Flowmaster Exhaust
Old 11-23-2011, 02:21 PM   #1
NYCSRTATE
NYCSRTATE's Avatar
Drives: Future ZL1 or CTS V Owner
ZL1 Pulley & Tune Projected HP/TQ?
Just thinking out loud.
Pulley, tune, long tubes how much are they leaving on the table for us to play with on the ZL1?
How much more will be able to get out of the LSA by upping the boost and getting the engine to breathe better?
NYCSRTATE is offline   Reply With Quote
Old 11-23-2011, 02:27 PM   #2
jayman
Drives: 09 dodge ram
I'm guessing by looking at the lsa in the CTS-V that with pulleys, tune, exhaust you should be able to make 550+ to the wheels. Add a cam and larger injectors to that and you will easily be 600+
jayman is offline   Reply With Quote
Old 11-23-2011, 02:57 PM   #3
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 944 RWHP/787 RWTQ
Best I can tell you are only hp limited by $$$ and how much risk you are willing to take before detonation occurs to the destruction of engine internals.
Trust me I am no export on the matter but my investigatons would tend to show that once you begin pushing 700 RWHP, some serious consideration should be given to race fuel which is consistent in octane and contaminant free. Additonally, race fuel allows the tuner flexibility to tweak some fine points providing additional protection against detonation.
Chew up the meat and spit out the bones.
BiggFoot is offline   Reply With Quote
Old 11-23-2011, 03:26 PM   #4
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I think you can go up about 3psi without changing much. headers and intake are not hard.
So I mean pumping the car up to 625-650bhp should not be hard or too expensive and could probbbaly be done with exhaust intake or pulley and tune.
I read some posts on CTS-v forums adding longtubes and pulley sometimes people did not end up with the same boost numbers as without.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 11-24-2011, 10:10 AM   #5
ZL WON
ZL WON's Avatar
Drives: too many to list
When you open up the exhaust, as in adding headers or free flow exhaust, you loose boost. That's why people with CTS-Vs and ZR1s are loosing power. You have to compensate by changing out the pulleys. What I typically see when I modify ZR1s or any other supercharged build I do, I see at the most a 2lb loss in boost by adding headers and exhaust. If this is done to the ZL1 that will put the car at 8lbs of boost. I run my ZR1 at 16lbs. Anything over that, you'll have to run race gas. On my Escalade and Denali GMC truck I run 10lbs of boost and use the LS9 camshaft. My plan for my ZL1 is to mimic what I did for my ZR1, which is CNC'd heads, cam, upper and lower pulley, headers, upgraded after cooler and heat exchanger, upgraded supercharger coolant pump, one stage colder spark plugs and a few other tricks. I'll also add a 10-rib belt conversion to the ZL1 as well to prevent any belt slippage. I'll have all this done in about two weeks after receiving the car, as soon as we get our baseline RWHP number. I'll put the entire build on Camaro5.
ZL WON is offline   Reply With Quote
Old 11-25-2011, 05:42 PM   #6
hognutz
hognutz's Avatar
Drives: 2013 ZL1
yeah the post I read was a two very similar cars and the hp #'s were pretty similar but the car with longtubes had less 2lb's of boost they had the same pulley kit as the car without longtubes. they bough the pulley kit then threw the headers on and dyno'd the car I don't think they relized there would be a boost loss.
As long as you deal with a place that understands you whole mod list I am sure this is a non issue.
I don't think I will go near as far as you are going. I would like to get the strait line speed back to the Z06 I am selling to buy this car though. My wife will get angry at me if my penis shrinks in size cause my new car is slower than my old car.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 11-25-2011, 06:10 PM   #7
Shurenuff
Shurenuff's Avatar
Drives: 2002 Nissan Altima
Very much looking forward to following your progress
Factory Badassery
Shurenuff is offline   Reply With Quote
Old 11-25-2011, 07:10 PM   #8
ZL WON
ZL WON's Avatar
Just do circles
Old 11-25-2011, 07:15 PM   #9
Rice Killer
Cooter
Rice Killer's Avatar
Drives: my wife crazy
Just do circles
Who wants a helicopter ride, haha!
#1451 - 2012 ZL1 - White, Black Wheels, Manual, Suede Package, and Exposed Hood Insert. Delivered on 6/20/12. Thanks to Jason from Symdon Motors in Evansville, WI.
Rice Killer is offline   Reply With Quote
Old 11-25-2011, 08:42 PM   #10
ADM PERFORMANCE
Drives: 2016 CAMARO SS
Your right in line..
We are starting a build for GM HIGHTECH on monday that is our stage 2 setup.LS9 Cam,Thermostat,Ported Throttlebody,Intake,Ported Throttlebody,.Ported Snout,2.55 upper pulley,63lb injectors.
Very Basic build for us and will make 590 rwhp or 110 over stock to the tires.
Look for the article about the time the ZL1 hits the market.
We also have 1 we are finishing tommorow that will make 650-670 to the tires that has more boost,Larger Cam,Lower compression,Headers.
I will post the build under forced induction on this one.
ADM PERFORMANCE is offline   Reply With Quote
Old 11-25-2011, 11:20 PM   #11
MrDew
MrDew's Avatar
Drives: 2012 ZL1 #165
so, what are we looking at if we just do the pulley/tune?
Or is this something y'all would not recommend?
MrDew is offline   Reply With Quote
Old 11-26-2011, 06:48 AM   #12
ADM PERFORMANCE
2.55 PULLEY and tune will net you 40-45 rwhp on ctsv.
Old 11-26-2011, 11:14 AM   #13
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
Is belt slip an issue with ctsv and this pulley?
Old 11-26-2011, 11:18 AM   #14
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
How much will the stock bottom end take safely before it becomes a problem?
2012ZL1 is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3448 Yesterday 12:30 AM
MarylandSpeed DYNO TESTED: Diablosport Predator Canned Tune on 2010 SS A6 MarylandSpeed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 05-18-2013 11:01 PM
BREAKING: 2012 CAMARO ZL1 - 6.2L LSA Supercharged - 6MT Revealed! Tran Camaro ZL1 Forum - ZL1 Specific Topics 756 05-01-2013 07:22 AM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
