Cold Air Inductions
Old 11-23-2011, 02:25 PM   #1
bcperry
Engineer in Training
bcperry's Avatar
Drives: IBM 2010 Camaro LS
Turbos on a stick?
Just throwing around the idea lately of FI (although at least a year from now, The University of Alabama is expensive, so is my wife, LOL). My car is a 6-speed, and I know the disadvantages (loss of pressure during shifts). I was just wondering how bad this is, if anyone out there has turbos and an M6, chime in. Hopefully Tracy will sniff this out, cause I would like his input, when I do go FI it'll either be his TT system or the SC he's working on.
K&N Aircharger CAI, BBK LT's, VMAX black ICE, Trifecta tuned
bcperry is offline   Reply With Quote
Old 11-23-2011, 03:08 PM   #2
puertoricanfont
Drives: 2016 scat pack charger
+1
puertoricanfont is offline   Reply With Quote
Old 11-23-2011, 04:15 PM   #3
SC2150
The spool down of the turbos Borg Warner EFR's (the ones we use in our deluxe kit) are a new technology design that address several issue with past designs, and the internal bypass allows the turbine wheel (made out of Gamma-Ti Titanium alloy) to continue spinning at speed for faster recovery and the Gamma-Ti allow cuts turbine inertia by app 50% dramatically improving response time & spool-up. They also have integrated adjustable wastegates (not the plate style of old) so external wastegates are not needed. They also have Stainless Steel turbine housings VS cast iron that allow for less weight & thermal inertia.
The problem right now is availability. With the IRL cars going to turbos this season the teams have bought up most any in existance (we were lucky to get the ones for Whiteside Customs when we did) so it will be Jan/Feb 2012 before we expect the next batch. In the mean time we are using ceramic ball bearing top quality units for the systems.
Old 11-23-2011, 04:16 PM   #4
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
turbo and stick should be fun
Also, it should not be bad.
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 11-23-2011, 04:33 PM   #5
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Get a hold of Robert (SSE 4 2SS). He has a TT427 M6 and is a moderator on this site.
Here is his build thread:
http://www.camaro5.com/forums/showthread.php?t=122837
The car is Brandi and it's a beast !!!
Old 11-23-2011, 05:04 PM   #6
bcperry
bcperry's Avatar
I appreciate it guys, and since it'll be a bit, I'll look foreward to what Tracy was talkin about!
Old 11-23-2011, 06:56 PM   #7
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Tracy are those the turbos that come in the 8k kit installed?
CAMARO
Old 11-23-2011, 07:30 PM   #8
Boost6924
Drives: 2SS/RS
I have a stick V8. Automatic is probably faster @ 1/4 mile, but in my opinion stick is a lot more fun on street. Who cares about pressure loss on gear changes, it's spinning tires anyways
438cid IPS Twin Turbo.
Boost6924 is offline   Reply With Quote
Old 11-24-2011, 12:01 AM   #9
bcperry
bcperry's Avatar
With the steelies on mine, It'll be like driving on ice. lol
Old 11-24-2011, 01:08 AM   #10
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Hey bcperry,
As Speedster said, I have a TT build, and I am harcore trying to keep the manual transmission.
Boost loss on shifts, yes, it's there... but it's manageable for the most part and there are ways to defeat it if it becomes too bothersome...
Off the line, no issue, just step on the gas a little more until you figure out the limits of traction....
1st to second... happens really quickly... It's by nature a pretty quick easy shift... but unless you have electronic controllers, you will have to lift, so you will loose some boost... the thing here is the gearing is still low enough hat you'll wind up so quickly that you'll not really notice it... maybe after a hundred passes and time has slowed down to the point you no longer have the big eyes, you'll notice it...
2nd to 3rd... This shift typically takes a little bit longer, so you'll notice the boost loss a little bit more... So much of this is dependant on the type of TT system you have. Where the turbos are mounted... The closer to the exhaust manifold, the better off you are...
3rd to 4th... This is where you'll notice it the most on the race track, and unfortunately where it is most critical... The vast majority of acceleration takes place in the first 1/8th mile... the flip side is that Turbo's love a load... so, get through the gears and into 4th gear and let them work... The car will reward you.
If your doing mile runs such as the Texas mile, my first big goal, then you will really notice the boost loss going from 4th to 5th.. The gear change is pretty dramatic and when you step back in it, it takes a little bit of time to spool them back up... but holy moly when it does....
I was told a long time ago that really hard long pulls in upper gears are hard on the drive train... I now know why... To have the front end of a 4000 + lb car lift.... HARD in 4th and 5th gear is quite amazing... My car in 4th gear will lag for just a moment in time, and then you literally feel the front end lifting from the acceleration...it set you in the seat and keeps you pinned... It's actually quite awe inspiring...
Now, the bonus to this boost loss at each shift is it allows you time to set the tires and minimize wheel spin...
If wheel spin isn't an issue, then there are electronic box's that will allow you to perform no lift shifts... I'm not terribly familiar with them so I'll let someone else elaborate on those...
How much different is my car with the turbo's...
I used to shift into 4th gear, or red line third gear at the finish line of the quarter mile....in around 13 seconds at 112-113 mph... My best time ever stock was a 12.71 at 113 mph, and I lost... to a 12.69 at 108... Dang automatic point and shoot cars...
Now....
We launched the car very very easy due to being on the stock differential, ( a 2.55 60 ft...) and I was shifting into 4th gear at 115 mph just past the 1/8th mile, and went 11.51 at 131.9... This car is capable of much much faster 60 foot times, and consequently much much faster times and speeds at the end of the track...
Don't be afraid of the boost loss in a manual trans car... It can be managed... and when I step on the gas at 110 mph and the car drifts the back end out to the right and the tires start smoking... without the use of the clutch... no dumping it with the motor wound up... in gear, clutch fully engaged, roll into the throttle and hang on... Woo Hoo...
Old 11-24-2011, 01:16 AM   #11
blackTT600
Drives: 2011 2LT M6 SC
Hey bcperry,
Now....
:re spekt: soon
blackTT600 is offline   Reply With Quote
Old 11-24-2011, 08:50 AM   #12
Steck
Drives: 2006 twin turbo Corvette Z06
I have a TT Z06, and the boost drop isn't bad at all. A good tuner can dial in the engine to spool them faster by generating more heat, and things like turbo blankets and insulating the manifolds help them spool too.
Steck is offline   Reply With Quote
Old 11-24-2011, 09:29 AM   #13
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Couldnt you just power shift and not get any lag? Horrible for the tranny but if its once in a blue moon solely for going all out then it might be worth it.
DarkneSS is offline   Reply With Quote
Old 11-24-2011, 11:00 AM   #14
bcperry
bcperry's Avatar
Thanks SSE 4 2SS, That's definately opened my eyes a bit, I guess I just took everybody a bit too seriously. The way I took it, It would be just as well to stay N/A. But, Now that I've heard from everyone, soon as I graduate, my first few paychecks are already spent. LOL
Just Released Hurst Comp Stick Kit 2010+ Camaro Automatic Shifter Xplosive Performance Transmission / Driveline 4 01-02-2011 04:18 AM
Smoke coming out of oil dip stick tube. meschwenk Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 4 10-04-2010 08:38 AM
Replacement Stick for my Hurst shifter alfie43 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 12 08-17-2010 12:15 AM
MP3's on USB Stick Steve Dallas Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 5 12-01-2009 11:30 AM
Black Hockey Stick Stripes ls1_98 Exterior Parts & Accessories 0 11-22-2009 09:01 PM
