives: Has Wheels
Edit
SLP Headers / High Flow Cats (CHECK ENG LIGHT ON) HELP LENN2010Z28 Tuning / Diagnostics -- engine and transmission 10 01-23-2012 05:55 PM
Question about JBA High Flow Cats fitment with Flowmaster American Thunder Catback TCAT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2011 02:04 PM
Those with LT's, RESET your check engine light! TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 107 08-18-2010 01:51 AM
Thew check engine light... need help!! Spiffyguitar Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 08-10-2010 02:26 AM
Dynojet results for intake, headers, exhaust with SOLO hiflow cats! topgun1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 07-02-2010 06:52 AM
