Classic Industries
Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications.
Old 11-22-2011, 03:47 PM   #1
SETFREE
SETFREE's Avatar
Drives: 2010 CHEVY CAMARO
Carbon Fiber Door Panel? (Vinyl)
So I am wonder if anybody has done this yes, I want to make the Grey portion of my door panel black carbon fiber, the problem is I tried a piece of normal Vinyl and it would not stick, Before I go buying the better 3M dry Carbon Vinyl I want to know if anybody has done this before.......and if so how did you get it to stick and the textured surface like the center of the door panel
Thanks In Advance!
SETFREE is offline   Reply With Quote
Old 11-22-2011, 03:54 PM   #2
PLuche
PLuche's Avatar
Drives: 2012 Camaro 1LT manual
maybe using a spray can of 3M glue adhesive. I have used it to glue door panel cloth that is falling off. Works really good and you can buy it at Walmart for like $9
PLuche is offline   Reply With Quote
Old 11-22-2011, 03:55 PM   #3
SETFREE
SETFREE's Avatar
Thanks! Has anybody ever put this stuff on a door panel? just want to know the best way to do this
Old 11-22-2011, 04:03 PM   #4
Indpowr
Drives: Corvette C6
Should be an pretty easy job if your got at DIY
we do them in leather / real carbon fiber / and used to mix it up some. IMO looks really good
Photo is real but gives you an idea how it would look
Old 11-22-2011, 04:09 PM   #5
SETFREE
SETFREE's Avatar
^^^ Yup that's the look I'm going for (it's more of a flat (dull) dry carbon fiber finish
Old 11-22-2011, 04:17 PM   #6
Harley1
Harley1's Avatar
Drives: Ahh....DCB F29
Is that wrap?
Can u PM me a price...thx
Harley1 is offline   Reply With Quote
Old 11-22-2011, 04:42 PM   #7
Indpowr
Drives: Corvette C6
Originally Posted by Harley1 View Post
Is that wrap?
No, these are real car. What the OP was looking for is a sticker and looks really good IMO for what it has to offer for the price point.
I can not PM right now, i will soon as i can
Old 11-22-2011, 05:48 PM   #8
SETFREE
SETFREE's Avatar
Anybody else have ideas?
Old 11-22-2011, 06:33 PM   #9
tonytahoe
tonytahoe's Avatar
Drives: 2011 Camaro Convertible 2SS/RS
Carbon Door Panels-
I was going to have my door panels hydrodipped in Carbon Fiber,but then i heard it screwed up the ambient light tubes.Now I've heard of the company called HeadlightArmor.com. They sell this carbon fiber wrap in various lenghts/widths.Check them out,they say the door panels can be covered with this stuff.
tonytahoe is offline   Reply With Quote
Old 11-22-2011, 06:47 PM   #10
CaryE1
CaryE1's Avatar
Drives: Black 2011 2LT
SetFree, yes, check out Headlight Armor - http://www.headlightarmor.com/carbon...inyl-wrap.aspx. They have great carbon fiber wrap that would work well on the large center panel. It has a great look and feel. I have used it in several places in my car, you can see a few pics here - http://www.camaro5.com/forums/showth...=113178&page=8
However, you will need some additional adhesive for any black plastic. And, as TonyTahoe mentions, if you have the ambient lighting in the door panel, this will cover it up.
CaryE1 is offline   Reply With Quote
Old 11-22-2011, 07:40 PM   #11
TCAT
SoCal HT5: [COTW 8/15/11]
TCAT's Avatar
Drives: 2011 SS SW LS3 T76 Turbocharged
Yes, it is totally possible. I have my door panels and my dash trim (both pieces) vinyl wrapped with white Carbon Fiber Vinyl (Gloss White Carbon). Hexis is the brand of Vinyl used. That's the same kind that Headlight armor sells. It worked great, and looks unique. Check out my build thread and you'll see pics.
I have a 1SS, so the ambient lighting wasn't an issue at all. Also, the vinly wrap adheres perfectly fine without an additional adhesive. Heat it up good and stretch it out a tad while laying it on. Since I had cloth covered panels, we had to remove that and any old adhesive from the cloth before cleaning and preparing the surface for the vinyl wrap.
This pic will give you an idea what can be wrapped in vinyl :
This bottom one shows the dash trim in vinyl.
TCAT is offline   Reply With Quote
Old 11-22-2011, 08:18 PM   #12
SETFREE
SETFREE's Avatar
Thank You so much TCAT! and thank you everybody else, I am using The Scotch 3M Di-Noc (more expensive but high quality) but the problem is it wont stick to the plastic wall because its not sflat and has a "texture" bumps feel to it, I don't think you had that problem did you TCAT?
Old 11-22-2011, 08:23 PM   #13
TCAT
TCAT's Avatar
I did not have a problem with the Hexis vinyl wrap as long as the surface is somewhat flat and not curvy and contourned. The vinyl doesn't follow sharp bends well without folding up. However, for wrapping the outside of the vehicle (the whole car, or chevy bowties, etc) or any flat surfaces on the interior like the door panels, you should be fine. Hopefully you'll experience the same results. Ask a couple vinyl wrapping shops or contact Hexis directly to see what they recommend when applying. Their Hexis Carbon HX30000 material is supposed to adhere on it's own WITH heat without additional seperate adhesive I believe. Also, buy a cheap heat gun to heat up the vinyl so it adheres well, stretches a tad and forms easily to the surface. Practice on small sections first before a big project. That builds confidence and skill allowing a cleaner and more proffesional look. Otherwise, just have a pro do it for you, but it will obviously be more expensive.
Old 11-22-2011, 08:29 PM   #14
hvychvy970
hvychvy970's Avatar
Drives: Black 2011 2SSRS owner
Colossians 3:17
RK Sport Rear Spoiler/Black Chrome Powder Coated SS Wheels/Air Lift Suspension/MagnaFlow Competition Axleback 5" Tips/Hurst Short Throw Shifter/Trinity 1000 Programmer/Black GM Heritage Grille/Street Scene Lower Grille w/Ducts/20% Tint/Smoked Exterior Lens Kit/Driver's Side Grand Sport Hash Marks Flat Black
hvychvy970 is offline   Reply With Quote
Old 11-22-2011, 08:45 PM   #15
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Drives: 2010 Camaro LT/RS M6
Sorry I don't have better pics. This is from a thread of mine for a different topic. This is 3M 3D carbon fiber vinyl. It will not stick to your panels until heat is applied. It can be a pain to keep air bubbles from popping up so I would get the adhesion promoter. Take your time and work it. Apply heat to an area then smooth it out with a squeegee. The dash pieces are not an issue. BTW I do not have this anymore. I just put in leather which I am about to make a thread on. Make sure to remove all glue before applying vinyl or bumps will show.
CamaroC-17 is offline   Reply With Quote
Old 11-22-2011, 09:22 PM   #16
SETFREE
SETFREE's Avatar
Maybe that's my problem!........I didn't test it while heating it up, (only tired a small piece)
Old 11-22-2011, 09:24 PM   #17
TCAT
TCAT's Avatar
Heating vinyl wrap is a MUST. Keep practicing man. Search some youtube videos regarding professional installation of vinyl wrap. It should help you a bit.
Old 11-24-2011, 10:22 AM   #18
HeadlightArmor
HeadlightArmor's Avatar
Drives: Company Car
Post
Yes the door panels can be done - customer photo here
Looks great!
Di-Noc is an interior architectural finish. It is not suitable for automotive applications. It is not surprising you had issues.
More on the wrap in our vendor thread here
http://www.camaro5.com/forums/showthread.php?t=113178
Black and White are available.
HeadlightArmor is offline   Reply With Quote
Old 11-29-2011, 12:54 AM   #19
SETFREE
SETFREE's Avatar
Looks great!
Yeh even heating it up sucks, It won't stick and I got the best stuff on the market, or so they say, yours is better? sticks better?
Old 11-29-2011, 09:00 AM   #20
HeadlightArmor
Drives: Company Car
Post
You said you are using Di-Noc. As I said Di-Noc is an interior architectural finish. Great for your office door or elevator door, but a poor choice for an automotive application.
Our material was designed at the outset as an automotive wrap material. As with most application, initial prep and surface cleaning is an important first step. The material is warmed, stretched and pressed into place, then heating to lock the material down. We have a DIY on Camaro5 showing the application on the bow ties here
Old 11-29-2011, 05:14 PM   #21
tonytahoe
tonytahoe's Avatar
This is a question for Camarosc5 and T-Cat,did you remove yor dash panels and dash pieces yourself? and if you did what kind of pia was it to remove these items?I would like to do Carbon Fiber too,but I have not decided to wrap them or have them hydrodipped.Either way,the parts need to come off.So any info you may have would be appreciated.Thanks,Tt--
Old 11-29-2011, 06:24 PM   #22
TCAT
TCAT's Avatar
I personally did not remove the dash trim peices myself this time (the shop did it), but I have removed them plenty of times before. It's very easy and they are just clips. You shouldn't have any trouble. If a shop charges you for labor on the dash trim removal, just do it yourself. What a shop will charge you is labor for removing the door panels as that's more time consuming. The vinyl will hold up well, just make sure to wrap it well, take your time, and try not to have to many folds that are visible. However, hydrodipping or paint is a much more durable over a long period of time, but these options are more expensive than vinyl wrapping.
Old 11-29-2011, 06:34 PM   #23
DraggnFrameGMC
DraggnFrameGMC's Avatar
Drives: 2011 Synergy Green Camaro LT
Heres a different type of vinyl than what youre talking about, but it looks the same. This is interior cloth vinyl in carbon fiber. I did it last week.
DraggnFrameGMC is offline   Reply With Quote
Old 11-29-2011, 08:14 PM   #24
SETFREE
SETFREE's Avatar
HeadLightArmor,
Can I get a sample of your stuff sent to me>?
Old 11-29-2011, 08:19 PM   #25
HeadlightArmor
Drives: Company Car
We have a link for a free sample of the material in our vendor thread here (bottom of the first post)
New 2010 Camaro Side Gill Inserts - Many Colors + Carbon Fiber - Vinyl or ABS plastic RPI Designs Exterior Parts & Accessories 33 04-06-2013 12:35 PM
F/S Carbon Fiber Bowtie Vinyl xBlackout_Camaro Exterior Parts & Accessories 5 11-04-2010 07:02 PM
CARBON FIBER LOOK VINYL BLACK10 Camaro Photos | Spyshots | Video | Media Gallery 26 10-24-2010 08:49 PM
Wow!!! One Of A Kind Carbon Fiber and Leather Door Panel Inserts (Pictures) dsvcustoms Interior Parts & Accessories 26 09-27-2010 11:53 AM
